Question about Samsung CLP 300 Laser Printer
CLP-300 Fuser Unit
Does anyone have a service manual or anything that shows how to assemble/disassembe the fuser unit on the Samsung CLP-300? if so, mabey you could scan the page and email it to me at mitch@nospam.mitchscomputerbuilders.info , just remove the nospam. , make sure the . as well. Please Help, Thanks
  • 3 more comments
  • Mitch Patterson
    Mitch Patterson Feb 23, 2008
    solved
  • Valerie Baker Mar 11, 2008
    Does anyone have a service manual or anything that shows how to assemble/disassembe the fuser unit on the Samsung CLP-300? if so, can you could email me at val9494@sbcglobal.net?
    Thanks....
  • goonagain Jan 15, 2009
    same problem - Fuser Low Heat Error - is the message displayed on pop-up - Red light on constantly. Please help - I presume the fuser may have to be replaced but would welcome any other way round problem.
  • Anonymous Feb 03, 2009
    Were you able to repair the fuser unit or did you have to purchase a new one?
  • Big Hal Apr 17, 2009
    Getting "Problem with Fuser - call Service". Though it's about 3 years old, this particular printer doesn't get used that often - probably done less that 1,000 prints. Any chance of finding aService Manual in the UK?
Thank you but I purchased a manual from manualuniverse before seeing your post.
I was able to take apart and put everything back. I must have missed a small piece of paper in the fuser, as the paper starts coming out, then goes sideways.
Back to dis-assembly.........
Posted on Mar 13, 2008
The heating unit had a melt down - the red rubber rollers melted. Where can I get service or a replacement part? Denver, CO area. Is it worth fixing?
I use precisionroller.com
Free shipping and the cost for the fuser assembly for your printer is just $139.00. I would think it would be worth fixing. Especially if you have other supplies like toners for it.
Here is the link to your printer fuser parts.
http://www.precisionroller.com/search.php?q=clp+510+fuser
Good Luck and Thank You for using Fixya!
Oct 30, 2010 | Samsung CLP-510 Laser Printer
I have samsung CLX 3160 color laser printer, its giving message Deve Sensor Error, Please tell what does it mean and how can we solve it.. beside this do let me know if there is any option to reset it. I...
Took out all drum toner cartridges as well as waste container and cleaned with compressed air all parts as well as cleaned sensors with alcohol wipes. Cleaned CLP-300 Imaging Kit also called drum cartridge or fuser unit. (part #Clp-r300a). Problem solved.
Nov 08, 2009 | Samsung CLX 3160fn All-In-One Printer
New black toner cartridge for samsung CLP 315 (K4092) only working on one side of the page
Hi
It sounds like the fuser unit has issues and Samsung with the CLP 300 upwards seem to have issues like this all the time.
I would suggest contacting Samsung customer services to see if you can have the unit replaced free of charge.
0845 (7267864)
Thanks
Taz
Oct 28, 2009 | Samsung CLP-315W Laser Color Printer
Samsung clp-610 has an error code of ''adc slope error cycle power'' what does this mean? How can we rectify the problem?
this would be a problem with the fuser unit. the analog to digital converter, ADC, is malfunctioning or there is a problem with the heat being put out by the fuser itself. if cycling the power doesn't clear the problem you will more than likely have to replace the fuser unit.
Sep 11, 2009 | Samsung CLP-610ND + Demo Laser Printer
"Low Heat Error"
Thats probably the best way to solve the solution. Sometimes if there is a thermistor that is causing the problem that can be serviceable in the fuser unit, that can be replaced instead of purchasing a whole new fuser assembly. It's less expensive replacing the thermistor.
Jul 16, 2008 | Samsung CLP-600N Laser Printer
Low heat
Depending upon how old the printer is, if it is less than a year call up samsung and they will send out a technition within about 2 days to your house to replace the fuser unit, i had the same problem, if older than a year, you can probly order one, but be warned, i think they are like $120 but appear easy to replace, just undo the two screws at the front cover to pop off the top cover, then there should be 4 screws holding the fuser in place, remover and then slide the end of a roler on the left over to remove.
Hope this helps
Mitch
PS don't forget to rate me
Apr 12, 2008 | Samsung CLP 300 Laser Printer
Fuser is too hot....
Samsung fuser units are very suceptible to voltage variations and get damaged easily. The fuser's thermofuse probably got damaged and became unable to read temperature. The only way to get it fis is to replace the fuser in an Authorized Service Center (ASC). Your unit has a 1 year complete warranty coverage by Samsung and any real ASC without charging you.
After the unit is fixed, get a good transient surge suppresor to help protect the unit. Good luck.
Oct 19, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP 300 Laser Printer Logo
2,357 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
