Question about Toshiba Satellite A135-S2276 Notebook
Bk sp button
My bk sp button has slowed and will not do double letters untill the line flashes also the same with erasing any ideas..
    President:
  • 778 Answers
If this is a recent development, I would suggest uninstalling any recently installed software that may be conflicting.
Also, more detailed information always helps us to help you.
Thanks, and Good luck.
Posted on Feb 24, 2008
Harley trouble shooting
First, check for any error codes:
The speedometer is capable of displaying & clearing speedometer , tachometer TSM/TSSM , HFSM , ECM , ABS Diagnostic Trouble Codes also known as DTC's.
1 - Turn the ignition switch to off & run/stop switch is to run .
2 - Push odometer reset button in & HOLD .
3 - Turn the ignition switch on and then release odometer reset button . The background lighting should illuminate & the speedometer needle should sweep it's full range & indicator lamps ( battery , security , low fuel , check engine and cruise ) should illuminate . The word "DIAG" should then appear .
4 - Push the odometer reset button once and you will see the selection menu "PSSPtb" with the first P flashing .
5 - Each letter represents a area of the diagnostics module . The module that is flashing is the one you are going to check . To move from one letter to the next you must push the odometer reset button one time . ( from P to S to SP to t to b and back to P , ect ect )
P = ECM
S = TSM/TSSM/HFSM
SP = speedometer
t = tachometer
b = ABS codes
6 - To get the DTC code in a area of diagnostics you should PUSH & HOLD the odometer reset button in for 5 seconds and the release . If there are any DTC's the code will be displayed or the word " none " will appear if there are no DTC's . Push the odometer reset button again to view any additional codes if they exist .
7 - Record the codes .
8 - If DTC's are NOT to be cleared , press and release the odometer reset button . Part #of module will be displayed .
9 - If DTC's are to be cleared for that module , PRESS & HOLD the odometer reset button until " clear " is displayed .
10 - Press and release the odometer reset button to continue to the next module .
11 - Turn the ignition switch off to exit the diagnostic mode .
If you DO get any error codes, repost them for diagnosis.
Aug 05, 2014 | 2006 Harley Davidson FLHR Road king
Tip
Barcode scanner reapir tips
Loading Scanner: With the scanner powered off press and hold the SHIFT key & BK SP key on the scanner. While holding those two keys down press power, let power key go and then let SHIFT and BK SP go. The scanner will now go thru a reboot process. When done the scanner should read:
“ COMMAND MODE “
Select function
Self Test
At this point press the up arrow key twice and the scanner will now read:
“ COMMAND MODE “
Select function
Program loader
Place the scanner in the cradle and press enter. The scanner may or may not give a message saying “ WARNING: EEPROM WILL BE ERASED CONTINUE? “ At this point push enter. Let it erase the EEPROM. When done the scanner will ask you for “BAUD” press the up arrow twice and the scanner should read 38400. Press enter and, the scanner will ask you for “data bits”, press the up arrow key for 8 bits. The scanner will now prompt you for “flow control”, press enter. The scanner will now be on a screen that says:
“COMM Parameters”
Start? <ENT>
Just leave the scanner at that screen for now.
There is a file you need to test its called Diags.hex that needs to be transferred to the unit. once that is downloaded you can test the laser memory and even the keyboard.
on Dec 01, 2009 | Computers & Internet
I have a Sylvania Netbook (synet582-bk) and when I press one letter on the keyboard two show up. All keys react the same way. What can I do to correct it?
it happend on internet browser only? then disabe addons on your browser one by one untill you fint the one causing the double letter problem.
Aug 25, 2013 | Computers & Internet
How to unlock partition on flash drive
USB flash drives are small, convenient storage drives. Place data such as pictures, photos and text on them quickly and efficiently and then carry it to another computer for copying to its hard drive.
A USB flash drive that has security enabled in it must be 'unlocked" before it can be used, which becomes difficult if the password has been lost. Because the security on the USB flash drive is rudimentary, a number of methods, from built-in software to optional programs, can remove the security so that the drive can be used.
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link Below). http://www.truecrypt.org/downloads Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed.
Hope this helps.
Jan 17, 2013 | SanDisk Electronics - Others
I can not change my home page
Go to control panel, select internet option, click on top address and use Bk Sp key to erase all information, now enter your home page address and click apply.
Jun 04, 2012 | Acer Aspire Computers & Internet
How do I reformat it?
To format a USB Flash Drive, follow the steps below for your OS:
A. Windows PC
1. Power on your computer. 2. Insert the USB flash drive. 3. Click on the "Start" menu and click on "My Computer". 4. Right-click the drive letter that corresponds to your USB flash drive. 5. Select "Format" from the context-menu. 6. A new window will open, input the following information in the correct fields:
File System: FAT32 Volume Label: "Give your USB drive a title" (optional)
7. Check the "Quick Format" checkbox. 8. Click "Start" 9. Upon completion, your USB flash drive will be formatted.
B. Mac OS
1. Power on your computer. 2. Insert the USB flash drive. 3. Double-click on your Macintosh HD. 4. Double-click on the "Applications" folder. 5. Double-click on the "Utilities" folder. 6. Double-click on the "Disk Utility" application. 7. The program will open, select your device from the left-hand pane. 8. Click on "Erase" on the main page. 9. Input the following information in the correct fields:
Format: MS-DOS Label: "Give your USB flash drive a title" (optional)
10. Click on the "Erase" button. 11. Upon completion, your USB flash drive will be formatted.
Aug 15, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
My Toshiba DVR670 dvd recorder/vcr combo. When I turn on the combo and have a tape in it it will display in the bottom lefthand corner the letters SP and an arrow pointing up with a line under it above the...
need to repair or replace the unit more likely the VCR belts are not tight enoughsince the advent of DVD recorders the quality of VCR components has gone way down I have 3 combo units the only one that still records is in the unit which only has a DVD player in it. and even that won't allow tracking adjustment
Dec 07, 2009 | Electronics - Others
Camera fails to flash every time we take a picture
1.Turn off the camera.
2.Install a set of new or fully charged batteries into the camera. then turn it ON
3.Press the Flash Status button to scroll through the flash options until Fill Flash (the lightning bolt icon alone, with no other letter or symbol) is displayed. This forces the camera to use the flash. a86196b.jpg
4.Take a picture. [If flash still doesn't work contact Kodak support line 1 800 235 6325 (23KODAK)]
Nov 16, 2009 | Kodak EasyShare C875 Digital Camera
Nedd help setting time on columbia watch
Ple disregard all prior instructions. They are either wrong or a step was forgotten. Press "set" for 5 seconds. Then "mode" until you see 12-Hr flashing in the window, then press "ST/SP" until you see 12-Hr flashing, then press "mode" again until you see the word "hour", and the actual hour is flashing. At this point, you may increase time by pressing the ST/SP button or decrease by pressing the "Reset" button, then the "set" button. Enjoy!
May 09, 2009 | Columbia All Sport watch
Unable to print message on the LCD
press MENU then the blue copy button (b/w) then fourtimes the arrow up button quite quickly after another.
Machine should switch to maintenance mode and all lights will flash.
Mar 11, 2008 | Brother MFC-5840CN All-In-One InkJet...
Toshiba Satellite A135-S2276 Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
