Question about Brother SE-270D Computerized Sewing Machine
Bobbin case I need to fix my bobbin case. Can you explain what holds the case in place so the needle doesn't jam? It's for the Brother ex660 model sewing machine.
  • 319 Answers
Please see the authorized instruction manual here. Page 57 and 58 relate to your problem. If you need further help, please reply with updates!
Thanks
Posted on Feb 17, 2008
    Sergeant:
    Champion:
  • 281 Answers
I'm not really good in those things, but i suggest you to go to best buy and they will fix it for you for a low price.
I'm really sorry
    Genius:
  • 3,587 Answers
Try this link first, where the user manual resides..
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SE_270D_EN_199.PDF
you'll need the adobe reader, in case you don't have one.
www.adobe.com
  • 2 more comments
  • Patrick Michaels
    Patrick Michaels Feb 17, 2008
    ok..on page 16 of the manual I posted, there is a step by step instruction sheet with pictures..Hope that you have a copy of that manual, for this exquisite machine.
  • Patrick Michaels
    ok..step one..is the needle tightly installed, and not bent?
  • Patrick Michaels
    from the embroidery forum. Seems like this is somewhat complicated, eh?
    When a machine "jams up" like this it can cause extra thread to become
    lodged in the mechanism. Take your bobbin and bobbin case out (if able)
    and clean carefully. Use no wax dental floss on all areas that your
    thread would travel through. You may have knocked the needle shaft out
    of alignment also.
    Clean thoroughly, check needle alignment,
    embroidery foot placement, change needle and "walk it through" (turn
    hand wheel) a few stitches if you are able. If you can not stitch it is
    possible that the needle shaft has shifted and you will need to take to
    a mechanic.
    While a Brother dealer should be the most familiar
    with your machine, call around and see if any other reputable machine
    mechanics might be able to work on this machine as you will be paying
    for the service no matter where you go.
  • Patrick Michaels
    ok..so all the experts ignored the notes, and read the top product line, and went to work. and kudos to the fellow that got it right, by IGNORING the item at the top, and reading the notes from the EU. No wonder the EU was so frustrated. Most of us experts were led down an erroneous path, and I didn't catch it until the very end..shame on me for not being able to read her mind. And all it came up to was an Inappropriate rating.
    Genius:
  • 3,422 Answers
Please go through the given manuals carefully it will explain you everything step by step.
Click HERE to view the user manual
Click HERE to view the quick start guide
Goodluck..
  • Brother Master
  • 19,396 Answers
Hi, unfortunately this is not my field of expertise, in any case I can give you the link to the operation manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000059/se270dug01en.pdf
hope it can help you
I have a ULT2002D Brother sewing machine that keeps catching the thread. From the needle and winds around the bobbin causing a jam. What Can I do about this and can I fix it myself
Sounds like there is a hook of metal either on the needle or the bobbin case (sometimes happens when trying to sew something very very thick and the needle bends slightly and hits the bobbin case.). Suggest changing needle 1st, if this is not the problem, take out bobbin case and look and feel with fingers, if there is a mark where the needle has hit just use your own steel nail file and file the area very gently to remove the bur. Good luck!
Oct 11, 2017 | Brother Sewing Machines
I have a brother lx 2500 sewing machine and when it jamed i opened up the bobbin area and cleaned everything but now having problems getting the casing back in
Use a mirror and make sure that the area is perfectly clean and there are no obstructions. Then make sure that the needle is all the way up to the top of its cycle and then insert the bobbin.
Sep 20, 2015 | Brother Sewing Machines
Singer Confidence Model 7470 bobbin jammed, needles breaking, now won't sew
Sewing machines will get out of time, often as a result of broken needle. Search for sewing machine timing or take it for service, otherwise it will simply continue to break needles and possibly damage the machine.
Nov 11, 2017 | Brother Sewing Machines
The plastic part that holds the bobbin appears to be jamming against the feed dogs. The machine was working fine and then it just stopped. It jammed and bent the needle. Would not advance forward at all. I...
This is the main link for brother usa parts finder Industrial Garment Printers and Industrial Sewing Machines they should have the part or know where you can get it . If you don't find it online call and talk to them. If the bobbin case doesn't fix it you may need the timing set, but I would try the bobbin case first.
Apr 13, 2017 | Brother Sewing Machines
The bobbin case keeps rotating and jamming up. I have to open the cover and move it back into position
Are you using the right size bobbins? It requires a SA 156, I use the metal ones that I buy on ebay, 20 for $8.99 and free shipping. Less trouble.
Sep 18, 2010 | Brother EX660 Computerized Sewing Machine
I have a CE-4000 model. In the middle of sewing,
When you put back in the bobbin case, there is a little "knub" that sticks out with a flat spot on the right (on the top side of it) that you need to ensure it rests gently to the left of the position finger bracket (silver metal piece, in the square of the bobbin case area its on the right closest to you).
When you put in initially, it was probably twisted clockwise and there was a gap between the knub and the position finger bracket and when you put the needle plate on in jams that bobbin case in that position and the needle just takes chunks out of it..
You might need a new bobbin case, try sanding out the needle marks with sandpaper.
-Chirs
Jun 04, 2010 | Brother CS-100-T Computerized Sewing...
Machine jammed
Turn off the power and remove the needle and presser foot.
Open the needle plate and bobbin case and clean the area, removing lint and the jammed thread.
Make sure the bobbin case is properly in place.
There is a maintenance section in the manual to show you how to remove the bobbin case and clean the machine.
Install a new needle with the flat side to the back of the machine.
Rethread the machine with the presser foot up.
Make sure the thread from the bobbin is feeding from the bobbin spool in the correct direction and through the proper guides.
If you need a manual, you can download one at Brother.com.
Mar 10, 2010 | Brother CS-8060 Computerized Sewing...
Corect threading needle for sewing on brother lx3125
please follow the instruction
1. raise needle to its hieghest position
2. remove hand hole cover plate
3. remove bobbin case from shuttle, pull open latch of bobbin case
4. pull bobbin case straight out of shuttle
5 insert bobbin into bobbin case making sure thread is coming from bobbin.
6. pull thread through slot
7. pull thread under tension spring
8. holding latch open position case into shuttle, and release latch. case should lock into place when latch is released
happy sewing.
regards please rated me.. thanks
Mar 31, 2009 | Brother Sewing Machines
It's a brother ex660
see my notes on your premium solution. I'm around the 4th of 5th down the list.
Feb 17, 2008 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
170 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
