Question about JVC MX-D301T Shelf System
CD fails to start.
At times the unit fails to recognise the music CD in the tray, or recognises its presence and shows tracks & time play on screen but doesn't initiate playing. The fault is erratic. Pushing 'play' on the remote doesn't initiate either.
Is this a faulty head or 'dry joints' somwhere?
Stephen
New Zealand
  • Steve Bostin Feb 17, 2008
    Model is JVC MX-D501T -if it makes a difference!
    Genius:
  • 3,422 Answers
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
If still ur problem is not solved then i am sad to say you have to get it repaired and thats the only solution..
Good luck..
Posted on Feb 17, 2008
    Genius:
  • 3,587 Answers
Well..that looks to be a clear indication that you have a lens cleaning challenge. Believe it or not, it 's not unlike the old head cleaning for audio and video players. Now, here's the rub, the cleaning kits that are recommended are quite dear. Let me see which ones are available for this unit.
Denon CD deck
This unit needs a service visit. It may be a common problem with that model but to me it sound like a power supply issue as when you play a disc more power is used to rotate motors and move the sled. This is indicating to you that it is in a weakened condition and will soon fail more significantly. The problem may be as little as a solder joint or a defective Filter capacitor which is common in some models of equipment.
Dec 11, 2012 | Audio Players & Recorders
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
CD playing erratic
Run a "Laser Lens Cleaner" thru the unit a couple times. Use one that takes fluid, you can find them at just about any retail store for 15-20. If that doesn't solve it, it needs to be repaired. At that point weigh the cost over replacement. A new transport usually will cost 100-150 on average for parts and labor. Hope this helps
Jun 23, 2009 | Audio Players & Recorders
All In One Centre
- i like your problem can u give me more variables for this case?
-OS used
-type of connection(wifi light if applicable)
-workaround try to scan via MSPAINT on file their is scanner and cameras- to scan from the PC->printer
Sep 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
My music wouldn't play
just throw ur f**kin' memory card and buy a normal one which can recognize any music eccept wma tracks
Aug 04, 2008 | Sony PlayStation Portable (PSP) Console
File format not recognised
you need to put all your songs in mp3 format ?or better still down load mp3 music only or try this MP3 Converter - MP3 to WAV and WAV to MP3 Converter Software Downloads
Jan 13, 2008 | Sony Network Walkman NW-E005 MP3 Player
Disc won't play
Silmilar problem on a MX-D501T
Dec 09, 2007 | JVC MX-D301T Shelf System
Device Won't Recognise Blank CD-R Media or Certain Music CDs.
try and see if you can pull a directory using explorer,, sometimes if you record to the full 80 minutes capacity, the disc will return an error,,,even if you recorded it on that drive...also i know this may sound strange but on the drive tray itself take the mount where the laser is mounted and extend it out to the furthest travel point ,,,gently,,,do not force...load the disc, and see if it is now recognized,,,sometimes it is a timing issue, and this way the tray/laser recalibrates itself....
Jul 03, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
JVC MX-D301T Shelf System Logo
142 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
