Back to:
Tags:
Videoseven LTV32H 32 in. LCD Television
Red light goes on & off when i put the tv power...
posted by Lamre on Feb 17, 2008
Its been more than a year that i have bought my Videoseven LTV32H and i haven't used it very much. I don't know what might have happened since it was fine when i turned it off last night and I am the only one using it.Of course it was plugged in all night as it has allways been.Outside the weather conditions were good so there's no chance of a thunder or anything like that.I removed the power cord from the outlet hopping that it might somehow "rest" but it didn't work.Now when i put it in the outlet the red light goes on and off blinking like a sort of message but since i don't have the service manual i don't know what it means.Outlet voltage 240 V.Hope that anyone can help me!!!
Thanks to anyone in advance.
Comment by Lamre, posted on Feb 26, 2008
I connected the TV to a UPS but nothing different happened.Then i opened the case myself trying to find anything that could be wrong.I sow there was a fuse and I pulled it out.I checked it and it was good. The light blinks on and off repeatedly like it should mean something, but the thing is that i don't have a manual to understand what is wrong.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 17, 2008
Thanks for Trying (70)
PaulTulsa
Rank:Master Master
Rating: 81%, 11 votes
If the unit operates properly, use an UPS, uninterrupted power supply. Even though there are no thunderstorms, power is not always "clean." It may fluctuate depending on localized conditions.
Rating Locked! (?) Lamre has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Red light goes on & off when i put the tv power cord into the outlet:
I don't want to Accept this solution
Can you Help with these Flat Panel Televisions problems?
phillips 47 inch ambilight t.v perfect picture and sound...
i get no visual on tv yhe monitor keep sayin no signal
I have received this TV from my older cousin that has had...
whrn i hook my laptop to the telly the picture isnt as...
when the tv is switched to standby , it will not switch...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
