Question about Cell Phones
V3 unable to charge
My razor v3 worked fine until i tried to charge it first it said unable to charge then it died and it wont charge someone help. whenever I take it off the charger it just turns off.
  • thebigred Jan 03, 2009
    how do you reflash the firmware
    Brigadier General:
  • 7,752 Answers
Reflash the firmware this will correct the charging issues and if that does not fix it then have the mainboard replaced.
Posted on Feb 17, 2008
I try to charge my razor using my blackberry charger but it wont work it keeps saying "unable to charge" why?
hello,
from explanation this means that you are trying to charge your razor with another phone charger , it will not work out for them self because they are not compatible .
what you need to get your razor phone is the type of his own charger ,but if you can not fine it own charger then you will have to go the store together with your razor phone then will help in locating it own charger that will work for with out any damage on your phone
thank you and thanks for using fixya.
Apr 11, 2010 | Motorola Mobility RAZR V3
RAZOR v3 -- i have 2 batteries, both good, 2
try taking out the sim and blow the stuff out of it. Then put it back together and see what happens
Dec 29, 2009 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
Unable To Charge Message on Razor Cell Phone stops working off charger. Battrey shows full
My v3 has done the same sometimes I couldn`t charge then taking it off charge it used to die.
Try a new battery.
Nov 09, 2009 | Motorola Mobility RAZR V3
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
May 27, 2009 | LG VX9400 Cellular Phone
Razor will not charge
my own razor does this also. the problem is the charging port on the phone. try using an electronics cleaner inside the port but do not oervsaturate. Otherwise if the phone is warrantied or you have insurance take your phone in and get it changed. I had a spare phone that i use to charge my battery. hope this helps.
Sep 11, 2008 | Motorola Mobility RAZR V3
RAZOR V3 wont charge
clean the charging port, try changing the battery if that does not work then take the phone and have it checked.
Jun 19, 2008 | Motorola Mobility RAZR V3
Unable to charge the razor
there may be a short in the wire or in the plug. try wiggling it around a little bit and see if you can get a connection
Jan 19, 2008 | Motorola Mobility RAZR V3
Unable to charge
try a travel charger and see if that is charging it...if that does not help the problem you may need to change the charger port. or when u install it on the pc....check your device maanger and see if it has a yellow triangle which means that you may need to update the drivers for the computer to recognise it...hopefully you are using windows XP...if you are using vista that O/S is giving loads of problems.
P.S. trying loading on your MPT 4.0....if you do not have it you can download it for free online
Dec 21, 2007 | Motorola Mobility RAZR V3
Phone is dead wont take charge
You simply need a new battery. Razr batteries are notorious for loosing life and the entire problem is the chargers you are using. You MUST have one with an IC chip that tells it when to stop charging otherwise watch how long you are charging it. Also when you have a new battery let it fully charge and fully die twice before you start normal charging this helps a lot.
Feb 24, 2007 | Motorola Mobility RAZR V3
Unable to charge :(
Does it say something like "charger not recognized". I remember having this problem with my razor, and it drove me crazy for several days, then it went away and has never returned. I may have also blasted all the txt messages away to help fix it to. Killing all the txt messages seems to help this phone if its acting up. Definitely speeds up the menu operation. Apparently 250 txt messages is its capacity, even though it will store alot more.
Nov 11, 2006 | Motorola Mobility RAZR V3
Cell Phones Logo
261 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
