Question about iRiver Clix Digital Media Player
Iriver Clix USB freeze
Mu Iriver freezes on music menue and when i try the USB connection
I have tried another iriver on the same USB port and cable works fine
any help avialable?
  • Anonymous Jul 08, 2008
    On the screen it alwasys shows usb connected,
    When I disconnected this message still appears,
    My computer recognize it I can drag music, video or format,
    I tried everytihin formatting, firmware upgrade, reset but it didn’t work,
    What shall I do,
Worked like a dream! Thanks!!
Posted on Apr 23, 2008
My screen also froze in the music menu, but when I connected to the PC, it was recognised and I could get into the files. Try resetting it by sticking a paper clip in the reset hole if you've not done it already. Mine's working fine so far....
Posted on Mar 06, 2008
  • ken_mintcake Aug 24, 2010
    I used the bottom E string on my acoustic guitar - and it worked! I wouldnt recommend this for any other problems you may have................
I would like to ask the problem of my iriver clix 4gb the problem is my iriver didn't on or my iriver is I hope you can help my problem of my unit thanks................
If it do not power up at all ..check the battery ..cause it may have connection problems ...if it opens but freezing on start ..look for the reset button ..and reset it ..This is a button hidden in a hole and need to be pressed with the stylus or with a sharp object ..and the unit has to be powered and on when you do it (even if it is in freezing position )
In the first case..no power at all ..you will probably need a new battery cause this one it is either corrupted or lost the ability to store the power ...It might power with the ac charger inserted so its worth a try ..
Jan 14, 2011 | iRiver clix 2nd generation MP3 Player
Iriver Clix 2 8GB connecting to PC problem
Usually it have to, but if is not use iriver plus software !! or see if u have drivers properly installed.
Apr 28, 2009 | iRiver Clix Digital Media Player
Iriver clix - dowloading music from laptop to iriver clix
If you set up Windows Media Player to autosync to the Clix, then, when you delete songs from the computer (including the wallpaper jpeg), the files also get deleted off the clix. Make sure you have Manual Sync enabled in Windows Media Player (or, more accurately, disable auto-sync).
If auto-sync is already disabled, then you have a good, old-fashioned DB corruption. You can reload the firmware from iRiver's website:
http://iriverinc.com/support/ultra/clix2.aspx.
Sep 07, 2008 | iRiver clix 2nd generation MP3 Player
MAJOR PROBLEM?
did you fix your player, , if you did can you tell me how
Jun 27, 2008 | iRiver Clix Digital Media Player
Iriver x20 - freezes and wont show as a connected device to pc
When you connect the PMP to the computer does it say your new device is ready for use or something else like 'the device has malfunctioned'?
I have the same issue that frequently the computer won't see the PMP. Keep trying it sometimes works. If not then its likely that the harddisk is dead or dying.
Apr 22, 2008 | iRiver PMP-120 Digital Media Player
IRiver Clix Freezes Up
I had the same problem. Sent it back and got a new one. They said it is a cold solder issue.
Mar 18, 2008 | iRiver Clix Digital Media Player
Iriver "USB Connected" screen problem
Before suicide, first consider your daughter ;)
Then make sure the USB ports and cables do not have a lot of dust in them.
Unplug and try it in a different port[also those in the back of your computer]
Make sure you have the driver installed.
Hope that helped, if not, reply with more details.
Jan 12, 2008 | iRiver Clix Digital Media Player
IRIVER PLUS 3 MEDIA TRANSFER SCREEN
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
Dec 30, 2007 | iRiver Clix Digital Media Player
Iriver Clix problem
yes i river has got customer support in online but i don t know how efficient it is if you had brought it from india , you better contact the vndor and ask for its warranty support man or else give a try connect the i river to another computer with windows xp (i prefer) and then install the software bundled up with your device and try to format the device via the software and then disconnect the device and power it on it will work i think
Aug 06, 2007 | iRiver Clix Digital Media Player
iRiver Clix Digital Media Player Logo
359 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
