How to use recover an information from bad hard drive by using recovering disk
I'm a hardware computer engineering but my problem is that my hard drive get damage but i want to you a recovering disk to get some information out of it how can i use it and where can i get some
  • lupe_nyc Mar 19, 2008
    physically damaged travel drive. how do i recover data from disc?
    i was told by office IT that wires need sodering to read data. can data be recovered w/o this?
    thanks.
    Problem Solver:
  • 16 Answers
It pretty much depends on the type of damage.
If the Hard Drive has no Hardware Faults, then you should be able to recover your files... or at least some of them. There a lot of specialized utilities out there that will do whatever they can to help. [Link below.]
If it IS a hardware fault, then there isn't much that you can do... the only solution would be taking the HDD to a specialized Data Recovery Service. However, that is a very costly solution... it all depends just how badly you need the data.
I believe the following link will give you all the information you need:
http://free-backup.info/data-recovery-software.htm
Make sure you understand everything before you venture forth with the data recovery.
Hope it helps... and good luck. Don't forget to rate me.
P. S. In the future, adding a full stop ("dot") to appropriate places in your question would make it much easier to read. :)
Posted on Feb 17, 2008
How to recover data from my toshiba 320 hard disk?
Data lost due to unintentional formatting of the drive or when someone knowingly delete some data later on realizing that the data was important, In situations like this one should use a data recovery tool. To know more about data recovery process visit http://www.recoverlostfile.net
Dec 23, 2012 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
Tip
Hard Disk Data Recovery
Definition of Hard Disk: Hard Drive is a storage device where you can store any types of data and file. Hard Drive is available as external and internal device. We know PC storage device as internal system Hard Disk. When you save data or install programs on your computer, the information is typically written to your Hard Disk. The Hard Disk is a spindle of magnetic disks, called platters, that record and store information. There are several interface standards for passing data between a Hard Disk and a computer. The most common are IDE and SCSI. Hard Disk is made of one or more aluminium or glass platters, coated with a ferromagnetic material. Most Hard Disks are found as Parallel ATA (PATA), Serial ATA (SATA) or SCSI device.
Difference with Floppy Drive:
The term hard is used to distinguish it from a soft, or floppy, disk. Hard Disks hold more data and also faster than floppy disks. As an example a Hard Disk can store anywhere from 10 to more than 100 gigabytes, where most floppies have a maximum storage capacity of 1.4 megabytes. Floppy is more risky device than Hard Disk for losing data.
Problem with Hard Disk:
Most common problems of Hard Disk which may arise anytime are Booting problem, OS Installation problem, Hard drive crashing and another Hard Disk not showing original space or not showing partition etc. But in every case the risk is loss of data. In some of cases formatting and reloading of Operating System can recover your Hard drive and make it useful but formatting can recover a blank Hard Disk only without data. But you have to recover Hard Disk with data, so formatting is not possible.
Data Recovery:
Data recovery is the process of retrieving back data from the damaged media. The damage of storage media can be physical damage and logical damage. The data is retrieved back by recovery experts after determining the type of the damage caused to the storage media. Most of cases data recovery is important and formatting is not possible there. So that I need to choose another way for solution of this type of problems of Hard Disk. The first and secure way to recover a Hard Disk is using data recovery software.
Recover Data from crashed Hard Disk: Power surges, Software Corruption or Malfunction, Hardware or system failure, Natural calamities, User errors may crash your Hard Drive. Data recovery software helps to retrieve or recover the data from the crashed hard Drive. Data recovery software gives an easy and Graphical User Interface with less difficulty so that the data can be recovered easily. The recovery software helps to recover the data and restore them on a second Hard Disk, the Hard Disk being connected to the computer and recognized by the BIOS, the recovered data can be stored on a safe location on the second disk.
Logical data recovery: In a data loss situation when the Hard Drive is perfectly fine and the BIOS recognizes the Hard Drive but reports a read error, logical data recovery technique is very helpful. Here the files that are damaged or corrupted by any user error or virus attack are rebuilt rather than repairing the Hard Drive.
Fragmentation: When the FAT entry is lost during accidental file deletion, formatting or partition deletion that particular block of Hard Drive becomes inaccessible. Some data recovery software makes an attempt to rebuild the files without a FAT entry. This technique is very efficient if the file size is smaller than the clusters size. But it is inefficient in recovery the larger files.
Data Recovery from deleted partition: Partition is allocation of memory in different sections. Each partition will be like separate disk drives. Partition is very use full when the user is using operating systems more than one. Usually after formatting the disk it may not be able to recognize a partition because of accidental deletion of the partition table or by virus infection. The partition is not actually deleted; it can be recovered by using recovery tools and copy the data present in the partition to the required destination. Formatting the drive erases a large amount of data present on it, but not all the data. The recovery of the data depends on the fragmentation of the file system as the parts of files are being placed on different places in the drive. The data recovery software will assume that files were not fragmented and stored in continuous clusters. If the partition was formatted using different file system, then recovery process will be very complicated.
Another Data recovery process: If you don't have any data recovery software you can try another process to recover data. Attach the Hard Drive with another system in slave or second SATA.If detect the drive then boot to the first Hard Drive and use the bad Hard Drive as secondary. Then you can copy the data from the second drive to first drive easily. Here have another process to recover data from a crashed Hard Disk. But it is so risky, and should not try to do this for an inexpert person. First pack the Hard Disk in a bag properly where moisture can't attack. Now freeze it upto get chill. After freezing quickly attach with a system in secondary, and copy the data within the Drive will come in room temperature.
So the most secure process to recover data from a Hard Disk is to use data recovery software. It is available in market.
on Mar 18, 2011 | Computers & Internet
External hard disk WD 500gb icon absent in my computer window?
Turn the computer off without the external hard drive being plugged in.
plug the external hard drive in a usb port, power up, the systems post boot up will find the drive and inform windows what hardware is installed.
When windows boots up, it will look at all the hardware and find the external hard drive, when windows finishes booting up you should be able to see the drive in my computer.
If you can't access your files,data recovery software can help.I used this one called Tenorshare Data Recovery to retrieve files off crashed HDD and it worked. Get it from http://www.any-data-recovery.com
If needed,you can download it and scan your hard drive for free to preview whether your files can be recovered.
Mar 29, 2012 | Western Digital WD Elements Portable...
I can't access my wd external hard disk (passport )through (my computer) i can see it using windows disk management as unallocated partition...when right clicking..no options are active but properties
Hello
Have you tried accessing the hard drive on another computer?
Have you tried using a different USB cable?
Was the hard drive dropped or moved while it was plugged in?
Check the WD Site if you hard drive has warranty.
I hope this solves your problem and please reply if you need more help.
May 11, 2011 | Western Digital Passport WDXML800UE...
I want to recover my computer to factory settings
As soon as you press the power button on your notebook, Keep tapping F8 repeatedly. Another screen should pop up with a list of commands (safe mode / start up repair etc) Near the bottom of the list you should see an option to ReInstall windows / Reset to factory Default. Select which one you prefer and follow the simple instructions.
Hope this helps and please rate thanks.
Mar 13, 2011 | Toshiba Satellite L305D-S5881 Notebook
I can see the disk in Computer Management but it's not mounted nor can I browse the files on the drive. Hmm...
Check the drive properties in Computer Management / Disk Management.
Often a drive letter will be set to use the same drive letter as another drive already in use by the system.
Try using "Change drive letter" and set it to some other value.
Feb 24, 2011 | Apricorn DriveWire IDE/PATA/SATA to USB...
Sony vaio not recognizing external hard drive
PLEASE GO TO CONTROL PANEL, CLICK ADMINISTRATIVE TOOLS, CLICK COMPUTER MANAGEMENT, ON LEFT PANE, UNDER STORAGE, CLICK DISK MANAGEMENT, WAIT A FEW SECONDS, MAXIMIZE PAGE,THEN SEE IF YOU CAN SEE IT. IF IT SAYS UNALLOCATED SPACE, RIGHT CLICK ,YOU WILL HAVE TO FORMAT USUALLY "NTFS". IF IT DOES NOT SAY UNALLOCATED SPACE, THEN RIGHT CLICK AND MARK PARTITION AS ACTIVE. .........HOPE THIS HELPS........JEFFXC
Jan 25, 2011 | Western Digital My Passport Essential...
Sony Vaio laptop could not access 1TB external hard drive
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Oct 20, 2009 | Western Digital Computers & Internet
The hard drive is not being detected on our laptop it turns on and everything but its not being detected what is the problem its not even a year old yet.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
Oct 09, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
I had a problem recovering my computer. I bought recovery disks from compaq. 4 hours into I got a message Can not copy X:\WINDOW\1386\LANG\IMJPCL\HL_. Can I fix this? If it is possible great I will pa
Sounds to me like the hard drive has bad sectors on it and it can't copy all the files to it. Also its taking way way to long to recover, shouldn't take that many hours to recover the computer with the disks.
Its taking to long to copy and verify the information to the hard drive. Get the hard drive replaced with a new one or a known good used one.
May 22, 2009 | HP Compaq Presario SR1430NX (PS566AA) PC...
Computers & Internet Logo
228 people viewed this question
Alun Cox
David Payne
David Payne
