Ws-a65 HD TV remote issue
We are unable to get the actual tv to return to channel 3, therefore we cannot get the ps2 box to work. Please advise!
  • 593 Answers
Ch3 is not programmed as an active channel, try and add it manually or turn on the PS2 and do an autoprogram. Why is the PS2 on an RF input, are you using a modulator? Turn it on and autoprogram again, itll pick it up.
Posted on Feb 17, 2008
Mitsubishi WS-A65 1080 HD Series Won't Switch from 480i to 1080i
Its main digital board has to be replaced. It is a skilled work. If you wish to get more details about this work, check the site linked below and pull up older posts there.
Apr 22, 2013 | Televison & Video
I have the new suddenlink little boxes put on my tv by your people. BUT they did not fix the remotes to work with the tv combos (tv and dvd) They will not turn on the tv therefore I must use one remote...
Hi - My name is Tina and I am with Suddenlink. I am very sorry for the issues you are having with the remotes for your new DigitaLink boxes. If you would email me at tina-AT-suddenlink-DOT-com, I would be happy to help resolve this issue. Thanks!
Oct 13, 2010 | Televison & Video
DVI Alert, your HDTV does not support HDCP. what does this mean? Please use YPrPb component connection to watch
Ok so, I was having the same exact problem but I got mine to work.
Make sure you have your HDMI cable is connected from the TV and cable box....
1)Turn off your tv and reboot your cable box (my cable box was rebooted by pushing the following buttons AT THE SAME TIME: "info," "vol ," and "vol-").
2)Once your cable box reboots completely, power it and the TV on...
3)Push your INPUT button on the actual TV REMOTE. Give it a couple of seconds and then use your CABLE BOX REMOTE to begin switching the channels. Your HD channels will be in the 600's if you have the same cable company as I do.
Hope this helps...it worked for me
NOTE: Your COAXIAL should only be plugged in from the cable outlet on the wall to the cable box. Your HDMI cable will be the one to plug FROM the CABLE BOX to the TV
Aug 08, 2010 | LG 42LC2D 42 in. LCD HDTV
TV only works on HD stations
Your TV has an SD/ED component input and an HD component input. You are using the HD input. It can only accept HD signals. You need to correct the settings in you cable box. You need to "fix" the video output so that it converts everything to HD. If you have a motorola box, you can usually turn the box off and press the menu button to access the cable box setup menu. Set the 4:3 override to Stretch or Full. If you need more help with this, post back with more information: cable provider, cable box used. I hope this was of some assistance.
Mar 28, 2010 | Samsung DLP HL-P5663W 56" TV
Cannot hook up ps2 to durabrand model DWT1304
yes , you need to be in GAME mode on the TV , since you don't have the remote you can still access GAME mode from the menu button on the front of the TV . you must be in GAME mode for your PS2 to work. thanks
Dec 30, 2008 | Durabrand DWT1304 13" TV
I cant get high def 1080-i to work on my mitsubishi 55807
IYou have to have your comcast box tuned to a channel that is broadcast in HD. On your Comcast remote hit menu. This will bring up several icons, one is HD. Select that icon and it will bring up the TV Guide for just HD channels. Select one and tune to that channel. Once your on that channel use your original remote and hit menu, then advance features, then go down to video display and change it from 480 to 980 or 1080. Let me know if this helps.
Dec 15, 2008 | Mitsubishi WS-55807 TV
I just subscribed to HD service, But my mitsubishi 55807 tv wont display 1080 it stays on 480. the server is comcast. can you help?
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
