Question about Roper RAS8445KQ Top Load Washer
Washer not filling
My topload Roper washer is not filling up. Both hot and cold water come on but it doesnt stop running, I can't tell you how many gallons have been wasted. It started on the regular cycle so I switched to heavy and now it only fills on gentle.
  • 2 more comments
  • facesister Feb 18, 2008
    No it doesn't over flow on the floor. Both hot and cold pumps come on but the tub just doesn't get full, it simply goes down the drain.
  • facesister Feb 19, 2008
    Thank you it worked.
  • Anonymous Oct 10, 2008
    I had the same exact problem with my washer not filling up. Draining as it filled I suppose. I tried moving my drainage hose up and it seems to be working like a charm!!!! I was so close to going out and buying a new washer because I couldnt fix it! Thanks so much :-)
  • shannabelle Oct 10, 2008
    Thanks for the drain hose solution! I have a different washer but same problem and it worked like a charm! Thanks
  • 770 Answers
Plz dont take this wrong but you say it fills and WONT STOP?? does the unit over flow on the floor?? or you need to let me know because the last part of your question states a diffrent problem..is the hot water valve on?//plz answer my questions and we can go on.
Posted on Feb 17, 2008
  • Gary Davd
    Gary Davd Feb 18, 2008
    You need to raise the drain hose up to a higer point than the tub level too low will create a siphon.. Try that and let me know
New roper wash. Mach. Will not fill on warm wash, but does on hot cycle
this could be a simple fix, where your hoses screw onto the back, ensure that there is a screened washer in place as your cold water is pushing the hot water back through the lines so the hot can't come through with the cold running as well, thats why it will only be hot or cold, scoot down to your white goods center and they will provide you with the correct washer screens for your unit, cost should be no more than about $3 a piece. good luck.
Oct 14, 2013 | Roper RAS8445KQ Top Load Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Roper washer stops at rinse circle
Turn off your water to the washer.
Remove the hoses from the valve at the rear of the washer and clean the trash out of the filter screen.
You have a cold fill rinse washer.
If it can't get water it stops advancing the timer.
Mar 08, 2009 | Whirlpool LSB6200KQ Top Load Washer
Top load roper washer water will not cut off after filling machin
The water valve is the part where your water hoses connect.
Replace the water valve if the water is constantly running after the machine has been turned off.
If it only overfills during the fill cycle, check your water level switch and connecting plastic air pressure hose.
Mar 08, 2009 | Roper RAS8445KQ Top Load Washer
My Roper won't fill with water.
you need to replace the water inlet valve on the washer that the hoses go on,it is stuck closed,have you tryed hot water only to see if it comes out?the valve has a hot and cold water supply valve,you can get one by going to sears .com click on parts out in your model number and order your part,let me know if you want to try it and i will tell you how to get into the cabinet-mike
Nov 18, 2008 | Roper RAS6233KQ Top Load Washer
Cold water not running.
check the cold water selenoid on the water valve
May 05, 2008 | Washing Machines
Washer takes forever to fill
sediment gets clogged in the valve that cant be cleaned if you replaced the water valve it will solve the problem
Nov 25, 2007 | Roper RAB2121KW Top Load Washer
Washer leaks when running full loads
This could mean the fill level is not working properly and there is an overfill situation. Generally[I don't know 'Roper'] the fill level is controlled by a 'bottle' like device at the fixed to the outside of the drum at the bottom with, with a fine tube leading to a disk like thing near the top of the machine- with wire coming from it to the controller. The 'disk' thing is the pressure sensor. and the bottle thing is supposed to fill with water and the air pressure in the tube actuates the switch in the 'disk' Overtime the 'bottle' will get clogged with crud and need cleaning out. This will mean taking it off and giving it a good cleaning. Hope this helps.
Jul 07, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
181 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
