Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Honeywell digital thermostat error code
Misplaced heating manuals for honeywell digital theromastat and beckett burner system. Code is displayed in lower left corner of therm. and looks like a bottle. Burner has green flashing light above reset button. HELP
  • Anonymous Jan 10, 2009
    why don't they just let the up arrow make the heat go up!!!!! I am calling my husband in germany but its the middle of the night and can't reach him and the baby and I are cold. don't they have online manuals at least? they should post something here. I know there is a way to turn on the heat.
  • Anonymous Jan 22, 2009
    I have a basic digital hoeywell thermostat - nothing fancy like being able to program changes - where I just choose heat/cool and use arrows up and down to set the temperature. I don't know where the manual is. I have it set at either 70 or 71, but the read-out is fluctuating between 65 and 66 for that past 2 days. There is a little flame (assume trouble/error code) above the read-out temperature. Can someone tell me what my problem is and what I need to do -- Hopefully something I can do myself.
    Thanks, Lynn
  • 579 Answers
SOURCE: honeywell round mercury thermostat - heat not coming on
If you tip the mercury switch so that it makes contact and the furnace doesn't start, it isn't the t-stat. Check the connections, then start checking the furnace.
In any case, ditch the mercury t-stat (recycle it properly) and get a new programmable one if at all posible. It will pay for itself many times over by turning your heat down in the middle of the night and back up by morning.
Posted on Feb 10, 2008
SOURCE: Honeywell VisionPro USER SETUP CODES OR INSTALLER CODE FOR TEMP RESTRICTION
You need to get into the installer setup. Download the installer manual from Honeywell or an on-line vendor and it has the installer codes to alter the maximum heat setting. Press the system button and then buttons 2 & 4 at the same time for 5 sec to enter the installer mode. I believe the code is 0600 and then you enter the max temp for heat setting. Press done and your done!. Try this link for the installers manual http://www.alpinehomeair.com/related/Honeywell_VisionPro_8000_%20Install_%20Instructions.pdf
Posted on Feb 12, 2008
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
  • 19 Answers
SOURCE: permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
Posted on May 17, 2009
  • 3 Answers
SOURCE: Honeywell Thermostat power light
I just had this happen to me a few days ago. I hope you find this response before you did what I did and paid an AC guy $103 for him to do about 5 minutes worth of work. Here goes.
The power is shutting off because your drip line is clogged. Your drip line is the tubing that goes from your compressor (inside) to the outside of your house. When that tube gets clogged up (with algae and dirt) then the water will backup in the line. There is a protection circuit in the line and when it detects water (because of a backup) then it shuts all power to the AC off. If you take a shop vac outside and **** all the **** out then you'll be fine. The AC guy said that when I replace my filter every month that I need to pour about 1/2 cup of bleach in the line (from the inside) to prevent algae from forming and stopping the pipe up. Hope this helps someone out there before it costs them a $100.
Posted on Jun 11, 2009
I honeywell 3035d security box, no key, dont know code.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 07, 2010 | Honeywell Electronic Programmable...
Honeywell T2060 UtilityPro Demand Control Thermostat
Go to honeywell.com
Feb 16, 2010 | Honeywell Electronic Programmable...
Honeywell Beckett Oil burner locked out.....just
how do you reset a beckett oil burner when your locked out ?
Nov 04, 2009 | Heating & Cooling
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
Jan 21, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
4,781 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
