Question about Dell Latitude D600 Notebook
Start up problems
At start up, the screen doesn't load windows. It gives two options. Before timing out. The first option 1 Will load windows, until next start up, then same prob when re-starting windows.
The 2nd says;
2nd. Microsoft XP Proffesional-windows could not start because of a computer disc hardware configuration problem
could not read from selected boot disc.
This D600 was refurbished! How can I fix so theese options don't come up & I can start windows the correct way.
It was a count down setting, r-click
on "my computer" set to 1sec.
Posted on Feb 19, 2008
  • Dell Master
  • 19,396 Answers
Looks like you need to reinstall windows. get a windos setup disk and reinstall it. If it does not install cause windows setup cannot detect your c drive, then you may need to change the hd as well
first try reinstalling windows
Posted on Feb 17, 2008
My dell inspiron 1454 keeps looping on the boot up screen, then just goes back to the windows has filed to start screen..
Hi Charlotte,
The video doesn't show what you describe. The video shows that Windows is loading. Try booting in safe mode. Here's how:
Power up the machine. When the Dell logo appears, start tapping the F8 key until the Advanced Boot Options menu appears amd choose "Windows Safe Mode." Once windows starts, backup your data just in case. Then try to determine what it was you did last that may have caused the problem. Then try to start normally.
Hope this helps
Randy
Nov 02, 2012 | Computers & Internet
Hp pavilion slimline s3600t desktop pc - Wont boot up, flashes to blue screen after hp blue screen and restarts. no option for safe mode either
A Blue Screen is more time than not indicative of a driver issue or some hardware issue. First of all when it boots to the screen that shows Safe Mode and the other options, scroll down and see if there is an option to Stop or Disable Automatic Restart on Boot. This will stop the screen from restarting itself when the blue screen appears and give you a chance to read and see what the error is. Afterwards it is ok to run Startup Repair. Startup Repair does not delete any of your personal files. Let startup repair run and then see if it boots. Once again, startup repair does not delete any of your music, documents, pictures, videos or programs. System Restore does not delete any of you documents, music, pictures, videos or programs. System Recovery WILL DELETE all of your music, pictures, videos, documents & any programs you've added since you brought the computer home from the store. System Recovery sets your computer back to the very first time you turned it on after you purchased it. I would run the startup repair, if that does not fix your problem, see if you can run a System Restore. A lot of time the Restore Points are damaged or missing when this happens, but give it a try and restore to a point before you started having the blue screen issue. If all fails you're going to need a system disc so that you can get into the Recovery Console so that you can enter a dos command in the little black box that opens up with white letters. You want to type: chkdsk /r
Let it run. It will run well over an hour and you will notice the percentage of completion going from high to low, but that's ok. Let it run to completion then try rebooting. If this doesn't work, you're going to need to take it to a repair shop or reload the operating system yourself.
Mar 19, 2012 | HP Pavilion Slimline s3600t Desktop PC
Hi I turn on my laptop and it brings me to a black screen that gives me the options to either run windows repair (recommended) or start windows normally. If I run the repair it instantly brings me to that...
Hello!!
1. If you have the windows vista/7 dvd then put it in, boot from it but when it comes to install step , check for the REPAIR SYSTEM option at the bottom,
2. select that option and choose -> startup repair.
3. follow onscreen steps and wait for system reboot.
If everything goes fine it will start but if this doesn't work then you'll be needed to reinstall the whole OS..
P.S. any OEM/Retail Disk will work fine.
Hope it Helps..!!
Jul 13, 2011 | Computers & Internet
Is there another way to have my T3500 run in safe mode other than F8...When I press F8 while my computer is booting up it gives me a blank screen.
If you stop windows from booting up all the way by holding down the power button during the "loading windows" screen, until it turns off. Start it back up and before windows loads it will give you a menu, with options like "start windows in safe mode with networking" or "safe mode with command prompt"
May 03, 2011 | Dell Precision WorkStation T3500/ T5500/...
Windows is not loading have black screen with white cursor then goes to acer and fast out again to white cursor
Hello, doing a "last known good configuration" Works most of the time. Here is how to do it:
1. Make sure your computer is powered down.
2. Turn your computer on and immediately start pressing F8 on your keyboard repeatedly until you see a black screen with white writing that gives you a list of boot options.
3. Use the down arrow on your keyboard to select the Last Known Good Configuration (Advanced) option.
4. Press Enter on your keyboard and cross your fingers.
Good Luck!
Mar 31, 2011 | Acer Computers & Internet
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
I get a black screen saying windows cannot load
Are you able to boot in safe mode?
Are you able to boot from cd?
you may have to reinstall windows.
May 10, 2009 | Acer Aspire One PC Notebook
Windows xp logo will start to load then......
To solve this will require more information from you. The Blue screen is Windows way of telling you that it has a driver issue with a basic component, usually your video card. Did you recently make any hardware changes? If so please let me know what was changed.
When windows first boots, you can repeatedly press the F8 key until you see a menu giving you choices of windows booting. You need to select Safe Mode. Safe mode should allow you to at least boot without a blue screen. The blue screen could also be cause by a virus or other software.
Microsoft has a description of Safe mode here;
http://support.microsoft.com/kb/315222
but here is a quick snippet
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Dec 13, 2008 | Compaq Presario S6000NX (DQ178A#ABA) PC...
Start up problem
option1:- choose the option called safe mode. the first option. just log in and stay for a while in there and restart your computer.
option2:- choose the option start up windows normally.
Jun 18, 2008 | Compaq Presario 700 470024-192 Notebook
Dell Latitude D600 Notebook Logo
246 people viewed this question
Alun Cox
