Question about Panasonic DMR-EZ47V DVD Recorder/VCR
VHS playback - no picture
The VHS was working ok s well as the DVD. Then we experimented with trying to record a program onto DVD. I pressed STOP when finished. There was only sound, no picture. And now when I try to play a VHS, all I get is sound, no picture, and the current Channel number (C26). I have pulled out the plug and reinserted it several times. I learned that from all the trouble we had trying to record. Any suggestions? Thank you.
  • 70 Answers
Do you have a scart lead connected ? if so it is not in properly, and it would not be channel c26, but the av channel on your TV that you would need to be on.
Posted on Feb 17, 2008
Will this model record from the vhs tape to the dvd?
You don't state the manufacturer or model number in your question, thus we cannot answer. I will say that many do, but there is a caveat. If the the VHS tape is a commercially made movie, chances are it has copy protection on it. Most machines will sense this copy protection and will refuse to copy the protected VHS tape to DVD. This was done to prevent piracy. Home recorded tapes and non-protected tapes will usually work ok. Do not confuse write protection with copy protection however. Write protection is merely the tab on the tape that prevents re-recording of the tape. Copy protection is recorded right onto the tape itself and is read by the machine during playback.
Nov 19, 2015 | Televison & Video
Can record on DVD disc will not play on DVD player
Make sure the materials you're trying to record onto the DVD
is not Copyrighted. Try to record a normal TV program onto your
VHS, transfer it to your DVD and then play it. See if that will
work. A VHS movie is usually Copyrighted and Protected by
Macrovision. The picture output can be displayed on a TV set
for viewing but is scrambled black to a DVD Recorder.
Jul 16, 2011 | JVC DR-MV100B DVD Recorder/VCR
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
How do I record a vhs onto a dvd on the combo?
I have researched the manual for this particular device and you will not be able to convert/record VHS tapes to DVD discs. You can however record content from a DVD to VHS tape as this model only has a readable disc player not a DVD burner. Sorry, but you may want to research DVD recorders that also have VHS playback.
May 02, 2011 | Insignia IS-DVD040924 DVD Player/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
VHS to DVD recording
OK connect the AV Out Yellow, Red, White, OR SVHS, OR SCART, from the VCR, connect these leads color to color to the DVD's AV whatever, IN.. Press Play on VCR, and "Record" on CVD that should do it.
Jan 31, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
How to finish a transfer from VHS to DVD?
When you finish recording from VHS then press Stop on dvd recorder and finalize dvd, this option would be available in dvd menu.
After finalization, that burned dvd can be playback on any dvd player.
Apr 19, 2009 | Televison & Video
3-4 switch
1. Set tv to channel 4
2. insert a pre-recorded tape into vcr.
3.press play once to start playback.
4. after a few seconds press play on the vcr for 3 sec you will see a playback picture.
when a picture doesn't appear on the tv screen repeat step 4.
5. press stop to stop playback.
Mar 16, 2008 | Sanyo VWM-950 VHS VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
131 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
