Samsung remote control
I have a samsung TV & remote. My son put the remote in the bath.....GREAT!!
Now it does not work...EVEN BETTER!!!
When I press a button either TV on it or Cable on it flashes or flickers.
Do you know what I can do. Do I need to rest the remote.
Do I need a special code for that.
the code number on the bottom of the remote is BN59-00611A
Please help me. The TV is stuck on ABC with a religious chior.....If I have to listen to any more church music I will find a bridge and jump off...HELP
Thanks Janette
  • skynet048 Mar 08, 2009
    My remote fell on to the floor, and now doesn't respond at all. The up & down volumen and channel bottons are lighted up, but nothing else. I try to set it up again but nothing.
    It only makes something when i press the reset bottom, and bot channel up & down and volumen lightens up
    Any help?
    Kind regards
  • Arunas Oct 11, 2012
    http://www.remotes-store.eu/product.php?...
    Problem Solver:
  • 18 Answers
New remote:
http://www.remotes-store.eu/product.php?id_product=97
Posted on Oct 11, 2012
    Sergeant:
    Champion:
  • 310 Answers
Open the remote and clean it with petrol. And then use it. After that it makes problem means contact me
Posted on Feb 17, 2008
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
Innovage Jumbo Universal Remote Control
try google for code, because there should be directions
Dec 27, 2007 | Televison & Video
I'm having a continued pairing failure with remote on ud55d7000 Samsung. I even tried put it close as on person had suggested but all I get is failure
I had the same problem. The following worked for me and the 46d7000 qwerty remote. Try this: unplug TV. Then press power button until the red led turns off (5 sec or so). One themed is off, plug in tv and power on and try the pairing again.
May 15, 2011 | Samsung Remote Control
Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Apr 07, 2009 | Samsung TV Remote Control
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Samsung TV Remote Not working
get new son would be a choice
Aug 27, 2008 | Samsung TV Remote Control
Tv won't operate off remote control
Unless you had the remote tested by Samsung, the test isn't comprehensive; it will only tell if the remote is putting out infra-red of some kind, that type of tester cannot determine if the codes are correct or complete. The only true test would be one in which you had a second TV or a second, known working remote. Even using an oscilloscope with an infra-red detector wouldn't help unless one had the specific code sequences available, it would only appear as a pulse train.
Aug 18, 2008 | Samsung Remote Control
Sky remote tune to samsung
3. Press tv again
Samsung Code: 0060
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Changing Samsung Remote Codes (2 TV's Same Remote Frequency)
There is NO solution to this problem. I'm an electronics engineer. I have three Samsung TV and IR remote extenders. It is a continual problem. If someone told you could "re-program" the Samsung remote, they must have thought you could write assembly level programming code. There is NO incentive for Samsung to modify their highly popular, simple, cheap remote system.
Believe me, I even tried putting polarizing filters over the IR sensors but the ones for cameras do not polarize light at IR frequencies.
Jul 21, 2008 | Samsung AH5900092W Remote Control
Televison & Video Logo
541 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
