Question about Kitchen Ranges
Digital Range timer/Stove Clock removal / replacement
How do I remove the stove clock on a Fridgidaire drop in electric range?
Do you have any step by step instructions or specs?
The model number for this GE part is 3AST51G208A1F.
Frigidaire uses p/n 8015944.
your help is very much appreciated.
  • runger Feb 17, 2008
    Frigidaire Model REG533MD-0
    S/N 85CK1323
5 Suggested Answers
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
  • 6 Answers
SOURCE: GE XL44 Gas Range JGBC15GER2. Can't see clock on
yes it is called a electronic oven control go to ap wagner.com and enter the model number and you can get priceing
Posted on Nov 08, 2009
SOURCE: Frigidaire Stove clock resets to 12:00 when igniters turned on
I have the same problem. This is an intermittent problem, maybe once every 20 to 30 starts the clock goes resets and the appliance beeps just like if unplugged it and then plugged it in again. I’m an electrical engineer and this sounds like the microcontroller that runs the appliance is being reset by noise caused by the spark igniters. This is definitely a design problem. Separating the wiring of the igniters and the control board should help. When I get a chance I’ll have to connected an oscilloscope and look at the noise. The control board microcontroller reset pin probably needs an RC snubber or an isolated ground. If /when I find something more definite, I’ll place another posting.
Posted on Jan 18, 2010
taran_2005
  • 10515 Answers
SOURCE: Electric Range Frigidaire Professional Series
The last expert is correct.
According to the Frigidaire technical documentation, most likely the cause of the problem is a bad Electronic Oven Control (EOC).
Check the wire harness and the P4 connector at the EOC. If the wire harness and the connector are fine, replace the EOC
You could try to disconnect the power supply for few minutes, say 15 minutes and see, if that could help the situation unless you need to replace EOC/Clock/Control board.
I don't think it is sensor as this is a common problem on these units and 99% it is faulty EOC.
Let me know,if needed further assistance.
Note - Kindly perform the repair, if you have prior appliance repair experience. These ovens are quite dangerous to work. It could not only damage the oven but could also harm you,if done in an appropriate way.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 18, 2010
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
How to disconnect beeping hotpoint stove digital timer/clock?
Good Afternoon Patti,
I understand that your Hotpoint stove digital timer/clock is beeping and you are wondering how to disconnect it. I suggest resetting your stove by either unplugging it or disconnecting the power at your home's circuit breaker for 3-5 minutes. When power is restored, if your stove is still beeping, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what the cause of the beeping is. They will also be able to assist with repairs, if needed. Hope this is helpful.
-Best Regards-
WP
May 06, 2014 | Frigidaire FEF336BC Electric Kitchen Range
Elements work but both ovens and clock face are off
Reset breaker or unplug and restart stove. Open back of stove to clock face and make sure the harnesses are tightly fitted to clock board. You could even remove and reinstall the harnesses to the clock board.
If able, check for 120v to clock. If clock is getting power but not lighting up, replace clock.
You did not say whether the clock controls the oven; ie. oven does not work when clock is off. if so, replace clock. If not, ignore it unless you want to know the time from that clock.
Oct 20, 2013 | Maytag GeminiĀ® MER6765BA Electric Kitchen...
I want to turn off the clock on the stove
i want to turn off the clock on my whirlpool stove
Jan 06, 2010 | General Electric Stove/Oven/Range Chrome...
Clock on Whirlpool Stove
Check to see if the oven is set to timed bake.
Jan 22, 2009 | Whirlpool GR460 Electric Kitchen Range
Cannot reset clock on my electric stove after a power failure!
Unplug the stove for 10 minutes, then plug it back in.
This should resolve your problem...
Nov 20, 2008 | General Electric Stove/Oven/Range Chrome...
Amana gas stove acf3325ac f2 code
HI The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
PLEASE RATE IT............................
Nov 16, 2008 | Amana Ovens
Oven not heating to proper temp
go to: RepairClinic.com
you'll need make & model #.
Nov 16, 2008 | Frigidaire Ovens
FRigidare new stove installation
Loud pop means electrical fault occured. There may be and internal fuse in the oven that blew. Probably blown oven element but certainly open circuit to timer. Remove back, check for supply to oven timer. If supply is there, the timer can be bypassed to allow for oven element to work as clock replacements are very expensive.
Nov 09, 2008 | Frigidaire FEF355 Electric Kitchen Range
AMANA STOVE
you have an electric problem that it can be from lightening or replace the clock. so u must be sure that gas valve working mostly it must be 24 volt . if u haven't electricity on gas valve check the high limit switch if there is a combination u must change valve
Mar 10, 2008 | Amana RanARG7302 Gas Kitchen Range
Kitchen Ranges Logo
658 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
