When I try to print a document I keep getting this message: fatal: Opening Printer Connection Failed: Unable to open the printer connection. Please check your printer connections and check for printer errors... But when I print a test page from my computer it works perfectly! I'm confused because everything is connected as it should be. I've installed and uninstalled the printer twice, still no joy. I'm using a new MacBook Pro with snow leopard. Printer is about 5 years old.
It is seen that if there are any issues with the printer drivers, issues like connection failure may occur. There are chances of drivers being outdated and corrupt. In such situations, you have to update the drivers. If there is any yellow exclamation mark next to printer driver, You need to replace that corrupted driver with the correct one. Before the installation, you also need to check for compatibility. Sometimes, incompatibility would cause issues like printer connection failed, etc.
Get more information and help to fix Printer Connection Failed . Hope this information helps you.
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
