Question about Sceptre X5G-Komodo IV 15" Flat Panel LCD Monitor
Monitor Powers off after a second or two.........
My Sceptre Xg5 Komodo just stays on for a second or two and then goes black.......Displays accurately for that amount of time. Cut it off and back on......Same thing. LED indicator is on when it goes out. Any Ideas?? Thanks to all who take the time to answer.
  • 2 more comments
  • remcon Feb 23, 2008
    kishkane, Thank you for taking the time to answer. I replaced a bulging a 470 uf Capacitor which I thought might be an obvious problem, but to no avail. (I think that I smell that noxious electronic "burning smell", as if it burned out.) Still comes on and off the same way. Something I did not notice before, is that you can see the display, after it goes out, with a strong light!! Hummm...... Also, is the "8-pin chip" that you're refering to be like a 10 or 12 leg IC chip? Again thanks for your time, remcon
  • kc5mah Mar 09, 2008
    i have the same problem.. was the problem solved if so ??how??
  • kbradleyjr Dec 29, 2008
    I have the same issue...
  • Dave Burton May 14, 2009
    Sceptre 19" X9G-Komodo II LCD monitor comes on for about 1 second, then goes off... also has a noticable burnt smell. Turn it off with the power button, then turn it back on, and the normal display comes back on for another 1 second, then goes off.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sceptre Master
  • 848 Answers
My Sceptre Xg5 Komodo just stays on for a second or two and then goes black.......Displays accurately for that amount of time. Cut it off and back on......Same thing. LED indicator is on when it goes out. Any Ideas?? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
Sceptre LM004 Power Supply Backlight Inverter for X9G KOMODO
Posted on Mar 22, 2015
    New Friend:
Look for bulging ends on can shaped capacitors. The most common one is 470 Uf. I replace them with a slightly higher voltage rating, like 35V instead of 25V. The new ones are only slightly larger, and fit quite well. This solved my problem on about six of these monitors I have had go bad. Right now, It seems that someone in the factory put 1200 uf capacitors in two of the four spots. I am in the process of replacing all of them with new 470 uf capacitors. The repair kits you buy online do not use higher voltage rating capacitors, but I have been doing it and never had another one go bad.
Posted on Jan 02, 2013
  • paul Claeyssens Jan 02, 2013
    look for bulging ends on can shaped capacitors. The most common one is 470 Uf. I replace them with a slightly higher voltage rating, like 35V instead of 25V. The new ones are only slightly larger, and fit quite well. This solved my problem on about six of these monitors I have had go bad. Right now, It seems that someone in the factory put 1200 uf capacitors in two of the four spots. I am in the process of replacing all of them with new 470 uf capacitors. The repair kits you buy online do not use higher voltage rating capacitors, but I have been doing it and never had another one go bad.
    these capacitors are available on ebay for reasonable prices
    Problem Solver:
  • 6 Answers
Well, that was easy.
Inside my Sceptre 19" X9G-Komodo II I found two bulging 25v 470uF electrolytic capacitors on the power board.
I didn't have any new 25v electrolytics, and I was in a hurry, so I scrounged around in my scrap heap, and found an old 9600 bps modem with a pair of 25v 470uF electrolytic capacitors in it, and replaced the bad ones in the monitor with the ones from the old modem. The monitor is working fine, now.
So, if you find any bulging capacitors, replace them. Also, replace any others of the same type & size (they are often in pairs), since sometimes they go bad without bulging, and if one capacitor of a particular size & type is bad then both of them probably are.
(If you don't know what I mean by "bulging capacitors," google for "badcaps.")
Posted on May 14, 2009
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Sceptre X42GV-Komodo 42 in. LCD TV no picture no sound but splash screen displays good
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 22, 2014 | Sceptre Televison & Video
Sceptre Monitor P/N X7G-Komodo II displays for about 1 second at a time, then goes black. When I cycle monitor power, I see a perfect display for 1 second. Does anyone have a recommended solution?
When the backlight does not stay on for more than a second, the problem is usually the backlight power supply board failure. Typical failures are blown capacitors, or transistors. A electronic repair shop should be able to fix it.
Oct 05, 2010 | Sceptre X7G Komodo II 17 in. Flat Panel...
Screen comes on for 1 second then goes out
guychristian, here are some good clues!! www.ccl-la.com/badcaps.htm and www.badcaps.net www.lcdparts.net www.ccfldirect.com and also visit youtube for videos of LCD monitor disassembly and LCD monitor repair. Read my profile on fixya for more options that you might want to persue. Remember this!! Your monitor isn't any different than any other brand!!!!! It can be fixed! how you do it is up to you to decide. 12fixlouie
Dec 15, 2009 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Same problem here
My Sceptre Komodo 19 would turn on for less than a second than turn off. Eventually, I could get it to stay up. But after a month, I couldn't get it to stay on anymore.
I found the solution on this website. There are some bad capacitors... 4 of them for about $2 worth. I replaced all four and the monitor works fine again. They are soldered in. They are polarized; they need to be installed the right way. The white stripe goes towards the “wall”.
2 are 470uf 25v and 2 are 1200uf 10v.
I ordered mine for about $10 with shipping from Mouser.com
661-EKZE250ETD471MJ1 and 647-UHE1A122MPD
Oct 04, 2009 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X32GV-Komodo keeps turning on and off
I replaced my own part and it works as new again .Go to ( Power-On.com )Look up part #LCD225-6M Power supply it only cost $65.00 and ups shipping was $10.46 2 day later I got it and 15 mim. later we were watching TV again
Mar 15, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
No picture on my x5g-komodo7 monitor
A reddish picture is the classic symptom of worn out backlight bulbs.
Sensor circuits usually shut down the power to the bulbs in a second or so.
Monitor Mike.
Jan 03, 2009 | Sceptre X5g-Komodo VII 15'' LCD Monitor
Sceptre LCD - no display
I have same problem... just went off warranty and they won't cover it.. they want $100 for repair plus $35 shipping plus I have to pay to ship it to them... For $179 I can buy a new 19" with 3 year warranty...I wouldn't buy another Sceptre at half the price
Jul 13, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Same Flashing Problem
Jul 06, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G Komodo IV 19 in
check out any dry solder or burnt and re solder it , hope it helps AJ
May 03, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G Komodo IV 19" Monitor
Hi dgp1952, Check with www.lcdrepair.net if you want a repair. Something is wrong with your backlight or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. Dust can cause the circuitry to heat up faster and put the power supply into Clamp mode. Clamp mode will turn the supply off to certain circuits which may be the reason your display is going black after 5 minutes.
Oct 09, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X5G-Komodo IV 15" Flat Panel LCD Monitor Logo
234 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
