Mitsubishi 1080 LP HDLP TV
Unit is shutting down for overheating. Message says to check for blocked air flow. No blockage found. If I knew where the heat sensor was I could probably troubleshoot it.
  • rshep23 Nov 26, 2008
    The TV picture cuts out but the sound stays on. The blue power light stays on also. I was told it could be the remote sensor in the TV.
  • Grizzly44 Jan 27, 2009
    My Pioneer PDP 4216HD does the same thing. If I change the channel up or down, it comes back on, or if I turn it off and then back on, it works fine. The signal strength is good and the problem iks intermittant.
Tv screen goes blank but still have sound
Posted on Mar 04, 2008
"TV will shut-down in afew seconds. Please check
Thia is a indication that the unit is overheating. Now the causes of this can be a cople things... the fan may have slowed or may be cloged.. In the past there have been instances were a faulty temperture sensor or thermal switch might cause this. I have replace many of these sensors at the shop. Mitsubishi has issued service bulletens on this problem. THere not difficult to get replace and are about 75 dollars to replace(at our shop)
Mar 06, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Air flow is blocked
In the 65" TVS there are 4 or more fans One of these is not functioning Probably the one over the power supply itself This will cause it to heat very quickly and shut down in a matter of about 20 seconds.
only way to find out which fan is not working isw to remove the back.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Mitsubishi WD-65731 65" HDTV
I get a message that the air flow/fan is blocked, then the tv shuts down. It's not blocked. It's perfectly clean.
This indicates the TV is overheating. Lamp based TVs usually have two or even three fans. One may be having problems or not turning fast enough.
Mar 31, 2010 | Televison & Video
Error Message
If the set is only 3 1/2 months old, you should still have warranty coverage. Opening up the unit will void the warranty, so don't open up the set. Call for warranty service. In all probability, the air flow sensor is defective. The message you are seeing is a result of the air flow not being detected or not sufficient. In any case, this is a covered problem and should cost you nothing to fix.
Dan
Mar 20, 2009 | Mitsubishi WD-Y65 65" HDTV
52' DLP Mitsubishi HD T.V. gets an error message on the bottom of the screen ''T.V. will shut down. Check that air flow is not blocked'' T.V. is in the open and air flow is not blocked. There is also a...
most rear projectors will turn themselves off whenever the lamp is dead. what we call protective mode. in this case the yellow light may be for the lamp. otherwise check if all the fan are working properly.
But MAKE SURE you let sufficient time for the tv to cool off before unplugging the main.
hope this helps
please rate me!
Mar 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubushi 1080 HDTV has an air flow block
There is a fan in the back. Make sure that the fan is spinning and that the grille is clean. It is possible that the sensor is bad too.
Keep us posted.
Dan
Jun 06, 2008 | Televison & Video
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-65831
contact mitsubishi customer relation at (800)332-2119..there is a service bulletin on this problem and mitsubishi has extended the warranty for repairing this problem for 2 years
Oct 28, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Error Message
. Set shuts off after displaying the message "TV will shut down in a few seconds. Please check if the air flow is blocked." After shutdown, it may have a yellow status LED, self diagnostics indicates error code 38. To repair, replace the Lamp Thermal Sensor with the new version, part # 299P313010A. The sensor is located on the Lamp Cartridge Housing. See Service Tip VS-72B. Under rare circumstances, when a replacement thermal sensor is not available, refer to the original Service Tip, VS-72 (page 2 and 3 of VS-72B) If error 3-4 then this maybe problem:. Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049010
Aug 22, 2007 | Mitsubishi WD-57732 Projection Television
Televison & Video Logo
603 people viewed this question
Top Televison & Video Experts
