Question about Panasonic NN-S561 Microwave Oven
What cause the wattage difference?
Have 2 panasonic microwaves: NN-S532 and NN-S542. I want to use 1 to repair the other. 1 is 1200W. The other 1300W. Same Invertor board & Magnetron part numbers. So what make the wattage different?
  • RockieEstes Feb 18, 2008
    SHARCNET: The fans and all components are the same, except the keypads! They are different and have a few small components onboard that probably do, as you said, make a higher power selection on the 1300 W unit, that the 1200 W keypad does not offer. Like AMD does with one cpu design sometimes. They leave a bridge open on one and closed on another and sell it as two different power models. Thanks!!
  • 2,130 Answers
Wattage is based upon voltage & current. I would think that on the 1300W unit, either the voltage or the current is higher than that which is used on the 1200W unit.
Perhaps the magnetron in the 1300W unit is being driven harder. Are the fans the same size?, The magnetron in the 1300W could be running harder and they have a larger fan in it.
In any event, if the part numbers are the same, you should have no trouble using one units parts to fix the other.
- Jim
Posted on Feb 17, 2008
Panasonic nn ct776 invertor/magnetron
Not really. Best to compare against a good one.
Nov 16, 2013 | Samsung MT1066SS Convection/Microwave Oven
Microwave fuse keeps blowing on my Panasonic Microwave NN-9854P
I would check the door interlock switches and then if that doesn't fix it replace the invertor board and possibly magnetron.
Feb 21, 2011 | Panasonic NN-P295SF Microwave Oven
Panasonic Microwave Oven NN-S262BF It starts to run and stops after 3-5 seconds
The problem sounds like it is in the keypad controller, behind it there is a microprocessor with additional parts that work in conjunction with the hardware, if there are issues there the cost to repair would not be justified, better option is to replace.
Jan 31, 2011 | Panasonic Microwave Ovens
Our s333 panasonic microwave stops working after 1 second?.. it just shuts off?? can you advise?
It probably requires a new magnetron or an invertor board or both. Take it to an authorised Panasonic repair agent for an estimate for repair.
Jan 24, 2011 | Panasonic NN-T694SF Microwave Oven
H97 fault code on a micro wave. What is the estimated cost to fix? Is it cheaper to buy a new one?
Either te magnetron has failed or the invertor has failed.
How long is a piece of string.
Ask a Panasonic Authorised Repair Centre for an estimate.
Jan 07, 2011 | Panasonic NN-S541 Microwave Oven
Our Panasonic "the Genius" Model No. NN-S562WF 1200W Microwave has the following problem: We set it for the required minutes, it goes for about 40 seconds then stops - there is no heat happening at all.
hi that is one of 2 possible faults it is either the magnetron or the invertor board (panasonics "great idea" of replacing 3 simple more reliable components (transformer capacitor
Aug 30, 2010 | Panasonic Microwave Ovens
Panasonic genious sensor inverter 1300w nn-t664sfx displays code "h98" & will not run - what's the problem?
Mine did this once and it was the magnetron. Once replaced, it worked fine. Repair is an option if it is still under warranty or someone will do it on the cheap. Otherwise, just get a new microwave, since this is the main part.
Oct 04, 2009 | Panasonic NN-S960WA Microwave Oven
Microwave turns off by itself after being on for 3 seconds
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see and
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Mar 03, 2009 | Panasonic NN-S532 1200 Watts Microwave...
Panasonic Model No. NN-S933BF Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Panasonic NN-S561 Microwave Oven Logo
159 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
