Question about StarTech.com PCI Post Diagnostics Test Card (PCIPOST) System Diagnostic Device
2002 Pontiac sunfire running lights
I'm working on a 2002 pontiac sunfire. The daytime running lights are not working, The highbeams work but not daylight. I've checked all fuses and wires. Can't find a wire diagram on this and wondering if you know
  • 4 more comments
  • hmountain13 Feb 18, 2008
    I have a 2003 sunfire slx, and my running lights flash on and off when in gear. It started off with my right headlight always being dim. i replaced the bulb and it did nothing.
  • Anonymous Mar 29, 2008
    1998 Pontiac Sunfire daylight running lights don't work. The signal on the dash flashes and sometimes it makes a clicking noise when I start the car.
    daylight running lights do not work. The dash light flickers and sometimes makes a clicking noise when I turn the car on. It is a 1998 Pontiac SunFire. I would like to know what I should look for first to fix it
  • zubairansari Jan 26, 2009
    I have a similar issue with my 2001 Sunfire SLX. When I turn the ignition ON, it passes the self test but when i put it to drive I see the daytime light indicator for 1 or 2 secs then it goes on/off (oscillate) few time until it completely goes off and SERVICE light comes up! This doesn't happen if i turn the night lights on and put it to drive. But as soon as I turn the night lights OFF same problem observed. I dont know whats wrong with the daytime light. Can anyone please help.
  • Anonymous Feb 03, 2009
    I have the same problem and I'm going to check the relay first as that is what makes the clicking noise.
  • SunfireDrive Mar 07, 2009
    Same thing - the lights were working just fine until I brought my car into the shop for another problem. The mechanic called to let me know about the problem, but said they tried everything and couldn't fix it.
  • 4 Answers
Had similiar problems with my 2001. Check the entire length of the headlamp wiring harness under the hood behind the grill. They are prone to corrosion from road debris etc. Peel off the tape and follow thw wires. I'll bet there will be a broken one. Pay particular attention to the pink one. Just clean up the broken one and fix it with a **** connector and you should be good to go. Hope this helps.
Posted on May 16, 2009
There is a wiring fault for sure and it is the harness, my experiences have taken me to the harness were it goes behind the washer fluid tank and up over the frame rail, the harness corrodes and the wires break there because they are under strain from body movement.
Posted on Feb 24, 2010
I need help locating the drl microprocessor in my 2001 Pontiac sunfire
Pontiac Sunfire Questions - Daytime Running Lights ...
www.cargurus.com > Questions > Pontiac > Sunfire
CarGurusJul 22, 2009 - Daytime Running Lights - Relay clicks and then DRL shuts down. ... housing piece, but I couldn't seem to find any store or dealer to locate the specific part. ... The same EXACT thing is happening in my 2001 Pontiac Sunfire.Missing: microprocessor
Where is the DRL Module on a 2003 Sunfire? - Fixya
www.fixya.com/cars/t2791740-drl_module_2003_sunfire
Aug 24, 2009 - My wife's 2003 sunfire has a problem with the day time running lights and ... Your instrument cluster has a microprocessor which energizes the relay. .... Daytime Running light Module and relay on a 2001 Pontiac Sunfire GTX ...
DADRL - How To Disable DRLs
Jan 08, 2016 | 2001 Pontiac Sunfire
Low beam headlight not working on 2002 sunfire
Your problem is in the wires for the lights, The connectors all corrode from water etc. I pulled the wiring harness and replaced all connectors and sealed with liquid tape and when dried with normal electrical tape. Repair took about 6 hours.
Mar 02, 2013 | 2002 Pontiac Sunfire
1998 pontiac sunfire problems/ speedo.RPM.and daytime runnig lights will not work
smack the dash just above the instrument panel while driving
Feb 16, 2013 | 1998 Pontiac Sunfire
My 2004 pontiac sunfires headlights malfunction
have your mechanic check the daytime running light relay and control module as failure is common.
Dec 26, 2009 | 2000 Pontiac Sunfire
Drl and high beams dont work
Check the bulbs -- the daytime running lamps use the highbeams on the resistor -- There are two filliments per bulb one high; one low. If both high beam filliments are out nothing will work....replace bulbs if this is the case.
Aug 02, 2009 | 1999 Pontiac Sunfire
Pontiac sunfire 1999
Three things .. is the bulbs bad ? or is there a bad relay under the hood in your powerdistribution box.? or is there a ground wire loose near the headlights ? this has to be your problem one of these ideas.. holler if you need more Jerry
May 20, 2009 | 1999 Pontiac Sunfire
StarTech.com PCI Post Diagnostics Test Card (PCIPOST) System Diagnostic Device Logo
1,149 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
