Question about Onkyo TX-SV414Pro Receiver
Display The display on receiver is all "jumbled". The #16 indicator is showing "hall" & won't change. Yet it still seems to work OK with the remote. I tried unplugging, turning off etc & it just won't reset itelf.
  • kayjet001 Feb 17, 2008
    We are hooked up to satellite TV so no cable TV box?
    I still have the manual & already tried the troubleshooting steps. I will call Onkyo & see what they say. Thanks for the number.
    Genius:
  • 3,422 Answers
Click HERE for the manual go through it there are some troubleshooting steps it may help you fix the problem.
Here is the main support no. of Onkyo 201-785-2600
Goodluck..
Posted on Feb 17, 2008
  • Priya darshan Feb 17, 2008
    Your welcome..
    Please don't forget to rate me as fixya..
  • Onkyo Master
  • 19,396 Answers
Did you try restarting the cable box?
I have a Pioneervsx-1021k AV Receiver and all the buttons were working fine until I decided to play with the remote. Now some of the buttons light up, and some don't. I have found that not being able...
Hello
Just reset the system and try. So many external commands may confuse the system control IC inside, will hang up very like our computer systmes do. Resetting it to factory settings will make the unit work well. To reset the system:
Disconnect the iPod and USB memory
device from the receiver beforehand
1# Switch the receiver into standby.
2# While holding down ENTER on the front
panel, press STANDBY/ON.
The display shows RESET .
3# Select 'RESET' using PRESET then
press ENTER on the front panel.
The display shows RESET? OK.
4# Press ENTER to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory default settings.
Note that all settings will be saved, even if
the receiver is unplugged.
If this process does not help you, your system needs service with its main system control circuit. Actually this is a very skilled job, and should be done either by any well experienced service technician or by the Authorised Service Center for Pioneer at your town. OK.
Aug 21, 2011 | Pioneer VSX1020K Receiver
Hi, I have a Yamaha rx-v450 amp that won't change sound modes (stereo, hall, jazz, rock etc) from the remote control but it works from the buttons on the unit. I've checked my remote by pointing it...
Hi! Transmitting doesn't mean it's working, What you should do to test it is use a good quality universal remote such as a Logitech Harmony and first program the preset code for your receiver into the Universal Remote. If that works, you know your OEM remote has gone bad, at least for those buttons. If it doesn't then you you should attempt to have your Universal Remote "learn" the IR signals from your receiver's remote If the controls still don't work, there is a problem with either your IR receiver on your receiver or the the circuitry that proceesses the signals into commands. Good Luck!
May 11, 2011 | Yamaha RX-V450 Receiver
I have a Yamaha RX-V467 receiver, and am wondering if there is something wrong. Before mounting the surrounds on the wall, but after using them for a few days (in both instances using the Rocketfish Rear...
It sounds like you digital assignments are either hosed or not working. Most AV receivers will TRY the digital path first and drop to an analog path if the bitstream is absent or corrupt. Upon restortation it might switch back automatically.
Treat it like a new installation and thumb through the manual and settings.
Mar 29, 2011 | Yamaha RXV467 Receiver
I have a Sony CDP-CX350. I recently discovered the remote will not control anything on the player. The remote has fresh batteries and displays that a signal is sent out. The same display usually shows...
If you have turned it back on then this would indicate the receiving module that picks up the infrared signal is not working and has become defective, but I would double check your manual so nothing was over looked.
Jan 30, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Twice now my Pioneer VSX-819H has shut down. Can not get any power to it. The first time I'm sure the phono pre-amp caused a surge. I no longer have it hooked up. The servicer said nothing was wrong and...
I found this for the VSX918, 818. Perhaps it's similar.
The power does not turn on. • Disconnect the power plug from the outlet, and insert again.
• Make sure there are no loose strands of speaker wire touching the rear panel. This could cause the receiver to shut off automatically.
The receiver suddenly switches off and the power indicator
blinks.
• After about a minute (you won’t be able to switch the unit on during this time), switch the receiver back on. If the message persists, call a Pioneer authorized independent service company.
Resetting the main unit
Use this procedure to reset all the receiver’s settings to the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the ADVANCED SURROUND button, press and hold the
STANDBY/ON button for about three
seconds.
3 When you see RESET? appear in the display, press ‘
ST –’. OK?
shows in the display.
4 Press SOUND RETRIEVER to confirm.
OK
appears in the display to indicate that the receiver has been reset to the factory settings.
Mar 02, 2010 | Pioneer VSX-819H-K A/V Receiver
Lock remote stopped working. changed baterry, tried to reprogram as per manual nothing works
some auto parts stores have a display at the counter where they sell new remotes or fob's. The display has a sensor that lights up when you use your remote. Point the remote at the display and press any button if the light comes on your fob is likely ok. may need to check the receiver. good luck
Nov 30, 2009 | 2002 Ford Explorer
How do I change the time on the display on our Nortel phone system?
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming2.gif mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___" 18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Nov 02, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
114 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
