If you cannot turn the front wheels and the steering wheel was vibrating before then (since I assume that the car is undrivable now), then your car most likely has broken/damaged tie rod: check if the front wheels wobbles.
A less common problem is the actual steering/wheel rack-pinion gearing mechansim is broken and it is indicated by not being able to move both the front wheels together.
In both case, you need specialist repair.
Hope it helps.
