Question about Jetway M1931TDB (Gray, Black) (Silver, Black) 19" LCD Monitor
M1931TDB 19" LCD
My LCD started flickering. constant noise is coming from speakers. I tried muting the speakers but Lcd still flickers. Eyes feel tired after 30 min. Any Ideas if this can be fixed without sending to jetwaycomp?
  • linuxboy Feb 20, 2008
    I lucked out, found out the LCD is still under warranty. Charged $25 for "S&H". Glad I do'nt have to crack it open. Thx for the help.
  • carmeneq1 Aug 13, 2008
    I had the same problem with noise coming from speakers. Finally the monitor would not stay on. I goes on for a second and goes blank.
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Hyundaip90wu screen flicker
Unfortunately, unless you are an electronics expert, getting this fixed may cost you more than getting a new monitor. If it is under warranty, contact where you bought it. One thing you could do is try this monitor on a different machine, but I think it would still flicker.
May 02, 2014 | Hyundai P90WU 19" LCD Monitor - 5 ms 1440...
Lcd screen is flickering on and off very fast
Disconnect the lcd from the computer. Turn on the LCD and see if it still flickers fast. If it doesn't then go ahead reconnect the lcd back to the computer. If its still flickering, then go ahead and hook it up to another laptop or desktop. If it doesn't flicker on another computer then that means there is a problems with the video card on the original computer.
If it still flickers then that means the lcd is bad and would need to be replaced.
May 31, 2011 | LG L1960TR 19" LCD Monitor
I got a Gateway LCD 900G monitor, it keeps flickering and making hissing noises, what can i do?
Flickering could be a loose power connection but the hissing is indicative of a potential short. for your own safety, I'd get this to a TV type repairman asap.
Dec 25, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Envision 19" Widescreen Flat-Panel LCD Monitor It just started I have lines that flicker across the screen.How do I stop that it is driving me crazy.
Is there any speaker sets near the monitor or electromagnetic devices near the monitor?
Generally the flicker is caused by some external devices.
Mar 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
Does this monitor have built in speakers?
yes this monitor does have 2 x 3watt speakers inbuilt
Jun 23, 2009 | Jetway M1931TDB (Gray, Black) (Silver,...
Proview fv-926afw 19'' LCD flickers and buzzes
If you have a capacitor tester.. i'll be much better at least you would know which caps that actually failing..
I would replace all the caps if you dont have the tester.. and while your at it. try to resolder connections and some parts like transistor etc.. maybe they have "cold solder"
May 04, 2009 | Panasonic Computers & Internet
Philips 17 inch 170s4fg lcd monitor,display flickering
I have Got one philips 170S lcd monitor. Iam having flicker peoblem and my display not stable. pls, give me ur best solution for the above problems.
Jan 10, 2009 | Philips 170S4FG 17" LCD Monitor
I have a Toshiba Satellite P100 laptop which I bought in New Zealand. I think the model comes from the USA. Part of my screen is flickering. It runs vertically from the top to the bottom of the screen and...
Good morning, Kevin!
Sounds like an LCD problem. You can verify this by hooking up an external monitor. The external monitor will probably show a good display.
After verification of the problem,you may want to try to replug the LCD cable at both ends, just to see if that corrects the situation.
If that resolves things, all is well and good. If not, you may need a replacement LCD.
If the external monitor shows the same display, you may have a motherboard problem.
Hope this information is of some help.
Ron-
May 09, 2008 | Computers & Internet
Blueish flickering
Try to put speaker distance from monitor.
Try to remove the display card and fixed it again.
Then boot up your and see .
Apr 21, 2008 | Acer AL1913 19" LCD Monitor
LCD screen 'flicker'
Try setting the video output option to NTSC (if it's on PAL). I know this sounds funny, but I have heard some rumblings about this option somehow creating a LCD flicker. If it doesn't work, I apologize in advance for wasting your time! My camera is on NTSC and I haven't seen any flicker on the file numbers on the LCD.
Sep 19, 2005 | Nikon D2H Set Digital Camera
Jetway M1931TDB (Gray, Black) (Silver, Black) 19" LCD Monitor Logo
117 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
