Computers & Internet Logo
Posted on Jan 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shutdown.exe.initializi ng failed - Computers & Internet
dougmpage
Level 2:
New Friend:
  • Expert 86 Answers
  • Posted on Jan 28, 2010
dougmpage
Expert
Level 2:
New Friend:
Answers
86
Questions
0
Helped
32894
Points
241
You can run RegClean from Microsoft or try Windows OneCare's online scan to check for any registry problems.
Problems like this are usually caused by a software install that's messed up the registry somewhere. The above may help fix it.
1helpful
Hi! i am trying to detect a problem in my sony model HCD-GZR777DA when switch it on, after waiting it display c 31 00. where to start please help
31: DPD offset adjustment error .
Contact any service technician. You can't repair this. The error code list to this set:
The meaning of error code is as below:
01: Communication error (No reply from syscon)
02: Syscon hung up
03: Power OFF request when syscon hung up
19: Thermal shutdown
24: MoveSledHome error
25: Mechanical move error (5 Changer)
26: Mechanical move stack error
30: DC motor adjustment error
32: TE balance adjustment error
33: TE sensor adjustment error
34: TE loop gain adjustment error
35: FE loop gain adjustment error
36: Bad jitter after adjustment
40: Focus NG
42: Focus layer jump NG
51: Spindle stop error
52: Open kick spindle error
60: Focus on error
61: Seek fail error
62: Read Q data/ID error
70: Lead in data read fail
71: TOC read time out (CD)
80: Can't buffering
81: Unknown media type
Are you confident to do anything with these error displays.
If you wish to get some details; check the site linked here. Pull up older posts.
tip
Create Desktop Shutdown/Lock/Restart/Hibernate Shortcut Icons In Vista
1. Right click an empty area of your Desktop
2. Select New>> Shortcut
3. In the text box titled: "Type the location of the item:" Enter the Command for the particular shortcut you would like to create. I've listed all of the commands below that activate their respective shortcut:
Hibernate rundll32.exe PowrProf.dll,SetSuspendState
Lock Rundll32.exe User32.dll,LockWorkStation
Restart Shutdown.exe -r -t 00
Shutdown Shutdown.exe -s -t 00
Sleep rundll32.exe powrprof.dll,SetSuspendState Sleep
4. Once you've entered the command, click "Next"
5. Vista will now ask you what you would like to name your shortcut. I've always just given it the name of its function (EG: Shutdown or Shutdown System).
6. Once you have named you shortcut, click "Finish". Your new shortcut will now reside on your Desktop. Simply double click the icon to activate the command.
Note: If you do not like the look of the "default" icon that Vista has given it, you can change the icon to a different one. Here's how:
1. Right click the shortcut icon
2. Select Properties
3. The shortcut properties window will now be displayed. Click the "Change Icon" button.
4. The "Change Icon" window will now appear. Here, you can select from the many available system icons. Click the icon that you would like to use as your shortcut icon and then click OK.
Your Desktop shortcut icon will now revert to the selected system icon.
That's it! Have fun!
on Oct 08, 2010 • Computers & Internet
tip
Here's how to create a shutdown shortcut on your desktop
Instead of going to the start menu, choosing shutdown, then waiting for the computer to shut all the programs down, you can create a shortcut on the desktop to do it quickly. You can create a shutdown, restart, or a logoff icon on your desktop which will work a lot quicker than using the usual buttons in the start menu.
1. Go to your blank desktop
2. Right click on a blank space and a menu will appear
3. Choose New from the menu
4. Then choose Shortcut
5. Where it says type the location of the item type in shutdown.exe -s
6. Then press next
7. Now enter a name for your icon. Mine is called SHUTDOWN NOW
8. Press next
9. The Shutdown shortcut will be on your desktop
Different combination you can type in when creating a shortcut to shutdown, restart, or logoff.
Shutdown.exe -s
Shutsdown your computer in 30 seconds and will close all programs and ask you to save all work.
shutdown.exe -r
Restarts your computer in 30 seconds.
shutdown.exe -l
This one will logoff your computer back to the welcome screen where you will need to login again.
shutdown.exe -s -t 1
Shutsdown your computer in one second. the -t 1 tells it how long to wait. (one second in this case) You can put -t 10 or even -t 1120.
shutdown.exe -s -t 15 -c "Goodbye you idiot"
This is my favorite code. It will shutdown in 15 seconds and have a message in the box saying "Goodbye you idiot"
The -c "bla bla bla" stands for a comment.
Notes:
* to stop the computer from shutting down type shutdown /a into the run box located in the start menu..
* -f will force everything to close immediately without asking to save anything.
on Jan 29, 2010 • Computers & Internet
Will not boot
If you dont have the option to run:
"Windows XP Recovery Console"
You probably have to install windows on a second PHYSICAL drive, Disconnect the failing one first!
Reconnect the failing drive in slave mode.
1. Start/Run "cmd.exe"
2. execute "chkdsk /F /R /X D:"
3. Shutdown
4. Swap drives.
5. Start system (while praying :) )
Have HP mini notebook. everytime im on the
Sounds like spyware / malware i would use an online scanner like Eset or a program like Malwarebytes.
also to stop the computer from restarting open the command prompt window (start menu, click run, type cmd, click ok...) type "shutdown.exe /a" without the "" and there is a space between exe and /a this will abort the shutdown.
Solusyon
I-download ang cCleaner at patakbuhin ang registry cleaner bahagi ng programa. Ito ay maaaring ayusin lamang na error. Dito ay ang lokasyon para sa pag-download,
http://www.ccleaner.com/ccleaner-20
Inaasahan na ang maliit na boses sa iyong ulo ay masaya at na ito ay gumagana ng mabuti para sa iyo.
Paki-iwan ang rating, salamat mabait
1helpful
Dell model DHM DESKTOP which is stuck while plug in .
Try this out:
1. Hold down the Start (Windows Flag Key) button on your keyboard and press R
2. Type this Command : shutdown.exe -s -f -t 00
This will shutdown all running programs and shutdown windows Instantly.
Optionally you can create a desktop shortcut to do this automatically. Here is how:
1. Right click on any blank space of windows desktop -> New -> Shortcut. A “Create Shortcut” window will open.
2. In the blank, type in:
It means, shutdown and wait for Zero second. Click “Next” button for next step.
3. Type in whatever name you like in the blank. I use “Turn Off PC”. Then, click “Finish” button.
4. You are finished . A new shutdown shortcut has been created on your windows desktop!
Just click on it to shutdown.
3answers
Abnormal Shutdown of windows 2003 standard
y cuse its sharing isssas to 1st off way to maby boots 2 max os on hard drive unless u want to fail soon do all your updates
Security key
download aircrack-2.1 and run wzcook.exe under win32 folder
c:\aircrack-2.1\win32\wzcook.exe
http://www.aircrack-ng.org/doku.php#download should be a good place to start.
Grand Canyon Tech
Grand Canyon Tech
