Question about Zenith C27A24T 27" TV
Zenith tv wont unlock
I bought 5 tvs from a hotel liquidator,they are all locked. I have the remote to unlock them but can not figure it out.please help
  • 1 more comment
  • lizard1974 Apr 04, 2008
    My zenith tv won't unlock and we no longer have the original remote. We only have a univeral zenith remote that is not allowing me to enter the"911" solution. More help please....
  • ed aguirre Aug 06, 2008
    i bought 5 tvs from a hotel, they are all locked. I have the remote to unlock them but can not figure it out
  • ip45371 Apr 14, 2009
    i have same problem but i have RCA tv model J20300BL and also from motel
    thanks
  • 3 Answers
It should be a good enough reason for an exchange if possible. And should be covered under warranty, if not. However, if you want to try and fix it yourself......
Yes there should be a "hidden" menu. Before you access it, I want to warn you, do NOT change any values of anything you don't understand what it is or does. You can PERMANENTLY DAMAGE YOUR TV. Also, write down the original values of anything you change before changing it!!!!!
If you still want to proceed(at your own risk), here ya go.
1. Press and hold the menu button until
the menu comes up on screen and then
times out (5 - 10 seconds)
2. Immediately press 9, 8, 7, 6, Enter.
3. The set should now be in the service menu
mode. To access most of the features
selection 00 needs to be toggled from 0 to 1
4. After your adjustments 00 needs to be
toggled from 1 to 0
5.Feature 16 unlock the auto-program (change to 0)
Posted on Aug 06, 2008
DEAR,
1. JUST PRESS PROGRAM BUTTON UNTILL LIGHT ON 2. GO TO TV MODE 3. PREES CODE "911" ON YOUR REMOTE 4. NOW PRESS ENTER KEY IT WILL TAKE YOUR TV TO THE ORIGINAL FACTORY SETTINGS HOPE YOUR PROBLUM WILL SOLVE IN SECONDS
PREY FOR ME
SAEED
Posted on Feb 17, 2008
DEAR,
JUST PRESS "911" ON YOUR REMOTE IT WILL TAKE YOUR TV TO THE ORIGINAL FACTORY SETTINGS HOPE YOUR PROBLUM WILL SOLVE IN SECONDS
PREY FOR ME
BIE SAEED
Can't auto program Zenith TV for cable channels
  1. Did you try to call LG/Zenith customer support and see if they can help you? If not find your nearest LG/Zenith service center (not Best Buy) preferably a small service shop to see if they have a service remote to unlock it
Aug 23, 2009 | Zenith Z37LZ5D 37 in. LCD TV
My tv was purchased from a hotel and the volume is 'locked' at the mid-point. how can i fix it?
you cant. these tvs are manufactured like this to keep the volume at an acceptable level so that this tv volume does not disturb the next room. Unless this tv has an audio output (red, white) to output the tv audio to an external audio source such as a surround sound system then the volume is what is. Altough a good buy a tv is from a hotel it comes with limitations. Take it to pawn shop to sell then buy another tv not from a hotel.
Aug 15, 2009 | Zenith B36A24Z 36" TV
We have a zenith concierge tv that was donated to a group home. WE have tried programming it so that the cable tv stations can be used but it has a lock on the auto program and I can't figure out how to...
You have to purchase the master remote from Zenith or a hotel supply company. This is the only way to gain access to programming the concierge. The remote is currently $24.99.
Jan 22, 2009 | Televison & Video
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
I cannot reset the channels on my TV. It is the Concierge TV from a hotel. Will I need to buy a Zenith Remote from the store to do the channel programming. It says it is locked
You have a hotel/motel model that cannot be programmed or any of the settings changed without a special Master remote. Sorry, doubt that you can buy one from the store, they are not sold to the public. Contact the hotel where you bought the set and try to get the model number for the remote from them. This is a different number than the model number of your tv.
Dec 13, 2008 | Zenith C27A24T 27" TV
My tv wont let me auto program the channels
if you can get to menu to unlock the channels type in 0000 or 1234 or 9999 or 0001 orif this doesnt work you could take back off tv and remove the little battery that looks like a coin out. becareful, this is high voltage in there.........
Zenith TV not programmed for home purpose
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds.
- Press 9, 8, 7, 6 and ENTER in the sequence.
You should be in the installer menu now. There should be a line that looks something like this:
03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
May 26, 2008 | Zenith SC652 Remote Control
Zenith Concierge H25W35DT 27"
The CORRECT answer is you must purchase a LP702 remote. Google it to find one to buy. You must unlock channels and program the channels fresh.
Some standard zenith remotes allow you to reset the tv by popping off the cover of the remote and pressing an unmarked button.
Mar 09, 2008 | Zenith C27A24T 27" TV
Zenith h32h38dt 32
The "H" model Zenith TVs are hotel/motel sets designed that
a roomer cannot access the menu feature. Your best bet would
be to purchase a name brand universal remote which has the
menu button feature or order an original Zenith master remote
which would not require programming. Once you have a workable
remote which will allow you to access the on-screen menus you
should be able to program the channels.
Hope this helps,
CaseyBee
Feb 27, 2008 | Televison & Video
Zenith C27A24T 27" TV Logo
3,210 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
