Question about Kitchen Appliances - Others
Cherokee jeep electric windows
Someone played with the car and they stoped the windows and aircon. the dont work we have checked fuses and we think there ok can u help
    Genius:
  • 1,665 Answers
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Feb 17, 2008
    ALL WINDOWS INOPERATIVE
    (1) Check the operation of the power lock switch on
    the driver side front door. If all of the doors lock and
    unlock, but none of the power windows operate, use a
    DRB scan tool and the proper Diagnostic Procedures
    manual to check the Body Control Module (BCM), the
    Driver Door Module (DDM) and the PCI data bus for
    proper operation. If not OK, go to Step 2.
    (2) Check the operation of the power lock switch
    on the passenger side front door. If the passenger
    doors lock and unlock, but the driver side front door
    does not, go to Step 5. If all of the power locks and
    power windows are inoperative from both front doors,
    go to Step 3.
    (3) Check the fused B(+) fuse in the Power Distribution
    Center (PDC). If OK, go to Step 4. If not OK,
    repair the shorted circuit or component as required
    and replace the faulty fuse.
    (4) Check for battery voltage at the fused B(+) fuse
    in the PDC. If OK, go to Step 5. If not OK, repair the
    open fused B(+) circuit to the battery as required.
    (5) Disconnect and isolate the battery negative
    cable. Remove the trim panel from the driver side
    front door. Disconnect the 15-way door wire harness
    connector from the DDM connector receptacle. Check
    for continuity between the ground circuit cavity of
    the 15-way door wire harness connector for the DDM
    and a good ground. There should be continuity. If
    OK, go to Step 6. If not OK, repair the open ground
    circuit to ground as required.
    (6) Reconnect the battery negative cable. Check for
    battery voltage at the fused B(+) circuit cavity of the
    15-way door wire harness connector for the DDM. If
    OK, replace the faulty DDM. If not OK, repair the
    open fused B(+) circuit to the fuse in the PDC as
    required.
Jeep cherokee problems
Check your fuses. Your owner manual can help as well to located them or simply look on the fuse box and it will tell you where every fuse is. Good Luck!
Jan 13, 2014 | Cars & Trucks
1995 jeep cherokee windows dont work
I would assume that we are talking about power windows here? if so, check the fuses for a blown fuse. if that is not the case, check the switch and the lock on the drivers side that can lock all of the windows.
Aug 30, 2013 | 1996 Jeep Grand Cherokee
Windows on Jeep
Check fuses, windows switch, wires or windows motor.
Aug 27, 2012 | 1999 Jeep Grand Cherokee
All of the electric windows in my 1998 Jeep Cherokee stopped working the other day - I am thinking that because it is so abrupt and because it is all of them that it is probably a fuse. Which fuse is the...
Generally the windows would not be on a fuse but a circuit breaker. Chances are though that you either have a faulty switch in the master control or a broken wire in the tunnel that goes from the body into the drivers door.
Jun 07, 2010 | 1998 Jeep Cherokee
The electric windows on 1993 Jeep Grand don't work.
You would have to take the door panel off to take the window motor off, then run jumper wires to the window motor terminals. If the motor doesn't turn, time to get a new one. But more than likely, if all the windows don't work, it may possibly be a fuse. Also, you might want to check the window switches, they do burn out. I have had to replace a couple on my 1993 Jeep Grand Cherokee.
Feb 23, 2010 | 1993 Jeep Grand Cherokee
Drivers side door on 1998 jeep grand cherokee stoped working ,doors wont lock , window wont roll down , mirrors dont work , is there a fuse to check ? and where , i know where the fuse box is dont know the...
I have the same problem. Do not know cause but I remove large red 50 fuse in engine compartment fuse box, wait 15 sec and replace. Lock car and unlock. This seams to reset something and car is fine. This problems seams to appear when my battery is low.(?)
Oct 26, 2009 | 1998 Jeep Grand Cherokee
All warning lights on dash come on and all electrics stop working
The common problem with the dashes on the Jeep is contacts. Remove the cluster and try cleaning the electrical contacts with a Q-tip and alcohol replace cluster and try again.
Aug 02, 2009 | 1995 Jeep Grand Cherokee
Power windows won t work
There are broken wires in the wiring harness between the frame and your driver's side door. These wires control all the windows and door locks in a 95 Jeep. Same thing happened to me. You will have to cut the rubber boot to get it off and check which wires are broken and repair them.
May 30, 2009 | 1995 Jeep Grand Cherokee
Aircon/heater/rear window demister not working.
Youes probably begot a bad connection inside the fuse block. You can try cleaning fuse contacts with a really small nail file or something to re-establish contact.
Feb 13, 2009 | 2000 Jeep Grand Cherokee
Kitchen Appliances - Others Logo
448 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
