Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Easyshare 5300 USB printer port
I can't plug in the USB cable in the back of the printer. It has a plastic thing in the way. When I removed the plastic thing, I see 4 wires but not a proper place to plug in the cable. What do I do?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 41 Answers
Easyshare 5300 USB printer port - a857448.jpgedeafeb.jpg Make sure you cable has this type of plug (bottom image) and plug it into the slot marked 17 on the top image. If you cant do that maybe its broken and you should exchange it for a new one.
Posted on Feb 22, 2008
I have a kodak 5300 printer. I recently had the
Reinstall your windows or 'Recover' or 'Restore' to an earlier date, perhaps to the original 'new' date.
Let the operating system find the drivers for your printer again, or install the right drivers for your operating system and printer combination, off of the website for Kodak.
Good luck.
Jul 04, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 printer problem
I would suggest the following :
1) Remove the Kodak printer and all its software.
2) Disconnect the USB cable from the computer.
3) Reinstall the entire software applications for the printer just as if you were installing it for the first time.
4) When asked to connect the printer .. Use a different USB port .. even if you have to switch something out .. but do this step irregardless.
Now what I want to know is ..
1) Can you print from the computer?
2) Black still "gone" ?
Let me know
Feb 01, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Sharing 5300 with more than one computer
You can do this by using a router. If your home lan is wired then you would connect all computers to the ethernet ports on the router. Run the usb cable from the printer to the the computer. Turn on all computers you wish to be in the network as well as the printer & any modem you use to connect to your isp. Connect one computer to the internet. Start running the network wizard on each computer, starting with the one connected to the internet. When you have finished the wizard on all computers you might need to install the printer driver on all the other computers. You should now be able to print from any computer connected to your network. Hope this helps & please remember to rate my answer. Thanks.
Jan 25, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
My usb cable dosent match the port in the back of 5300
Usb cables are universal, the only reason it may not match is if the MAN. sent the printer with it's own cable. That would not seem to be a Canon thing to do if it were a Dell then yes.
Also, try this the USB cable will only fit in one way, try turning it the other way and see if it fits. the silver end part has a line down the middle that part should be in the down position.
Jan 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Istallation of 5300 printer
please be sure that the printer is on and has a green steady light when u plug the usb cable to the computer.
Aug 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
External hard drive problem
The problem is that the printer, being a composite device, takes a lot of energy from the computer USB ports. Some computers, such as some Dell computers, have problems with USB ports due to a cheap manufacturing. What I can suggest you is to simply unplug the printer when you want to use the HDD, because no matter what you do, you'll have the same problem and that's because of the computer that won't supply enough power to the USB ports.
Also, if you are using a laptop, remember to keep it plugged to the power so it can provide more energy to the USB ports.
Aug 06, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer easyshare 5300
Heres a few things to try. Open the access panel to where the ink is. In the top right hand corner on the printer there should be an L shaped plastic piece. Remove that piece and make sure that the cables are connected properly. You can also try to unplug the printer and plug it back in. If this stuff does not work, you will need a replacement printer.
Jun 30, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak AIO Easyshare 5300 scanning problem
Could be USB connection if you have another cable try it. Try connecting to different USB ports on your PC. If you have a Powerd USB hub lying around try connecting the printer to the PC through that.
Also try disconnecting all USB devices including the printer. Reboot your PC. Connect only the printer and try and scan.
Some times multiple USB devices dont work when they are both connected to the same PC.
Hope this helps!
SDtester
May 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak easyshare 5300 issue.
Call Kodak tech support and they will ship you a new printhead without any charge.
Jan 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
37 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
