Question about Cameras
Replacement cables for lorex cameras
I need to replace the 4 pin connector and cable that plugs into the back of the camera. Lorex is no help apparently they don't have parts. I have one cable that works, the others were destroyed. I have plugged the one that is okay into the cameras that the cables were destroyed and all the cameras work. Attached pictures of what I need. HELP, please.
MrsJGreen
  • 130 Answers
SOURCE: Canon zoombrowser Ex downloading problem
Try updating the Zoombrowser software.
If you have a connection to the camera, go into my computer and get images directly off the camera using scanner and camera wizard, microsoft's default program. This will at least allow you to transfer your images until you can resolve the software problem.
If you have no connection to the camera via your computer, you need to try some other troubleshooting steps to get a connection. I will post those below in the next post.
Posted on May 30, 2008
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
welcomejee
  • 10594 Answers
SOURCE: canon powershot A85 camera, only seeing black and white on TV
Please check Yellow video connector in TV and hook camera video cord there to see color picture of Canon A85
Posted on Feb 20, 2009
The sd1000 manual says that you will get this error when you have too many pictures on your memory card (aprox 1000). I am not sure how many I had on my 2GB card but it was a lot. I deleted about 50 - 100 pictures and then it started working again and the new pictures downloaded to the computer.
Posted on Jun 27, 2009
  • 3 Answers
SOURCE: I cannot download my pictures
1. Turn PC on.
2. Plug camera cable into Camera.
3. Plug camera cable USB end into computer USB port.
4. Turn on Camera... wait until camera show message 'USB, PC, Pictbridge'.
5. PC should be selected if not select by highlighting and press shutter button.
6. Press 'Shutter' button.
7. Window 'Autoplay' appears on PC. Select 'import' in Autoplay window.
8. Another window will ask you to name your picture folder. Give it a name.
9. The pictures download to the picture folder automatically.
10. Turn the camera off and disconnect cable from camera and from the PC
11. ENJOY!!
Posted on Feb 19, 2011
I have a lorex CA1090310741 model MC7540 color camera but the wires are cut.. I need to know which is what their are 4 wires red,white,clear coated copper and bare copper???
you need power to the red and black, white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Oct 03, 2017 | Lorex Home Security
Need Owners manual 4 Lorex LNC201
About 75,300 results (0.48 seconds) Search Results
    [PDF]LNC200 Series LIVE Ping Wireless Network Camera ... - Lorex
    https://www.lorextechnology.com/.../LNC200_SERIES_MANUAL_EN_...
    Oct 16, 2012 - If you require further installation assistance, please visit ... Thank youfor purchasing this Lorex wireless network camera. This user's guide refers to the following models: • LNC201. • LNC204. Contents. Before you start, make ...
    Lorex Support - product manuals and remote video monitoring
    https://www.lorextechnology.com/support/
    Lorex Support - Get online help for your setup problems using lorex self-serve and access your lorex information, products manuals and documentation. ... Find out all the ways you can get support and service for your Lorex products. ... Some products may have the Model Number located inside the battery compartment.
Jan 25, 2016 | Lorex Home Security
We just set up our Lorex LHV1000 8 channel system but the dvr won't stop beeping. How do I make it stop? We only have 4 cameras in use but we tried plugging all 8 in to see if that was the problem but it...
Might be too late... but it beeps if its not hooked up to internet. So to stop it from beeping either connect it to ethernet cable in back, or you can turn off beeping in menus- its i believe settings, event, network- then unclick the box thats there
Mar 13, 2015 | Lorex Home Security
Lorex SG 6157 need to know what the four wires go to blue black re yellow
Red & Black are PRETTY MUCH always the Transformer Pwr (12v delivered: (9V DC working...Red is positive)).
So the video should be your yellow & blue/
(I thought green (but what do I know)).
ImageSensor:1/3"ColorCMOS, VideoFormat:PAL, EffectivePixels:628Hx582V Resolution:330TVLines-SyncSystem:Internal, AES:1/50~1/1500Sec Min.Illumination:2Lux, Lens:6mmF1.8, ViewingAngle:Diagonal53? OperatingVoltage:9VDC, OperatingTemperature:-10~45degreeC Dimension(WxDxH):53x80x49mm, EnvironmentalRating:IP44
I have every confidence your cables are going someplace EVEN MORE COMPLEX you have not even mentioned. You really need to share that BEFORE DEFINATIVE answers can be given abort ONE end of your cable.
The primary question
Are you using Philips/BNC (cannon-PWR)/ connectors or the RJ45 type... using individual power transformers or Power Distribution panel... Direct to a video screen (TV monitor).. or a NVR real-time matrix... or DVR recording system
Comment back if you are serious with configuration information... If I don't know your answer straight away I can get you pointed in the right direction.
Required Pin-out, nvr, dvr, resolution, compression, remote, IP
lorex sg6157 wire pinout Bing images
Lorex SG6157P Specifications
Jan 14, 2015 | Lorex SG6157 Indoor/Outdoor Color Camera...
Wires cut on my lorex mc7520 color camera how do I wire
http://www.lorextechnology.com/downloads/security-dvr/SG19LD-SG17LD-Series/SG17LD800&SG19LD800_SERIES_MANUAL_EN_R3.pdf
I hope you have the rest of the system since the monitor powers the camera. If you have the end of the cable with the connector on it then just splice the wires color for color. If not then you're out of luck.
Oct 01, 2014 | Lorex Home Security
I purchased a system from Lorex model # LHV08C02
Lorex used standard BNC and provides Siamese cables for all their DVR systems; like this one.. If you want to use your own, use 75 Ohm RG-59 or RG-58 with compatible connectors. If using premade cables, use BNC female to female. Power is separate and is provided by the 'wall wart' style power adapter.
Sep 29, 2014 | Home Security
Have 8 cameras, 1 is showing grey color on screen
try to plug that camera to monitor directly it can be problem with its cable or BNC connector
Jun 02, 2014 | Lorex L19wd804251 19 Lcd Dvr Surveillance...
Lorex WL2700 blue screen and shaking
plug the camera directly to monitor if no change check connectors and cable
Apr 14, 2014 | Lorex L23WD845 4-Camera Security System...
Need wiring diagram for Lorex SG6184S. Cut off connectors and hardwired camera, not it does not work.
Lorex Corp SG6184S Weatherproof Mini Color Security Camera with Night Vision,where can i download manual,wanting to set it up to my vcr and clueless how this is done,i have camera's yellow white cables in tv[video/audio but unsure how to connect or what to do so i can record from vcr,please specifies
Sep 03, 2010 | Lorex Corp SG6184S Weatherproof Mini Color...
Cameras Logo
146 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
