Mayteg refirgerator Display on left door is flashing off and on. Darn thing is only 1.5 yrs old!! We unplugged it and plugged it back in twice longest wait was 5 minutes. Still does same thing. Model number is MFI2568AEW
  • Gary Davd
    Gary Davd May 11, 2010
    you posted this under washers but this is a ref right??
Freezer door handle is loose. How can I get to the handle nuts to tighten them?
Posted on Jul 06, 2010
I need the 4 digit code for the MFI2568AEB. Some genius took it off before we bought it. I've replaced teh HV board and the fridge won't work. HELP!!!
marcetters@yahoo.com
Posted on Mar 24, 2008
  • mikeizmad Jul 25, 2013
    the code for mfi2568aeb is 0302
  • 770 Answers
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Posted on Feb 16, 2008
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
I purchased the Sony TV in March 2003 and now it won't turn on. I checked the Internet, stumbled on this site, read some of the posts and notice that I was having the same problem, flashing red lights....
Take the darn thing aparts,go to Radio Rack buy a soldering iron,a roll of solders.Many of these old CRT-tv design have high voltages and video board CRT sockets pins connections to the CRT-Tv Tube connections are coldsoldering alot after year in and out used.Tries resolders the FBT-flyback transformer that a big black block of plastic with a red wire with a cap hook to the CRT-(tv tube).Also resolderings all the pins sockets on the video board for good connections and contact for the video board.These steps help,will help on high voltage on for good and video board output on solid putting connections with the CRT-(tv tube).
Feb 08, 2011 | Sony Televison & Video
The camera back button requires power to operate and as the electronics seem to be fried button pushing doesn't open the door. So is there a manual access way? thanks
I had a Canon Elan IIe and I don't recall having to have electronics to open the camera back.
Make sure you have a battery in it, turn it on look at the LCD panel and see if it has film in it.
If so you should be able to push the "mid roll" film rewind button located on the back left side it shows a film canister icon. Once the film has rewound into the canister release the back with the mechanical latch found on the left side (while facing the back of the camera) just push it down and the back will pop open. Those cameras are pretty darn good and the only thing I've seen friy the electronics is using an "old" type flash on the hot shoe and that takes the flash circuit board and melts the thing. I'd expect the camera battery is dead and you can't rewind the film back into the canister.
Nov 08, 2010 | Canon EOS Elan IIE 35mm SLR Camera
Have a 12 year old kitchenaid Superba stainless steel built in microwave. I suddenly stopped and "door' lights up on display. Door is shut hear clicking by left side may be a latch issue. How do you fix?
Hi - it is 12 yrs old so parts may not be available for it.
If its a door problem, then its really a door latch switch or switches that has failed. Time involved in removing case, then switches then checking them all then finding replacements at ?? cost is uneconomic.
Please consider getting a new machine - probably use less power, have more features and work a darn sight better than this old one.
Jun 08, 2010 | Microwave Ovens
Electronic display was flashing LE. Unable to open front load washer...no visible water. Tried to restart...unable. What is your best solution to open front and get washer working again? washer is...
Waht make? Model?
Sounds like an LG
You might want to unplug the unit for 10 min -then plug it back in and then power up , then press pause.
LE- could be a motor sensor, main board issue - wiring issue
Affordable Appliance repair
Orange County, CA.
Aug 22, 2009 | Washing Machines
Mini refirgerator stopped cooling, interior light
If nothing is running but the light is on you might want to unplug the unit for about a minute. Then plug it in. If it starts up again then do nothing. It just had to be adjusted. If the display shows a er then it could have something wrong with the thermistors. If it shows 2 dashes then let me know and I can try to walk you thru a program to get you backup and running again. If 2 dashes you will have to get to the plug so pull the unit out.
Jul 12, 2009 | U-Line Model: CO1175S01 Compact...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Flashing Power Light
Toshiba rear projection with blinking LED =
1) Open micro fuse F850,851,etc....caused by
2) Bad solder connects....jumper wires 008,010,017,048,600
re-solder all and solder STK392-110 convergence amp pins.
3) Or consider replacing original IC's with improved version...
STK394-160 = Hitachi part # CZ 01341
.........................T.
Aug 30, 2006 | Toshiba 53H71 53 in. Rear Projection...
Washing Machines Logo
391 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
