Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
    Problem Solver:
  • 16 Answers
Need more info. Your current configuration would be helpful.
HDDs in almost all cases require no drivers for their operation. If your motherboard correctly registers the HDD, it might be an outdated BIOS problem: Code 10 usually means problem with the BIOS. Read below for a solution.
Possible problem: Judging by the fact that you're running Windows 98 SE, I'll presume you're also having an older computer. If that is the case, there's little you can do: BIOS' on older motherboards don't support ever-present high capacity HDDs of today. The usual BIOS limitations were something like 8Gb, 30Gb, 80Gb, 130Gb. Another limitation is the IDE ATA interface which allows ATA devices up to 137 GB.
Try to obtain updated BIOS firmware files for your specific Motherboard model, and then "flash" it over your current one. Finding it should be quite straight-forward if its not some *ancient* model, otherwise you would find it to be almost impossible. You can usually find those on the website of your Motherboard's manufacturer, usually under "Support" and/or "Discontinued Products" section.
Caution: follow the flashing instructions to the letter - BIOS flashing is a somewhat hazardous operation; if not done properly, it could render your Motherboard permanently inoperable!
Problem 2: If Code 10 problem is beyond you, there's a new one - Windows 98 SE has a limited support for High Capacity drives - it's limited to about 120 GB. If you can boot to your Win98SE system, you should be able to circumvent that limit by splitting your HDD into two partitions with their individual capacity set not higher than 120 GB. I'm assuming you're just adding a second HDD and your current OS Installation is safely "tucked" in and running of your old HDD.
If all else fails - and you insist on using Windows 98 SE - the only solution would be housing the HDD in external case and connect it through USB. However, that brings additional problems... [such as unavailablility of Microsoft-made USB 2.0 drivers for Win98SE]
I suggest you go through the pre-problem part of what I wrote, then tackle the Problem 1, after which you should install a fresh copy of Windows XP. If you're afraid of performance drop (if your computer is an oldie), you still might get the best from both worlds by creating a custom installation of Windows XP with nLite. Such an installation has its "downsides" - like the fact the Microsoft is not quite approving of them - but as long as you have the original CD, you can fiddle with the custom installation to your hearts content. Anyway, I'm going off-topic here: google for nLite if you're up to it, you'll find who-what-how-when and where. Good luck.
Hope the above suggestions help you. If you need additional help. feel free to ask. Rate me if you find this helpful.
Posted on Feb 17, 2008
  • Cyberneticus Feb 17, 2008
    Heh, leave it to me to totally - miss it. NOW I noticed it was an External drive all the frelling time.
    Ok, so I presume you connected the HDD and Device manager told you something along these lines:
    "The device is not present, not working properly, or does not have all the drivers installed. (Code 10.)"
    Before you proceed, make sure that your HDD is fully functional and detected properly on some other PC.
    One possible problem could be an old motherboard with USB 1.0 or 1.1
    ports only. Make sure to check the specifications for the Removable
    drive. It SHOULD support USB 1.0/1.1 ("Legacy mode"); however it's not
    uncommon for many USB 2.0
    devices not to work on legacy USB 1.x ports, especially on Win98SE.
    You could try installing the Windows 98 USB driver for your HDD from a
    CD it came with [if any] or try to download the driver from official
    manufacturer's website].
    If you do indeed have the USB 1.x ports and the problem persists, one
    POSSIBLE solution is installation of a USB 2.0 PCI card that has full
    support for Windows 98. Again, this works in most cases, but still is
    in no way guaranteed to work in your prospective case.
    The only hassle-free solution is an OS upgrade to Windows 2000 or higher [XP preferable].
    Another limitation of Win98 is the inability to use NTFS [without much hassle, that is] and the aforementioned Windows 98 SE "problem" with High Capacity drives.
    Here are some helpful links (driver link included at the bottom):
    User Guide:
    Quick Start Guide:
    Drivers and misc downloads:
I have a flash disc but it d'ont work in W 98 system please help me to solve this problem
Posted on Oct 20, 2008
My Pc is not picking up D-760 Olympus driver?
The camera is not supposed to require an extra driver unless your computer is using an operating system lower than Windows ME. There is a driver for Windows 98SE, but none for the original Windows 98, Windows 95 or Windows 3.x.
The camera is supposed to appear as an external USB hard drive on the computer.
Jun 27, 2014 | Canon PowerShot A470 Digital Camera
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
you can burn all your stuff into a CD or a DVD
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
I need to back up my hardrive to an external Hardrive (Free Agent). I need diretions
Plus your free agent to your computer, then copy your files and folders from your compute to the new external one. Use copy and paste.
Apr 07, 2011 | Computers & Internet
I have all my pictures on a external hardrive and don't know how to get them on to my new computer.
Attach your harddrive to your computer via the cable that came with it.
Chances are it will be a USB connector.
Windows should recognise it and install the drivers automatically.
It will show up as a drive letter in 'My Computer'.
May 13, 2010 | Computers & Internet
Computer does not recognize Portable Harddrive
restart you system then plug it into different port if still not working then change the wire of ur hardrive...
Plz dont forget to rate
Sep 07, 2009 | Electronics - Others
1TB Verbatim external hardrive not recognized
Try taking the drive out of the enclosure and buying a usb adaoter that will fir the interface the hard drive has...either EIDE or SATA, then hook that up to a usb port and see if the computer will load it. May be the controller card in the enclosure is your problem.
Sep 02, 2009 | Verbatim VER95327 USB Hard Drive
My pc dose not come up my maxtor basics external desktop hard drive
What OS are you using? Windows 98SE does not always recognize exterrnal hard drives. Try the external HD on a computer running Windows XP and see if that works. If it works on WinXP and not Win98SE or possibly WinME the External HD is good.
May 06, 2008 | Maxtor Hard Drive
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
443 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
