Question about Canon PowerShot G3 Digital Camera
Compact flash disk
Canon powershot G3 is sending message "card full" when my 512mb SanDisk is absolutely empty. If I try to view a picture on the so-called 'card full' camera it says "no images". I've been using it for 3 years with no problems. I switched to another card and it worked fine. So should I just throw out the one that keeps being identified as 'card full'? Do they wear out?
  • geenie Feb 18, 2008
    this was better than helpful. It took care of the problem. This was my first posting - sorry I mismarked the rating.
  • Canon Master
  • 4,738 Answers
Yes they can and do go bad on occasion. But before throwing it out, attempt to format it in your camera. Find the menu selection that allows you to do a "full" or "low level" format, NOT a "quick" format. If the card still misbehaves, then it's time to retire that card.
Posted on Feb 17, 2008
Need of Canon digital solution disk Powershot G3 Camera for instaling on Windows 7 (64-bit)
You don't need any additional software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Jan 02, 2013 | Canon Powershot G3 4.0 Mp Digital Camera...
Canon A10 - "CF card error" with new 4GB card
You need to format new cards in the camera before using.
Apr 05, 2010 | Canon PowerShot A10 Digital Camera
Card reader in camera or computor wont read sdhc cards
Although my SanDisk compactFlash cards 128 MB 256MB 4GB and 8GB cards are far from being full, when I open up my Canon Powershot A40, the follwing msg appears: CF card full. However, the original Canon Compactflash card FC 8M provided with my camera will still accept new photos. The problem is recent. Can someone help me.
Sep 13, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
My card won't work on my computer, what is wrong?
When you format the card, be sure to do it in the camera, as the camera firmware writes hidden files to the card.
When you insert the card into the card reader, be sure to set write-protect, so the contents cannot be corrupted.
I suspect what may have happened is that at some point there has been a conflict between files written to the card by the camera and the computer.
May 13, 2017 | SanDisk ULTRA II 4GB Compact Flash Card...
Sandisk 4GB card reads full when it's empty.
I would suggest reformatting your disk to your camera. We have had those issues and it has cleared it up. Be sure any pics on your camera have been backed-up as you will loose all pics while reformatting. The key is to reformat your disk to your camera (use the camera's menu to located the reformat disk section)...do not use the computer. Hope it works!
Jun 07, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Roland SPD-S Flash card error
The card I have always been using is now also suddenly giving this message. I found an old SanDisk 16MB and a 1GB SanDisk that works perfectly in my Boss 864 and they also give the same message. Trying to go into formatting brings the message "no card!"
May 13, 2008 | Roland Spd-S Sampling Percussion Pad...
Device driver for g3
Dear diksi:
Unfortunately your G3 is incompatible with Windows Vista. To
do downloads to your computer you will therefore have to utilize a compact flash card reader. You can get them from any store that sells digital cameras. I bought one from Wal-Mart three months ago for $14.00.
You can still load and use your software however. You just won't be able to download using Canon Camera Window.
Hope this helps.
Sincerely,
HeavyDLB
Apr 27, 2008 | Canon PowerShot G3 Digital Camera
Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
Oct 27, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
Problem downloading pictures from memory card
Hi flashlal - I have a Cannon PowerShot S400 and I had a similar problem which uses a compact flash card. I could only view a few photos and it seemed like the rest were gone. I verified that my photos were on the compact flash card when I installed it in my pc and navigated to the compact flash card (You can do that by double clicking on the "My compute" icon). Then double click to the directory to where your memory card is located and navigate through the files. I noticed that my photos were there because the file size was in the hundreds of kilobytes (700KB and up), but the names of all the files were corrupt - they had symbols in the name. I figured at this point I had nothing to lose so I did a "check and repair disk" on the compact flash. To do this: take note of the directory that your memory card is located in (it should be something other than C:). Once you know where your memory card is located, you go to your start button on the PC, then to run. A pop-up window appears.The command to repair your disk is "chkdsk /f", however you have to tell it the directory of where your memory card is located. For me my memory card was in the E: drive so I had to type:
chkdsk e: /f
Once it finished running I went back to the my computer window and navigated to my compact flash folders. I looked at my photo names. I had to rename all my photos by putting the extenstion of "JPG" back as the file type. Once I did this, I could then view my pictures. The only thing I lost was the added information that my camera puts on it like the date, time, and camera setting used to take the picture. I was fine with not having that because it was more important for me to retrieve my pictures.
Good luck.
Sep 26, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot G3 Digital Camera Logo
78 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
