Question about IBM ThinkPad T30 2366 Notebook
2nd slot issues
I'm trying to install a second stick of ram in my t30, but it wont work. I switched the old and put in the new and that works. So whats my issue. I've been reading that there is a second slot issue with the t30. Could this be my problem?
  • lynchmobb Feb 17, 2008
    Tried your advise. Still not reading. I contacted ibm, and they said that I would have to pay for repair even though it was offered for free 2yrs previous. I asked customer service why would it matter, and he told me "its because we sent those notices out, and if you didn't respond...". Well basically its my prob, even though I haven't had the computer for more than a year. Any other suggestions to get this other slot to read my memory?
    Thanks for your help
    Genius:
  • 3,587 Answers
IBM's may need a bios update to read the 2nd slot do that first, and then check your setup for both slot availabilty. IBM always has, and always will make your life interesting.
got backup for your IBM Thinkpad?
Posted on Feb 16, 2008
  • Patrick Michaels
    Patrick Michaels Feb 17, 2008
    unfortunately, that's how IBM has always played the game. Too bad too, since the computer isn't really that bad. I also understand that the max size of memory is limited too. Reminds me of the old Compaq proprietary days.
I have e-machines T5026 with an Intel Corporation D915GAG mother board which currently has 1.5GB Dual-Channel DDR @ 133MHz (3-3-3-8). I am trying to add 1 gig of PNY RAM, #MD1024SD1-400. When I installed...
You may be using the wrong parity or out Latency ram. if they are not similar in latency they will not work in tandem. Make sure both of the ram's are the same MHZ and CS latency. Also, you may have bad ram as well. Try using the new ram first to see if the computer posts, if it does, input the old ram in the second slot, and if that doesnt work, the ram is not compatible with each other.
Feb 05, 2011 | Intel D915GAG Motherboard
I have 2 512 cards installed and the computer only shows that I have only 512 installed and it should be 1 gig?? What would be the cause of this?
There could be many reasons,
1 Either the RAM slot is not working
2 or the RAM card(s) are not OK
3 or the RAMs are not compatable(not of the same specs)
Solution
1 Remove both the RAM cards, clean the metal joints in both the RAMs and the RAM slots
2 Remove power, remove all power source, remove power cables including all the battery
3 Keep presssing the power switch ON for a few mins, Do....ON... OFF, ON... OFF WITHOUT any POWER
4 Replace battery, power adaptor, power cables etc
5 Insert one of the RAMs in 1st RAM slot, power on, check if it's OK, Switch OFF, remove the RAM
6 Do the above process for the other RAM, now check if that works, use the same RAM slot
7 Now do the above two steps for the 2nd RAM slot
It will give you a rough idea of where is the issue.....either RAMs are not OK or the slots have issues or there is a compatibility issue among the RAM cards.....
Pls reply back and leave a feedback
Regards
Kris
Nov 16, 2010 | IBM ThinkPad T30 Notebook
I got a blue screen and everything shut down,i switched all off and removed mains and battery for 5 minutes,i tried to restart and all i get is bleeping noise (2 bleeps then 3 bleeps then 1 continuess...
Sounds like faulty memory if there is more than 1 stick of RAM try testing just 1 at a time to eliminate the bad 1. If you're not sure how to get to the mempry search the internet with another PC for a service manual Sometimes just cleaning the contacts on the memory sticks will fix the problem. Good PC shops sell abrasive pads just for at very little cost or if you can find an old ink rubber they are basically the same thing. Cheers from Scott and plz vote
Nov 02, 2010 | IBM ThinkPad T30 2366 Notebook
I have a Soyo P4VGA MB. When I purchased the board I made a huge mistake a nd installed only 256mg of DDR. Since then, I tryed to install a second stick of 256 DDR (same brand and specs) but the computer...
Take both ram sticks out and turn the PC on. If it makes no sound at all with the stick out this means you have a problem with the mother board. If it screams like a banshie the board should be okay. Try putting the new stick in the slot where the old one is and the old one in the other slot. It might read it that way, no guaranties this will work but it won't hurt. It is also possible you got a bad stick. It does happen.
Hope this helped.
Good Luck
cookEmonster
Oct 13, 2010 | Computers & Internet
Bought 1G ram from local computer store. It runs for about 5 minutes then i get a blue screen error and reboot. returned to store for a different mem stick...same issue. went to Crucial, found the...
Did you remove the "old" RAM, or did you add the "new" RAM to the old RAM?
Try using your computer with ONLY the "new" RAM installed.
Try using your computer with ONLY the "old" RAM installed.
Try using your computer with the "new" RAM in the 1st slot, and the "old" RAM in the 2nd slot.
Try using your computer with the "old" RAM in the 1st slot, and the "new" RAM in the 2nd slot.
Aug 27, 2010 | HP Pavilion ZV5220US (PF143UA) PC Notebook
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
Trying to upgrade RAM on GA-945gzm-s2 mobo. Already have 1gb 5300 ddr2 stick of RAM. Works fine until I place the 2nd stick of RAM in. I turn it on and get no post beeps, no video, but everything is...
The new RAM module could be faulty or the second memory slot is faulty.
Try removing the original 1Gb memory module and inserting the new memory module in its place to see if the computer boots up normally. If it doesn't then then new memory module is faulty.
Oct 24, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Upgraded memory in my ibm t 30 laptop
You have 2 sticks of RAM correct? One that came with the system and one that you bought. You also have to slots but it appears one may not be working, however, nothing is impossible but that is very rare it is normally the RAM itself and not the slot. Take both pieces out, put the new ram in the first slot and boot up. If the system will not boot up then it is the RAM because you already know that that slot is good. However, you cannot do the same thing with the second slot, because your motherboard looks for RAM in the first slot and if there is none then it stops boot. Conclusion: Put new RAM in first, slot if it works then second slot is bad, if it does not work, then RAM is bad...
Hope this helps. Please vote accordingly and if you have any more questions I will be glad to research and answer them for you...FixYa
Jan 08, 2009 | IBM ThinkPad T30 2366 Notebook
4gigs ram
Switch sticks around in various combinations (2 gig in slot one, 1 gig in slot two, switch, try other stick, etc) and see if it is the memory or the motherboard.
Sep 10, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Installing new ram...wont work
Go HERE for troubleshooting guide. Scroll down to: Stability Problems - Memory Issues.
Jun 03, 2008 | MSI 915P Neo2 Platinum Motherboard
IBM ThinkPad T30 2366 Notebook Logo
184 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
