Question about Activa Watches
I have an activa lithium water resistant watch #AD632=010. The light works but the digital clock doesn't.
    New Friend:
If there is no time displayed the watch is just dead. You can try a new battery or just get a new watch.
If you can't seem to set the time: Press and hold Mode until it flashes a time and the letter A . This is how you set the alarm. Press mode again and you can set the time. start stop button moves between seconds, min., hrs, and days. reset changes the value.
Posted on Feb 04, 2010
SOURCE:
What's the band size for a cr2016 Timex indiglo? Also says wr 30 m.
these are not the model number , CR2016 is the lithium battery number and the WR30 is water resistance 30 meters.
you will need to send the watch off to Timex [email protected]
May 09, 2017 | Timex Watches
Analog on digital watch not working
when a watch has analog hands and has digital portion, 9 times out of 10 it will have 2 batteries inside. A lithium battery and a normal battery. It is possible one died before the other. Usually the lithium (digital portion) lasts longer. Have the battery changed.
Dec 06, 2013 | Watches
Is the Sharp watch shp5759 waterproof
No such thing as a waterproof watch in the USA. Watches are rated for resistance to different depths. If it just says water resistant it means you don't need to remove it to wash your hands. If it doesn't say anything it is water resistant.
Oct 01, 2012 | Watches
Activa AD 044 digital watch. Came without
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all INVICTA watch manuals. Rate me, please .
Apr 07, 2010 | Activa by Invicta Midsize Digital Watch...
I bought this watch and misplaced the manual for it and can't set it. Activa water resistant register no. 495494 AD639-008 yellow
Click on my profile (escapement), then click on Tips and Tricks. There you will find links for all watch manuals.Rate me, please.
Mar 17, 2010 | Activa Watches
How do you turn off alarm on activa AD050 watch
in the normal time mode,  hold down the start button (this also shows the current date)  and then press the reset button to toggle on/off the alarm
Dec 15, 2009 | Activa Multifunction Digital #AD050005...
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Polar A5 wrist watch
Have you thought of taking it into a watch specialist.
I would advise you not to accept adresses on this site for your watch to get repaired .
Does it run on a lithium battery ?
Aug 04, 2008 | Polar A5 Wrist Watch
Watches Logo
275 people viewed this question
Top Activa Watches Experts
Arturs Kalnins
Arturs Kalnins
ray gallant
ray gallant
Are you an Activa Watch Expert? Answer questions, earn points and help others
