Question about Toshiba P000223320 - System Board, FVRSY5 (P000223320R) Motherboard
Toshiba 490xcdt okay, got this off ebay...humm!! brought brand new power supply, left it plugged in, a battery light was on. after two hours pressed the on button and nothing....all lights off ....absoluting zip. any ideas? power cord thing still has the green light so thats not damaged... bad fuse? do laptops even have a fuse - where do i find it to replace on!?? any help would be really kind. thanks rob.
    Problem Solver:
  • 16 Answers
Are you sure you used the charger with the exact specifications?
I once encountered a problem like this... try removing the battery and replacing it after some 5-10 minutes. It worked for me.
If it doesn't, try whether it would work only on main AC with no battery inside what-so-ever. Then - try with it.
Oh, and no, laptops - to my knowledge - do not have fuses... at least those 4-5 I opened didn't.
Hope this helps. I'll post up if anything else comes to mind...
.:: Cyberneticus ::.
Posted on Feb 17, 2008
TOSHIBA SATELLITE C55D POWER LED ON WHEN CLICK POWER . ,BUTTON SCREEN LIGHTS UP AND SAYS BATTERY LOW AND CHARGING
Yep... classic signs of a bad/poor battery! About $13 including US shipping (US Seller too).
See eBay: 322759285844
If you REALLY want to do a good job buy a NEW POWER SUPPLY TOO! They do age ~ with time ~ like all of us.
$9.78 shipped.
Happy BATTERY with it's NEW Power Supply!
Anthony
Lot Battery for Toshiba Satellite C55 C55D C850 C855 C850D C855D PA5024U...
AC Adapter Power Supply Cord for Toshiba Satellite C55D A5120 L755D S5150...
Nov 21, 2017 | Toshiba Computers & Internet
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
Toshiba L655s5065RD wont start , only sign of life is blinking orange light
Okay, what does that light indicate? (hard drive activity, power plugged in, battery, etc). It most likely indicates a faulty power supply or damaged battery unit.
Dec 10, 2012 | Toshiba Satellite L655S5065RD 156 Notebook...
A Toshiba Flat Screen (52"
U tries check the power source and unplug,replug the tv back like about an hour later.For the tv to do a resetting itself back to the factory setting.No,fans in LCD or Plasma flat tvs.If this tv a LCD flat screen tv than the tv have power supply board problems,this tv doesn't have fan design into it.After it goes off the tv power LED light indication on the tv bazel frame are blinking?Yes that the tv have a power supply board can't sustance power voltages to the tv anymore.The tv power supply board that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.Or have the tv service by a athorized LCD tvs and Plasma tvs shops.
Aug 17, 2011 | Toshiba 52HL167 52 in. LCD HDTV
Toshiba satellite A200 - press power to turn on the machine and get blank screen and 3 beeps then nothing. Computer was left in sleep state for approximately 2 hours and now refuses to wake or reboot...
HI
Try to unplug the power supply and take the battery out. so it means there is no power going to the laptop. now press and hold the power button down for approximately 1 minute.
After that put the battery in and plug the adapter back.
Try to turn the laptop on most probably it will come on
If it still does the same thing contact ur laptop manufacturer
Jul 18, 2010 | Toshiba Satellite A200-16J01D Notebook
Toshiba a215-s5837 problem, ac light only flashes
You may have a bad battery. Many times laptops will not work if the battery is faulty. The first step would be to replace the battery with a new one.
Second Step: If the battery is working, then you may have a faulty AC power supply. It may be enough power being brought to power up the LCD light, but not the computer.
Third Step: Yoru mother board circuitry could be bad in the sense that some circuits are broken or the power conduit is not supplying the power to the rest of the circuits on the board.
If you are not a professional and able to troubleshoot in this manner after testing the batter and AC power supply, then I would suggest taking the laptop to a store for them to test the circuitry flow of the mother board.
Dec 30, 2009 | Toshiba Satellite A215-S5837 Notebook
My Tecra Toshiba will not turn on or off, even plugged in.
Yes it is. And, it is highly recommended that you remove the battery if you're going to use your laptop for more than 1 hour. If you keep your battery in and have the laptop connected to the adapter, the poor battery is going to be charging/discharging so much that its life is greatly shortened. Also, this is what causes dead cells in batteries.
You might possibly have an internal power supply problem.
But, go ahead - remove the battery. See if it helps.
You also might try letting the battery charge for 3 hours with the laptop off.
Oct 12, 2009 | Toshiba Tecra A1 Notebook
Power problem
How old is the system? It is possible that the drop with the power turned on caused a surge that damaged the internal power system.
Make sure that you have let the new battery charge for at least 8 hours and then see if the system will run off just battery power. The green light on the power supply means it is getting power and the amber light on the battery means that it is being charged. it shoudl go to green when fully charged.
After a full charge and the system will not run just on battery, then you have a faulty power system on the motherboard. That requires bench time and may not be worth the costs to repai, but that that will depend on the skill of the tech who checks it.
Jan 01, 2009 | Toshiba Computers & Internet
Toshiba laptop power light on but not working
Try this.Your VGA is problem or your battery is fully charge down.so please fully charge your battery atleast 8 hours and then press your power switch.it will on your loptop system.
plz Call 09944377607 V.RAJA
Jul 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
109 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
