Question about Xerox Phaser 6250DP Laser Printer
PAPER CRINKLING AFTER PRINTING MORE THAN ABOUT 2-3 PAGES THE PRINTS COME OUT CRINKLED AND VIRTUALLY UNUSABLE - BUT NO JAMS. ANY IDEAS WHAT MAY BE CAUSING THIS? THANKS LYN
    President:
  • 2,072 Answers
First check the paper path for something in the paper path. Staple, paper clip, etc, causing the paper to twist. Reseat the imaging unit and see if the transfer unit is seated properly.
But, What sounds most likely is that the fuser needs to be replaced. The rollers are most likely getting pretty bad inside that unit.
If I recall correctly, it is in the $200 range to replace.
Posted on Feb 16, 2008
HP 4250 SKEWING PAPER
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
Why would paper be jamming or getting stuck on right side with black ink every time?
The rollers that advance the paper could have been messed up by the key, therefore crinkling paper and not advancing in proper timing with the ink. It also could have busted of the plastic gears in modern day printers.
Apr 24, 2012 | Epson Workforce 610 All-In-One InkJet...
Had this for less than a year and now as it prints it sometimes jams and when it does work the printed image is crooked. Seems to be picking up the paper unevenly.
There is probably a crinkled piece of paper stuck in the paper path somewhere causing an alignment issue. Open all the access panels you can and check everywhere for a small piece of paper. Check really good as this issue can be caused by a VERY small piece all folded up.
Aug 08, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Dell M5200n Printer is crinkling Envelopes
If you have the option to print in Horizontal or Vertical feed, try the Horizontal option and be sure the feed guide slide is not too tight against the envelope.
Feb 24, 2009 | Dell Office Equipment & Supplies
Printer problem
The HP DeskJet printer will not print, it prints only partial pages, or produces ... remove the scanner, remove the printer driver, and reinstall the printer driver with all programs and ... the paper out of the printer after printing is finished. If one, or ... the kicker feet on your printer are broken, have the printer serviced. ... In tray only when the printer is not printing. Adding paper while printing can cause paper jams. Do ...
Jan 17, 2009 | Office Equipment & Supplies
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
HP Laserjet 2200 Keeps Spewing Out Blank Paper
sounds like it has a solinoid that is stuck open.
Dec 16, 2008 | HP LaserJet 2200D Printer
Prints a couple of pages - then jams
Well, for now it seems to be fixed - I opened up the paper tray and there is a little part that grabs the paper on the front of the tray - kinda sticky - I just took a paper cutter and put a couple of scratches on it and it is grabbing the paper for now. I do have some of those to use for replacements - but I had just changed it about a month ago and don't think it needed to be changed out again - they usually last quite a while. So, we'll see how long this lasts. We do a lot of printing on this thing and it has been a great printer - maybe we are just wearing it out!
May 20, 2008 | Ricoh CL4000DN Laser Printer
Martin Yale Paper Folder Problem
Im not familiar with a paper folder but if its anything like a printer, it probably has a maintenance kit you can buy or you may have to replace the rollers. Alot of the times they have a rubber grabber that wears out or a roller that gets dirty and doesnt catch the paper evenly and pulls it through at an angle, crinkling it. Check for debree or paper particles that may be floating around inside.
Jan 02, 2008 | Computers & Internet
Xerox Phaser 6250DP Laser Printer Logo
219 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
