Question about JVC AV-65WP55 65" Rear Projection HDTV-Ready Television
Can't get hd
Try the DVI connection with new hd dvd but nothing comes out only worked one time did not work anymore I know i put the right settings on dvd because it worked before but as now is not working bought two new sets of cables and didn't work.
  • 1 more comment
  • ozzo Feb 17, 2008
    toshiba 5000 i Know there is some thing wrong because it was working i saw a movie but now it seems like the dvi doesn't detect the signal from the dvd
  • ozzo Feb 17, 2008
    i have two brand new dvd players
  • ozzo Feb 17, 2008
    it only works with the regular input like red,white and yellow inputs but not with the HDMI input but it worked before
    Genius:
  • 3,587 Answers
Hmmm..so there's no signal from the TV DVI connection? what DVD are you trying to drive with this connection?
Posted on Feb 16, 2008
  • 2 more comments
  • Patrick Michaels
    Patrick Michaels Feb 17, 2008
    ok..that's not a good sign. Does the DVD appear to be working at all. The issue may be there, instead of the tv..any way to check the output of the Toshiba for certain good operation. That's a lot simpler than troubleshooting the JVC..
  • Patrick Michaels
    ok..so...now it's a signal compatibility issue with the DVD's and the TV...This will take a little research, with the input/output specs. I suspect that there's a mismatch between the devices(might be signal impedance, but I suspect a more detailed issue). I'll look into this in next few hours, and see what I come up with. Seems odd it was working ok. I'm assuming that neither of the DVD's are functioning with your JVC, correct?
  • Patrick Michaels
    ok..so we're talking about the HDMI connector..that helps a ton..back soon.
  • Patrick Michaels
    ok..you may not like this, but here's what I learned. The JVC HDMI, according to the published materials from their site(look in support/knowledge base) are only compatible with JVC compatible HD units. This is NOT unusual, since the whole HD situation is in flux, with everyone trying to grab market share.
    Toshiba's website, professes that their product is compatible with ALL HDMI compatibility connections.
    The rub? No one is adjudicating this on a standards level. The EU(you) is the only person that appears to have the option to find out what's compatible and what's not.
    And there are no HDMI converter boxes or technologies.
    My recommend?
    The DVD's are cheaper than the TV. don't know which one you bought first, but I'd see if there's a JVC DVD HD player available to swap for one of your Toshibas.
    I really and truly see this as a major issue for HD adoption, but then, what do I know, eh?
Connect the hdmi out put of a bush hd set top box
its telling you that you cant use the format that your source is set up for .. like 1080P wont play on a monitor that wont support that ..also hdmi requires an exchange of information between units before it will allow 1080 resolution (thats to prevent recording of high resolution material) the adapter may block that exchange .. if you set the source to 720 or less resolution then its likely to start working .. problem is .. if you cant see it how do you set it .. if your remote has an obvious button for that then you can just try selecting different modes and wait 10 seconds to see if it works .. if its not obvious then perhaps you can temporarily use svideo or composite in order to set up the source machine ..
Jan 27, 2010 | Televison & Video
DVI-HDMI not working with Sanyo Z2
HD comes as 720p and 1080p - the Sanyo will cope with 720 but not 1080 full HD - check the specs in the manual. You should have a DVD output setting for screen mode.
Sep 07, 2009 | Sanyo PLV-Z2 Multimedia Projector
HDTV on Mag LT776s
that monitor wont produce the 1280x720 resolution. It isnt hdtv ready
Aug 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
2232bw samsung DVI in problem
There is nothing broken, but you must become aware of the different standards in DVI connectors.
1)DVI-D which you have, does not have the 4 analog control pins around the alpha bar meaning it only works on digital devices.
2)DVI-A only has the 4 control pins and no bar, as well as a total of only 9-10 pins altogether. This is designed for analog only, and rarely see it anymore.
3)DVI-I stands for Interlaced, meaning it can work both ways, but will not fit in monitors that are set up for DVI-D because the analog pin sockets do not exist.
You can get more detailed by counting the pins in the rectangular area, if you use all 24 pins you have what is called a Dual-Link cable, so it can support resolutions over 1920x1280 if you have about 9 pins missing it is single-link and is limited resolution.
Jun 08, 2008 | Samsung 226BW Monitor
BenQ PE8700 DVI problem
Hi guys
All that needs to be done is a firmware upgrade.
This can however only be done by a BenQ Approved Service Provider because if the person doing this makes a balls-up the Projector will be dead as a doornail.
Mar 27, 2008 | BenQ PE8700 Multimedia Projector
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
HDMI to DVI Cable
I had a similar issue, try adjusting the advanced settings on the DVD player.....I can't recall which settings it should be on, but when I adjusted them on my upconverting DVD player everything worked fine after.
Dec 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
ILO 26 HD TV
We bought one as well, sometimes it comes on and sometimes it don't. I think walmart needs to refund our money. They knew they were a bad deal since they don't even carry them anymore.
Nov 12, 2007 | iLO 2600 Television
Hp hd dvd player for desktop wont play hd dvds
I had this problem. Turned out that I was using a DVI cable to connect my monitor to the video card, but my monitor was not HDCP compliant. Most HD-DVD's require the monitor to be HDCP compliant for digital output (i.e. over DVI or HDMI connections). Alternately, you can connect to your monitor via its analog (VGA) input instead, but you won't get HD output. I was able to do this using a VGA cable along with the VGA-DVI adapter for the video card output.
Cyberlink has a tool you can run to see if your system is capable of HD-DVD output. http://www.cyberlink.com/multi/support/bdhd_support/diagnosis.jsp
When I ran it, it gave me a red flag telling me my monitor was not HDCP compliant
Aug 05, 2007 | Pioneer VSX-D511 Receiver
JVC AV-65WP55 65" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
