Question about RCA F25432 25" TV
NEED ASSISTANCE Good Night Sir, I have a RCA 25'' TELEVISION CHASIS #CTC203AD5 MODEL # F25442 WHICH HAD POWER SUPPLY PROBLEM.I FIX SAME AND TELEVISION START WORKING BUT NO VOLTAGE COMING OUT OF FLYBACK FOR HEATER,I CHECK EVERYTHING AND ALSO CHANGE VIDEO IC,EVERYTHING ELSE WORKING BUT NO HEATER VOLTAGE. I SUSPECTED THE FLY BACK IS BAD IF SO PLEASE HELP ME WITH NUMBER FOR FLYBACK
    Problem Solver:
  • 15 Answers
Here is the infomation you need...
Posted on Feb 16, 2008
I have a RCA 25'' TELEVISION CHASIS #CTC203AD MODEL # F25432 the problem no power, WHICH no 12volt on rely but the h-out good.I CHECK EVERYTHING AND ALSO CHANGE VIDEO IC.can you hlep me pls
Posted on Aug 24, 2008
  • 56 Answers
Did you check the heating points on the tube???I don't think that the FB is bad first you should check a resistor for the heathing.I'm not familiar with the RCA but resistor is about 1ohm.You can also get a 6,3 V for heating from other source and then try,of course you have to disconnect original wires.Then if it works take a piece of isolated wire long enough to get this...Sold one side at the heating point on the CRT board then the other one push trough the ferith of the FB make three or four circles around the ferith and then sold it to another heating point on the CRT board.I did this many times and t works,but I still thing that there is a dead resistor on your way from the FB to the CRT board.
Is the RCA F25442 model TV a ATSC TV?
Check this site to download the user manual to your TV. It have all details.
Mar 27, 2013 | RCA F25442 25" TV
Remote control issue
Here is the part number for you remote control
Part Number 242778
and the link to get it
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=3300649&smodel=F25442
Apr 19, 2009 | Televison & Video
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
Seeing red !
I had a television that went to a bright shade of blue.A friends neighbor worked for sony television plant where the new tubes came down the assembly line.His job was to make sure tubes were working fine,if one color was dominant then his job was to smack the front center of the tube with a rubber mallot to fix the problem.He suggested i try that with my tube while the set was on.It worked and solved my blue problem.Apparently he explained,the gun connections in the tube came loose and to fix it was to smack it this caused the connection to reweld itself.For you I would use the palm of an open hand and smack the tube dead center with a good hard smack.Dont be afraid of breaking the glass because its very thick and strong.Give this a try.Hope it helps.Good luck!
Oct 31, 2008 | RCA F25442 25" TV
Fuse locations for RCA Scenium HD65W20
there are 2 fusable devices in this chasis dt307 they are f14200 and f14100 fl200 6 amp 125 v is located Power supply pcb. left rear chasis. f14100 3 amp 125v dm1 power supply pcb left rear. Does the unit have no flashing light... good luck on your troubleshooting and if you need any help contact me via email at the my shop at willie@fordtv.com
Mar 03, 2008 | RCA Scenium HD65W20 65" Rear Projection...
Rca projection tv has sound,no picture or OSD
The 169 is an old chasis but a good one. Many chronc problems can cause these symtons. No high voltage because of bad flyback, or HV spitter defec is the most likely, but there are chonic caps that fail in the power supply as well. This problem will most likely need the assistance of a qualified service professional.
Feb 10, 2008 | Televison & Video
Squealing set
It looks like an output transistor problem. You can't fix it by yourself; you will need to call a service. It will cost you at least 100$, so consider buying a new one good luck
Nov 11, 2005 | RCA F25442 25" TV
RCA F25432 25" TV Logo
154 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
