Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
Serious problems with an Asus M2N E SLI motherboard.
I tried to build the following system:
AMD Athlon 64 X2 6400+ Black Edition
Asus M2N E SLI
XFX 8500GT 256MB
2 X 1 Gig Kingston PC2 5300
Thermaltake Toughpower 850W
When it is all put together just nothing happens its as if the power button where broken but it isnt because it still switches my old hardware on, a small LED light on the motherboard lights up when i switch the power supply on. I have tried the CPU on another motherboard and the same thing happened (MSI K9MMV). I then tried another CPU a cheap AMD sempron and this didnt work either. I have trioed multiple PSUs and still no change i'm becoming desperate any ideas what it could be? thanx in advance.
I just built a system with an Asus M2N-SLI Deluxe MB. It powers on for about 5 seconds then shuts down. I am a patient person but this has me at wits end.I"ve tried everything including disconnecting everything on the board including the HDD and optical drives. I even disconnected the fans. I have tried it with out video and ram.I have DDR2 800 mg ram. I have 2 meg, and tried it with only one meg and i've tried it in all the slots. I hooked up another power supply to the board and it still does the same. I have a 680 Wayy PSU. Anyone have any ideas?
Oh, I also removed and re-installed the processor.
Just to let you know that what BIOS is in use in that motherboard does not support Athlon 6400+. U have to upgrade your BIOS to have full support for your prosessor.
Posted on Sep 08, 2008
    President:
  • 2,351 Answers
I understand how this must be driving you nuts. What I am going to suggest might sound stupid but I have to ask. After your assembly was finished (1st time around) did you check the 4-pin ATX + 12volt connector was correctly & fully inserted into the board? Pg. 2-28 section 6. in your manual? Did you add thermal grease to the CPU. A bad pin on the CPU will give you this symptom. I completly understand if you do not agree with this next part but it is extreamly important you go with it. Take the static bag your board was wrapped in & lay it on a table. Place a piece of foam on the static wrap & place your motherboard on the foam. You can use books instead. Connect your PSU, CPU heatsink & fan, Hd & video card & 1dimm to motherboard. Connect mouse, keyboard & monitor.
Check that PSU is set for 115v (small red slide switch near the off/on toggle switch). Plug in the PSU to outlet.
If the green led on board lights up you have power to board. This is known as a standby led. If it's not on, flip the toggle switch on the PSU to on.
Use a pen to short the power switch. This will turn on the board, no different than you pressing the power button on your case. Goto pg. 2-30 in your manual. Find PWRSW two pins. If the system starts up than somewhere durring install the board was shorted to the case.
Posted on Feb 17, 2008
Will an Asus m2n-e sli run an AMD Athlon X2 7850 2.8GHz am2+
As you can see here
http://www.cpu-upgrade.com/mb-ASUS/M2N-E.html
if you have the correct BIOS, yes.
Dec 24, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
have you tried removing all other hardware like your graphics card and all other peripheral cards even memory and booting to see and eliminate all other components?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Support processor for upgrade to higher processor
This are the comptible processor that you can use for this motherboard if you plan to do a upgrade on it. AMD Athlon 64, AMD Sempron, AMD Athlon 64 FX, AMD Athlon 64 X2
Here is a link that contain all the details about this motherboard.
http://www.dealtime.com/xPF-ASUS-Asus-M2N-MX
Aug 04, 2010 | ASUS M2N-MX Motherboard
What amd cpus does this mobo support? are there any that I can get off newegg for this mobo? and which sli connector should i get from Asus? like what length?
939 pin Athlon 64 X2 / Athlon 64 FX / Athlon 64 are the supported CPU's.
For the SLI connector, it's a 2 1/2 inch connector. (63.5mm).
Oct 26, 2009 | ASUS A8N-SLI Deluxe Motherboard
No video
could be that the drivers are not correct for the monitor/videocard that you have set up. have you tried downloading some newer ones from your monitors manufacturer?
May 27, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Motherboard Issue
Hi Tomokato,
This maybe nothing but the first thing I checked is the CPU.
Supported CPU list through Asus web site for M2N-SLI
(Click on this link). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=M2N-SLI
The first supported 64 X2 is;
Athlon 64 X2 3600+ (CU),512K,65W,rev.F2,SocketAM2
Second CPU supported;
Athlon 64 X2 3600+ (DD),1MB,65W,rev.G,SocketAM2
The CPU that you are using is not supported.
Since this is a new CPU, you might be able to exchange it for the Athlon 64 X2 3600+ (CU),512K,65W,rev.F2,SocketAM2.
Link to Asus main web site for M2N-SLI.
http://support.asus.com/download/download.aspx?modelname=M2N-SLI&SLanguage=en-us
Suggest you add the above link to you're favorites.
Even you're memory is not supported. As seen in user manual page. 2-13.
Have more questions, feel free to ask.
Mike
May 01, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
try the board with out memory and hard drive.
Do fans run?
Anything?
Powering up but nothing happens ?
did you install the motherboard drivers using the CD which came with it?
Sep 28, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
488 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
