I wash doing was and the machine first gave me the error code of E20 and their was water in the bottom of the basin. We cleaned out the water lines but still could not get the washer to start. It just sounds like the gears or something is not catching to spin the washer. I unplugged the washer and then try to start it again but this time I got the error code of E41. Can any one help with this?
If your machine is stuck on the drain sequence or you read error code E20, the filter basket is probably clogged:
You will need a pair of slip-joint pliers and a Phillips head screwdriver.
Before beginning any work, make sure to unplug the machine from the electrical outlet.
**Note: It may be easier to perform this task with the washer lying on its side; therefore it may be necessary to disconnect the water lines from the machine.
1: Take off the front kick plate (two screws at the bottom of the machine).
3: There is a black accordion hose with two clamps.
2: Have a towel ready to catch the water that leaks.
4: Remove the clamps at each end to access the filter basket.
5: Stick your hand inside the hose and remove the plastic filter basket (it will probably be clogged with hair, lint, fabric).
6: Thoroughly clean the filter basket and remove all debris from the inside of the black accordion hose.
7: Replace the filter basket.
8: Reattach the black accordion hose at both ends.
9: Secure the clamps at each end of the hose.
10: Wipe up any water that may have spilled inside the machine.
11: Reattach the front kick plate with the two screws removed earlier.
12: Reconnect all hoses before plugging in the machine to the electrical outlet.
** This took me about 30 minutes from start to finish.
solution from dtgray was absolutely perfect (for me anyway). it is a tough chore to get in there and work the clamps but with persistence i got the them off, cleaned the filter basket (coins, nails, dog hair!) the machine is working again now. my complaint is directed at Frigidaire. seeing that the filter basket clogging seems to be a problem for many, they should have designed the machine for easier access for routine maintenance. thanks again dtgray. you saved me major $$ as the repair guy was gonna charge me $100 minimum just to come out to my house.
dtgray2430, you are a life saver!!! Your solution and steps were perfect. If you tilt the washer to access the opening on the bottom, tilt washer on its right side. The clamps were definitely a challenge (both taking them off and on), but putting everything back with the clamps was worse. Cleaning out the black accordian, I found a tube sock, 2 metal wires, a small spring, and $1.25. I also suffered the 2 cuts that everone seems to manage. It worked, and my wife was never happier to do laundry.
Awesome! I found pillow stuffing and... You know those all-in-one washer/dryer sheets that have detergent built in? Yep, that's what I found! So those go right in the trash! I was most nervous about reattaching the hoses. I'm afraid i didn't get them on right... But we'll see. Took me about an hour, with the help of my son, and I didn't cut my hands at all. Thanks so much for the instructions.
Thank you so much for the great tips, Dtgray!!! Wow - I also got a $1.25 out of it, a lot of crud, my missing house key.... and no cuts for me! I cheated, however, and only took off the clamp to the accordian. I have little fingers, so I donned my surgical gloves, and extracted the crud! Thanks again!!!
dtgray2430 saved my machine. I was ready to buy a new washer but decided to check online for some advice first. My error code was 21 and clumsychris had exactly the same problem, different code. I am now $2.34 richer and found out where the underwires to my bras have been going. Thanks for the perfect solution!
E41 =Control board thinks the door switch is open.
1. Remove the door lock assembly and
measure the resistance of the PTC.
Shorted or open. Defective door lock assembly.
Around 1500Ohms. Defective control board.
READING ERROR CODES:
1. Wake the washer by pressing any button.
2. Wait 5 seconds.
3. Press and HOLD the Start/Pause and Cancel
buttons simultaneously. As long as the buttons are
held, the failure code will appear in the display as an
E followed by two numbers, a number and a letter or
two letters. The controlwill beep and the Door Lock,
Wash, Rinse, and Final Spin indicator lights will
flash.
Quick Check
If there is no error displayed and thewashermomentarily
starts then turns back off:
1. Listen for a relay closure inside the motor control
shortly after the Start/Pause key is pressed. If this
happens, themotor control has power.
2. Check the 5 pin connector wiring between the
console control and the motor control.
NOTE: During normal operation, the displaymay show:
“SAn” - deep clean (Sanitary Cycle)
“cd” - cool down (Sanitary cycle)
“do” or “dr” - door problem.
“Err” - an error has been detected.
“LOC” - control lock is activated.
“PAU” - cycle has been interrupted.
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin
Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the
LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and
Start/Pause buttons until LEDs start sequentially
chasing, then release buttons.
My washer gives me a E20 error message and will not drain the fabric softner...what can I do? Is this something I can do on my own or will I have to call a repair man?
The advice on this problem is dead on...access the the drain filter (black plunger looking like piece) where the drain hose exits the unit at the bottom of the machine...there is a hole in the bottom, no need to take off the back...turn unit on it's side...clamp with one screw that seals the gasket/plunger piece requires patience to re-attach but it was a very simple process...took about an hour from beginning to end...well worth doing on your own!!!
Six screws on the back of the unit removes a panel. behind that its easy to see the hose at the bottom of the drum. remove a couple of clamps and shopvac out the blockage. it was pretty simple and saved me the call to the appliance repair dude! **** it frigidaire
This worked perfect. you only need to take off the one black hose that goes to the pump. Things are sharp in there i got two badly cut fingers to prove it. On the plus side, I drew blood,fixed the washer, now my wife thinks i am a DIY god. can you say booom chika boom boom.
The solution to the above was dead on. Even down to the two cuts. One additional thing you should do is there is a plastic lint trap up inside the black hose which with a little of patience you can get out and clean it well.
Thanks for saving me the service call.
Excellent Advice!!! Thank you... My unit has a removable kick plate in the front. two screws and a tilted back unit and I am now $2.19 richer and an old sock too! Thank you for saving the repair call!
Jacaramo
The drain was clogged up under the drum, found a quartet, dime, hair clip and a handful of lint Thanks
BE CAREFUL the inside of the washer is extremely sharp! otherwise good advice
Everything worked great. I noticed the whole botoom of washer was rusted and rotted, there must have been an existing leak. When I re-installed the black accordian piece, the large mouth with the screw on clamp is now leaking. any advice, new clamp maybe?
SOURCE: Frigidaire Front loading washer error codes E41 and E20
Hi
E20 is a drainage error. If there is water in the drum make sure the discharge pipe at the back of the machine is not kinked or blocked. You should also check the pump filter is not clogged - this is behind the front panel underneath the drum at the front of the machine.
E41 = Control board thinks the door switch is open. This points towards a faulty door switch on the machine.
Hope this helps. Please remember to rate my answer. Many thanks.
Hello Diane Snow, thank you for your inquiry!
I understand that your Frigidaire washer is displaying "E20" error code. The "E20" error code means water is not pumping out fast enough. First, you want to check the hoses for restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would suggest seeking assistance from a professional technician for proper repair. I hope this is helpful. -Matt
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
I washed an area rug and the washer would not drain from the wash cycle. E20 code appeared. Water was left in in the bottom of the basin. I stopped the machine and tried to drain/spin. I just hear a grinding noise - nothing happening on all settings. All lights are on and door is locked when I set any setting on the washer. I have checked my water lines, screens, and drain hose - all clear.
We have the same problem. We got the exact same sequence of codes. We have the code E41. How do you remove the door lock assembly?
Water in bottom of shell, error code E20, got out my level-washer was not level, lowered feet, rechecked with level=no problem. Hooray! Then today, things are going along fine when, error code E20 comes up, again-this is after it sucessfully washed and drained two loads. I am very cautious as to NOT overload our washing machine with clothes or rugs etc,. Checked washer to see if perhaps it was again uneven-nope-perfectly level-WTF?! This washer is less than 3 months out of warranty (Murphey is up to no good again)...any ideas other than making it a large planter in my yard?
Water will not drain and E 20 is flashing.
my washer is reading e 20 as well how do i get to the drain under the drum?
how doesw one get up under the washer drum? sorry my frined is kinda Blonde when it comes to fixin things that are not People!
