Question about Sony ECM-HS1 Gun Zoom Microphone
New noise after having traviled my sony ECM-HS1 produced a constant noise in the right side both when listening to it record, the quality of any recording is severlie deminished, the hiose gets worse when torning the gun function on. I just tried to record a house concert with the ECM-HS1 mic on my sony digital 8 camera. In both the gun and zoom modes there is a constant hum that ruins sound recording. This is somthing new. I've had the mic for six years. I've cleaned the heads several times and have tried using diffeerent brands of tape.
    Genius:
  • 3,587 Answers
Sounds like a ground issue to me. that sounds like either 60 cycle hum, or a loose or broken ground. You can probably do an ohmmeter check, first, with no power, and see if you have continuity. That's not unusual for mikes of the seniority of your equipment.
Posted on Feb 16, 2008
I am trying to record my old vinyl records to a CD. I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling...
Complex? Traditional turntables need PHONO preamaplifiers (in receivers) to PREAMPLIFY the minute signal they produce to something useable.
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
Just curious, priorto the arrival of the RCD, how did you play or listen to the turntable?
Feb 26, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Constant low grinding noise from right side especially when turning let. everyhting is tight and just had the tires changed. it did not change anything. can it be the wheel bearing?
maybe bearings, but I would check and make sure that the metal cover or the pads are not causing your noise on the right side. You may want to jack up the front end and turn you wheel hard left and rotate the tire and see/listen. Good Luck Tim
Jan 09, 2011 | 2002 Chevrolet Silverado 1500HD
I am lloking for replacing the foam covering on the microphone, can some one help?
If you're referring to the "wind breaker" which is the foam covering commonly used on microphones, you can pick up wind breakers from most music stores for just a few dollars.
Oct 25, 2009 | Sony ECM-HS1 Gun Zoom Microphone
Whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Sep 28, 2009 | Samson C01U - USB Studio Condenser...
We have a problem with one of our DS-4000 recorders that is producing a popping noise at times in the recording. We thought it might be something when it was being transmitted over the server to the...
Make sure the recorder is not being used near a cellular device or transmitter.If it isnt,definitely send it to Olympus for service as there is nothing mechanical in the recorder that would cause this.
Aug 11, 2009 | Olympus DS-4000 Digital Voice Recorder
User Manual
javascript:moreinfowindow('http://www.docs.sony.com/reflib/docget.asp?manualid=8598&template_id=&region_id=1&DL=',600,560,10,10,'Manuals')
Dec 26, 2008 | Sony ECM-HS1 Gun Zoom Microphone
Sony ECM-HW1 Professional Microphone
it might voice automated and the flash could be pause until unpaused some recording devices have a constant light and some have a flashing light when recording check to see if pause is enabled
Apr 27, 2008 | Audio Players & Recorders
When I record using my microphone I hear "pops" and 'hissing" when listening to the playback. What can I do to prevent this? The moment I plug in an external mic (a Sennheiser) a low level rumble starts...
These mini video cameras are great for a lot of reasons, but the drawback is the tiny buttons and connectors, like the microphone input. It's probably actually a stereo microphone input.
If it is stereo (check the manual), then try using a stereo adapter, where you plug the adapter into the stereo mic input on the camera, and then plug the single microphone into only one side of the adapter ... then copy the audio to the "missing" side later in production ...
Alternative: record the audio separately onto a decent quality audio recorder with proper microphone jacks, then find the corresponding audio and synchronize it in software production. This is often how professionals do it, and one of the reasons you see the familiar "clapboard" snap at the beginning of movie shoots ... clapping your hands on camera right before you shoot will give you a visible action that will correspond to a peak in the audio soundwave that you can match up to synchronize the audio once you put the video and audio into your computer.
Another alternative - new item these days is an audio interface for video cameras that is basically a small black box that mounts onto the video camera or tripod, plugging into the tiny input on the camera and providing XLR microphone inputs ... just go to Borders and pick up any magazine on video production, you'll see them advertised all over the place ...
Good luck, hope I have helped in some way!
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Dec 18, 2007 | Sony Handycam HDR-SR1 HD Camcorder
No sound on new recordings
i thnk hed controler is out
please you must 1 st controler the video head part
Aug 11, 2006 | Sony Handycam DCR-TRV900E Mini DV Digital...
Sony ECM-HS1 Gun Zoom Microphone Logo
103 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
