Question about ASUS K8N4-E Deluxe Motherboard
Connecting audio There is a jumper on the pin connector labeled audio on my motherboard that prevents me from connecting it to the front of the case where there are audio plug-ins for headsets. Can I take this off of the pins and connect it? (I can't find my manual)
    Problem Solver:
  • 16 Answers
I took the liberty of finding you your Manual:
http://dlsvr01.asus.com/pub/ASUS/mb/sock754/K8N4-E_DX/e2009_k8n4-e_deluxe.pdf
Also, to spare you the trouble of going through it, here's the only reference you need:
[img]http://img301.imageshack.us/img301/9752/audioasusrc7.jpg[/img]
As you can see - YES - you can remove those and connect your front panel.
Hope this helps. Rate me. Thanks.
Posted on Feb 17, 2008
How to connect the front penal with motherboard
Hi.
To connect the front panel of your case with your motherboard, it is quite easy.
If you have the motherboard manual, I will help you on connecting the cables to the motherboard.
In summary, the pins or connectors for the front panel are on the same spot of the motherboard.
If you don't have the manual, check on the motherboard, THere are like 8 or 10 pairs of pins which are labeled.
The speaker cable is a 4 pin conector. See the speaker's pin on the motherboard.
The Power cable will fit into a 2 pin connector.
The HDD Cable as well
The reset. too..
The colored cable is always +, the black cable is always -
The + usually goes on the first pin of the assigned connector.
For example: motherboard connector is:
The cables goes on the Jumpers area.
You will see somthing like this:
Hope that helps
God Bless You!!
Remember to rate this solution!!
Feb 21, 2011 | Intel Motherboard
How do i wire-up the: ( eg. power l.e.d., HD led, reset led ect. to the board
The various wires from the case front panel should be labeled to indicate power LED, HD LED, etc.
The motherboard front panel jumper pins should be grouped together and the pins should be labeled to indicate PWR, HD. RST etc.
You can go to the motherboard manufacture's WEB site to download a diagram of your model motherboard and it will show all the locations of the connecting pins.
Jan 30, 2011 | Chaintech MP4M266A Motherboard
I want to know where the connection points are on the motherboard for the front mic and audio jacks. I have a epox ep-5pdaj motherboard. Will you send me a diagram please.
close to the back panel of the mainboard, below the back i/o connectors and 3.5mm audio jacks.
You need to remove the two jumpers from the pins, this is where you connect the front panel audio connector, if your case has each wire separate. then please look at this webpage http://www.intel.com/support/motherboards/desktop/sb/cs-015851.htm look at the part "For AC97 Front Panel Audio" PIN 1 should read MIC. If not, then scroll down, you are reading the wrong part of the page.
Aug 07, 2010 | EPoX EP-5PDAJ Motherboard
How to connect audio from motherboard p5s800
It is Asus P5S800-VM motherboard. Download the manual from Asus, click the link provided;
http://www.asus.com/Search.aspx?SearchKey=P5S800-VM
You'll need to download and install Adobe reader to view the manual;
http://www.adobe.com/products/reader/
Turn to page 1-29. Section 11. Front panel audio connector (10-1 pin FP_Audio1). Notice there are two jumpers. One across pins 9 and 10. Another across pins 5 and 6. Pin one is marked, AGND and pin two is marked MIC2. ECT.
This is default setting when using the rear audio jacks. You can not run rear audio and front audio at the same time. (So pick one or the other). To run front case audio remove the jumpers and connect the I/O cables to the FP_Audio1 pins. There is a work around. You can buy an adapter that will split the audio from the rear allowing you to connect secondary audio and mic ports. Open the link provided;
http://www.cablestogo.com/product.asp?cat_id=2009&sku=40422
You can buy these locally. To connect the FP_Audio remove the jumpers and connect the I/O cable to FP_audio pins. Use Adobe reader and zoom in. You'll find each pin is marked.
Cheers'
Mike
Mar 08, 2010 | Computers & Internet
Sound cable connection
Look more closely at your motherboard, for a 4-pin "PC Speaker" label.
The "HD Audio" is _OUTPUT_ (left front, sub-woofer, right front, left back, right back) to Surround Sound speakers.
Dec 31, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Need manual or instructions for connecting frint
The model of the motherboard is actually more helpful. Most of the FP Connectors will be labeled, i.e. HDLED +/-, PWR LED +/-, etc. Loook in your motherboard manual for which pins they relate to.
Dec 24, 2009 | Power Up 2532 Silver ATX Mid-Tower Case...
Connect wires to the motherboard
Please tell me the model number then I will be able to help you.
Nov 14, 2008 | E-Machines eMachines Desktop PC
Frontpanel sound
By default, the pins labeled LINE OUT_R/BLINE_OUT_R and the pins LINE OUT_L/BLINE_OUT_L are shortened with jumper caps. You should remove the caps ONLY when you are connecting the front audio cable. So, if you are going to use the back panel, you should short the pins mentioned earlier. You cannot use the back panel and the front panel at the same time. If you want to use your headphones using the back panel, short the mentioned pins and connect your headphones to the green header of your back panel audio. If you want to use the front panel, take off the jumper caps and connect the front panel cable. Remember, if you connect the front panel audio cable, you won't be able to use the back panel. If you are going to use the back panel, don't forget to return the jumper caps. Usually the 5-6 and 9-10 pins. Hope this helps.
Nov 18, 2007 | EliteGroup P4M800-M7 Motherboard
Viper MSNV-939 ATX Socket 939 audio connector jumper settings
 u short the pins with jumpers as per the diag
        5    4     3    2    1
       10          8     7    6
in this u short the   5,10  with one jumper &   3,8 wth another jumper
was this helpful to u, give the rating for me
thanks
Oct 15, 2007 | Mach Speed (S755) Motherboard
ASUS K8N4-E Deluxe Motherboard Logo
357 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
