Question about Coby MPC-848 MP3 Player
Factory reset of Coby mp3 player
How do i do a factory reset for my COBY mpc843
does not turn on
  • 4 more comments
  • Anonymous Feb 18, 2008
    when I try to copy it comes up I/O problem
  • Scott001 Mar 05, 2008
    Tried to reset contrast. Now, all I get is colors and no display. How do I fix???
  • Anonymous Mar 11, 2008
    My Coby freezes and turns of by itself. It plays the same songs over and over
  • warrenpack Jul 01, 2008
    MY SON'S COBY MPC843 WONT TURN ON. IT WILL PLAY WHEN HOOKED UP VIA USB TO THE PC, BUT OTHERWISE, NOTHING. WE'VE ONLY HAD IT FOR 6 MONTHS!
  • Anonymous Mar 17, 2014
    I turn it on and a "Coby" screen comes up and I can't do anything, I've reset it 10 times and still no luck
  • Anonymous Mar 27, 2014
    Tried factory reset twice with no results... can't delete anything else, but all 8G are used up
When ever i cut on my mp3 player the lights would flash on and off i have put a new battery in it and the computer will not respond when i put it in the computer
Posted on Apr 04, 2008
U NEED TO LOOK FOR A TINY-PIN-SIZE HOLE USUALLY LOCATED ON THE REAR OF THE DEVICE (MOST MODELS) U WILL NEED A NEEDLE OR SOMETHING SIMILAR IN SIZE TO PUSH INTO THE HOLE. HOLD IT THERE FOR ATLEAST 30 SECONDS AND THIS SHOULD DO THE TRICK TO RESET! HOPE THIS HELPS!
Posted on Feb 20, 2008
How to reinstall os on coby 7" tablet?
Usually on an android device access settings : sd card and storage : select erase all or restore or factory reset and device will be factory restored . If the OS is completely gone you may have to access an image from te Coby website and install from a laptop by cable .
Jun 12, 2014 | Coby Kyros MID80244G Tablet
I want to toke my coby mp3 back to factory settings, and erase all memory, how do i go about this?
To help you here is the user manual:
http://www.cobyusa.com/files/manuals/MP610_MN.pdf
You should make a reset and the format option of your device. How to do it you will find on the page 27 of the manual.
Good work!
Thanks.
gylacz
Jun 23, 2011 | Coby MP-610 MP3 Player
I have a coby mp3 610 4G and it will not do anything i.e. will not turn on, reset, or charge. it simply will not do anything at all but a blank screen
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player should allow it turn on etc & have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Mar 29, 2010 | Coby MP-610 MP3 Player
I cant download music into it
Thry the solution below. If it does not work then you need to reformat. Also you might want to go to the coby website and download a updated version on the firmware and reflash your player. This will set it back to factory settings.
  1. Open Windows Media Player.
  2. Find and click the "Sync" tab. This is located at the very top of the program.
  3. Plug the Coby mp3 player into one of the USB ports found on your computer. Depending on the exact Coby mp3 player that you own, you can either plug the player directly into the USB port or by using the cord that came with the Coby mp3 player. The name of the Coby mp3 player will appear in the top right corner of Windows Media Player.
  4. Click "Library." This link will be on the left side of the program.
  5. Double-click the "Songs" option in the middle of the screen.
  6. Scroll through the list of music on your computer until you find the songs you want to put on the Coby mp3 player. Right-click on the title of the song and a drop box will appear. Select "Add to Sync List." You will then notice the song listed in the column located on the right side of the program.
  7. Repeat the previous step until you're finished putting songs on the Coby mp3 player.
  8. Click the "Start Sync" tab located beneath the list of songs you chose in Step 6. Those songs will then be added to your Coby mp3 player.
Sep 26, 2009 | Coby MP-705 Digital Media Player
Coby mp3
the factory reset is listed in the mp3 player menu's, if not there may be a little pin hole on the side, inset a pen tip and it should factory restore.
Sep 08, 2008 | Coby MP-C883 MP3 Player
Coby Mp3
Try resetting the device by using a pin:
1. The rear bottom right corner there is a small hole, insert the pin, this will reset the device to its factory settings.
Try using Windows Media Player 11 to save audio files to your device it is a free download.
Jun 25, 2008 | Coby MP-C7085 MP3 Player
Coby MPC843
If you want to remove music from your mp3 all you do is just go to my computer on your start program located at the bottom left hand corner once you click that click on removable disk and all your music that you have on your mp3 will come up what ever you dont want just click on it with right clicker and go down to delete.
Jan 20, 2008 | Coby MPC-848 MP3 Player
Coby mpc843
turn up the sound
Jan 20, 2008 | Audio Players & Recorders
WILL NOT PLAY SONGS
What kinda of file is the song? It might only read mp3 fomats. Try fomating th mp3 on the computer and start again.
Dec 21, 2007 | Coby MPC-848 MP3 Player
Coby MPC-848 MP3 Player Logo
937 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
