Question about Creative Labs ZEN V Plus MP3 Player
First Frozen At The Logo, Now No Screen At All
It was first frozen at the logo, then after pushing a paper clip into the reset hole, powering on, connecting and disconnecting from the PC, nothing changed. Even worse, now the screen is totally blank and I can't tell if it's on or off. Help!!!!
    President:
  • 4,402 Answers
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
good luck
please mark the post with a fixya
Posted on Feb 19, 2008
Proscan tablet is frozen
Check for the reset pin hole on your tablet. Get a paper clip and push it 'gently' in the hole and hold it for thirty seconds. This resets the tablet.
Youdon't want to push hard as there is just a tiny button in there that can get dislodged.
Mar 02, 2014 | Proscan Recertified - PLT7035 4GB NAND...
Palm T3 frozen, tried restart in hole, nothing?
Doing a soft reset A soft reset tells your handheld to stop what it's doing and start over again. None of your information will be lost. After a soft reset, a screen appears that lets you reset the date and time, if needed. To do a soft reset, use the tip of an unfolded paper clip (or similar object without a sharp tip) to gently press the reset button inside the hole on the back panel of your handheld.
If a soft reset does not unfreeze your handheld, you need to do a hard reset. Doing a hard reset Only do a hard reset if a soft reset doesn't solve your problem, or if you want to clear all of your information from your handheld. [!] IMPORTANT A hard reset deletes all records and entries stored on your handheld, including the username that identifies the handheld. Before you do a hard reset, be sure to synchronize.
1spacer.gif Press and hold the power button. spacer.gif 2spacer.gif While holding the power button, use the tip of an unfolded paper clip (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld. spacer.gif 3spacer.gif Wait for the Palm Powered™ logo to appear, then release the power button. spacer.gif 4spacer.gif When you see the message that warns you about erasing all of the info on your handheld, do one of the following: blank.gifPress Up on the navigator to finish the reset and show the Digitizer screen.
blank.gifPress any other button to do a soft reset.
Jan 31, 2008 | Palm Tungsten T3 Handheld
Frozen screen on slvania netbook
Insert a paper clip into the hole on the bottom of the netbook if the device seems to be frozen. The hole is next to the battery cover. The system uses solid state memory rather than a hard drive, so the netbook should restart rapidly.
Feb 02, 2013 | Sylvania G-Netbook
How do i perform a hard reset on my palm pda
  1. Step 1 Straighten a paper clip into a single line.
  2. Step 2 Locate the "Reset" button by spotting a small hole on the backside of the Palm Zire 31.
  3. Step 3 Push the power button on the Palm Zire 31 with your finger and hold it down steadily.
  4. Step 4 Push the paper clip into the "Reset" button's hole while holding down the power button.
  5. Step 5 Release the power button once the screen displays the "Palm Powered" logo.
  6. Step 6 Push the navigational key in the "Up" direction to complete the Palm Zire 31 hard reset.
May 26, 2010 | Palm Zire 31 Handheld
TomTom Go720 cannot boot up/frozen screen/no response. Need repair
Try resetting it. Use a pin or straightened paper clip to push the reset button thru the hole marked "Reset" on the bottom. hold the reset for 15 seconds. then push and hold the power button for 5 seconds to complete the reset. Good luck.
Oct 27, 2009 | Tomtom GO 720 GPS Receiver
Creative Zen frozen and Reset has not worked
You probably shouldnt play with any of the buttons really but i know how to fix it. You hold down the slide power for about 5 seconds and poke the reset button with a pen tip or w.e for about another 5 seconds till it restarts itself.
Mar 28, 2009 | Creative Labs Zen Digital Media Player
Frozen Apple Logo
if itunes recognizes the phone use the restore option if not you need to perform a force recovery mode. to do this hold power and home screen buttons until the screen resets when it does keep holding the home screen button and plug in the phone to the computer after a few seconds itunes should see a phone in recovery mode and force you to do a restore. if that does not work you might have a hardware problem and will need to go to a store.
Jan 24, 2009 | Apple iPhone Smartphone
Creative Zen V Plus Frozen on the product title screen
this helped me as after it rebuilds the libary then it always froze on a song let the battery run out!
this worked for me straight away and i had tried loads of other ideas this actually came from the tech guys !!!
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
Feb 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Frozen screen
try holding down the power button for 15 seconds.....
Dec 20, 2007 | SanDisk Sansa e200 MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
82 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
