Question about Canon NP 6551 Black and White Copier
Canon np6025 my copies have lines on the top and bottom. I have adjusted the exposer calibration, and have cleaned the drum unit. I dont know what else to try. The darker I adjust it the more line are produced on the copies and it also gets darker.
  • Anonymous Mar 11, 2008
    error message E 523 on canon copier NP6551
I have a NP 6025 that is jamming from the letter tray top not multi purpose tray. I cleaned the rollers that did not help. its making a grinding noise (best way to describe it) The paper gets jammed at various stages in the input unit I can open the right door and see the paper. Wondering if anybody has any ideas on how to fix this problem....
Sean
Posted on Mar 13, 2008
I just cleaned the old toner out of the drum it was packed full. But the copies are still the same.
Posted on Feb 19, 2008
  • Canon Expert
  • 1,326 Answers
A few questions? How old is the drum unit? Are the outter sides of the drum worn down through the drum coatting? If so, you have to replace the drum and blade. Is this the first time cleaning out the waste toner? But if the drum looks ok, did you clean the optic's" All, six mirrors and the dust proof glass. Do the lines happen before the fixing ass'y? Did you vacum out he drum cavety? Here is one place to look... Take out the "Blanking Lamps" and clean them. That one had me chasing my tail for a while.. Good Luck...
Posted on Feb 18, 2008
When trying to make copies from the Cannon Imagerunner 3230 machine, we keep getting a black line on top of the copies. I tried cleaning the inside but it still appears. What could that be?
Drum Unit, Make sure the scan glass and platen glass is clean. Run copies from glass and document feeder to see if line appears on one or both. Both Drum unit or fusing Film. Will need a copier tech to remove parts for inspection.
Jun 09, 2010 | Canon imageRUNNER 3230 Black and White...
Printing b/w ok but colour is all out of alignment it seems to print all over the place making the copies distorted
pls name the machine model and manufacturer!
Try the color adjustment and calibration if not check the transfer folie, cleaning blade drum units,..
Jan 10, 2010 | Canon imageRUNNER 3225 Black and White...
The streaks are full page on both edges top to bottom and occur with printing and copying.
I suspect the drum unit might done its time.On this model you might find you can do 50000 to 90000 copies on your drum before it is done.First replace the drum.If problem sill presist the fixing unit can be the cause of the lines.
Dec 01, 2009 | Canon imageRUNNER 4570 Copier
Ghost lines horizontally (looks dirty) when making multiple copie
Check the cleaning blade of the OPC drum,the image transfer unit.
Aug 17, 2009 | Canon Office Equipment & Supplies
CANON 1600
Try to clean the drum & shake toner & it's nothing to do with transfer roller for sure , it's your drum unit only . Another thing ,was your drum unit exposed to light for more time than normal , in that case try another drum ,try this i think that will solve your problem
Jul 10, 2009 | Canon imageRUNNER 1630 Copier
Copies fine on bottom, but fade to nothing at top
Could be one of many things. Possible new transfer roller - make sure the transfer roller is not jammed.
Check the developer roller (at exit from toner hopper), to see if it is rotating properly. Check all connections to/from drum and transfer rollers.
This is most likely a dev unit problem. Not sure if dev/hopper and transfer are all in one unit - if so, replace the lot, or you'll be chasing one problem after the other.
Apr 10, 2009 | Canon Office Equipment & Supplies
1/4" weak, blurred line from top to bottom of page on every copy...has new drum, cleaned optics and glass, including **** glass...
hi, if the class is clean and the drum is not bad, this means is the fuser unit role cause this problem, but sometimes the cleaning blade too do this when it becomes bad and it doesnot clean the drum well. to help you trouble shoot this problem do this:
open the document feeder donot put any paper on class, and hit start, let the ,machine copy when the feeder is up and no paper, the copy will come black paper, check it if u still see the line there this means the fuser, if not its cleaning blade or drum.
let me know wat happen and if u have pics will help too.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 10, 2009 | Canon imageRUNNER 2000 Copier
Aficio 1035 Drum problems
if you clean the drum unit, but the copy is dark push the drum unir forward because the luck is not locked
Feb 07, 2009 | Ricoh Aficio 1035 Copier
Canon photocopier 1600 Cleaning Blade not cleaning properly
Perhaps the pblm is not in "the drum unit"... check the mirrors may be are dirty.
Jan 12, 2009 | Office Equipment & Supplies
Lines on the copies
It might be the drum unit, normally there are foreign objects int that unit. Need to take it apart and empty the waste toner.
Jul 10, 2007 | Canon imageRUNNER 2800 All-In-One Laser...
Canon NP 6551 Black and White Copier Logo
186 people viewed this question
old marine
old marine
