Question about Nokia 1600 Cellular Phone
Nokia 1600 - Key #1 Voicemail
When I pressed and held the "1" to enter voicemail there was no greeting or voiceprompts. I beleive I still pressed the "#" key though. I went ahead and entered the deafault Voicemail Passcode. Now apparently the passcode is what the phone is dialing (I'm assuming it should be dialing itself to get into voicemail). Obviously my call cannot be completed.... How do I reset or re-assign the #1 key when I hold it down to enter voicemail??
  • BlueBeer Feb 18, 2008
    Unfortunately this did not reset the number "1" key. It still dials the passcode I entered by mistake.
    Thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Go to setting>restore factory setting>enter 12345
now restart phone
preess and hold 1.
enter the no of Voicemailbox
Posted on Feb 17, 2008
  • Manu Kumar
    Manu Kumar Feb 19, 2008
    go to Menu>Messeges>voive mailbox no>enter the no>ok
  • Manu Kumar
    go to>menu>contacts>settings>voice mailbox no>enter the no>ok
    now press and hold 1
    this is tested on nokia1600
How do I set up voice mail
How to record a voicemail
    1)Call your Voicemail access number, or press its corresponding shortcut key (usually the number "1").
    2)Press the key corresponding to "set your voicemail greeting" or "Set up your voicemail."
    3)Decide whether you want to use an automated greeting, which usually gives out your number and advises callers that you're not available.
    4)Follow the prompts to record and save your greeting.
How to Record Voicemail Message on LG Phones
Nov 20, 2015 | LG Cell Phones
Voicemail change message
How To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
How To Record Your Alternate Greeting (Used when on vacation or out of the office.:1. Press the Check Voicemail key or press the Feature button, then 981
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the Choose softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting.
Nov 21, 2013 | Nortel T7316E 2-Line Corded Phone
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Dec 07, 2010 | Mitel Superset 4025 Corded Phone...
Setting up your voicemail
I bought and Uniden Dect 6.0 phone and the other day I had a voicemail msg but I can't retreive it how can I do that the book doesn't show how to set up for voicemail
Nov 15, 2009 | Lands Phones
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
10. Press the ChOOSE softkey
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Apr 15, 2009 | NorStar Lands Phones
How to set up voicemail on i phone
<<This is straight from TracFone support for setting up voicemail on the Motorola C139....enjoy>>
Thank you for your interest in TracFone Wireless. We are responding to
your recent inquiry.
TracFone Wireless would like to take this opportunity to apologize for
any inconvenience this issue may have caused you.
Your voicemail box has been reset. To set up and retrieve voicemail from
your TracFone:
Press the MENU key,
Scroll to MESSAGE and press SELECT,
Then scroll to VOICEMAIL and press the MENU key,
Next scroll to VOICEMAIL SETUP and press SELECT,
The VOICEMAIL Access Number should be: +17044089979 and press the OK
key (if there is no + sign, please press and hold the 0 key until it
comes up).
If the numbers there are different, press and hold the key below the
word CLEAR or DELETE until all the numbers disappear from the screen.
Then enter the number 17044089979 and press OK.
After programming the Voicemail Access Number on handset, please turn
the phone off and back on.
Then, press and hold the 1 key to auto-dial the VOICEMAIL box to record
greeting and complete setup.
Your temporary password can be 0000, 1111, 9999, the last 4 digits of
your wireless number, or another 4-digit number easy to remember.
All calls made to your voicemail from your TracFone will deduct airtime
units. To avoid being deducted airtime, it is recommended that you
contact your voicemail from a land line phone, by dialing your ten-digit
mobile number. To retrieve voicemail messages from a landline phone,
please follow the instructions below:
1. From your landline phone, dial your TracFone Number.
2. When you hear the greeting, press the star (*) key. If the star key
does not interrupt the greeting, press the (#) key.
3. Enter your password and follow the retrieval instructions.
Please note, if this procedure does not resolve this issue, we would
need to talk with you directly for further assistance.
Should you have any further questions or concerns, please contact one of
our customer care representatives at 1-800-867-7183. For your
convenience, our representatives are available Monday-Saturday from 8:00
AM to 9:45 PM EST, and on Sunday from 8:00 AM to 6:45 PM EST.
Thank you for being a TracFone Wireless customer. We appreciate your
business.
Sincerely,
TracFone Wireless
Sep 16, 2008 | Cell Phones
Would like to change voicemail message in phone
-Dial into voicemail
-Enter password to access system
-Press button for Greetings or Administrative Options menu
-Choose type of greeting
-Press button to change it and record new greeting
-Listen to new greeting and press button to confirm
-Exit system
May 02, 2008 | Cell Phones
Voicemail reset
Norstar Common Voicemail Features To Check Your Voicemail:
4. Leave message
took this from a guide i found, helped me out
Apr 30, 2008 | NorStar M7310 Corded Phone
Nokia 5185
In order to change your voicemail message you need to call into your voicemail system. Voicemail is not actually in the phone but a service where your calls are forwarded to. Most voicemail systems will play the main menu if you press the * key. One of them should be about a greeting. Check with your carrier for specifics.
Feb 03, 2008 | Nokia 5185i
Resetting company voicemail
4. Leave message
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
Nokia 1600 Cellular Phone Logo
1,236 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
