Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
Water leaking from water dispenser
We have been getting a random drip coming from our side door water dispenser. It drips at a pretty quick rate. Sometimes it will stop on its own after dripping 8 oz or more. Sometimes we have turned off the water source. When turing it back on the next day or so, it will not be dripping but eventually will begin again. Haven't determined a pattern.
Any ideas?
Thanks!
Turned water off at the source and then back on. Leak came back after a few hours.
  • Anonymous Jun 17, 2008
    Turned water off, then bak on. Drained water from the system, leak stops for awhile then comes back.
  • hared12 Dec 19, 2008
    I have the same problem. In checking the parts list, the only water valve it shows is for the ice maker. Are the 2 valves combined into one unit? I have model ED5FTGXKQ01
    President:
  • 1,314 Answers
Replace your water valves one for the door disp is leaking
Posted on Feb 16, 2008
We had a leak happen after replacing the filter for the first time on our Whirlpool Side by Side. On page 19 of the Whirlpool Side by Side Use & Care Guide it says air in the lines can cause this problem. Drain about 10 glassfuls of water from the dispenser to get the air out. When you do this you notice that it stops sputtering too. Maybe that could be causing your leak too. Hope so. davis972
Posted on Aug 15, 2008
The freezer door leaks water from the water/ice dispenser. The dispenser fills up with water. Items in the freezer door almost seem as if they never freeze. All items in the door are much less frozen...
Leaky dispenser-------
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Sep 09, 2011 | KitchenAid KSCS25FKSS Side by Side...
Water dispenser leaks on model number KSRS25FGSS13. I HAVE FLUSH THE AIR OUT AND IT STILL HAS A VERY SMALL DRIP
Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser.
May 10, 2010 | KitchenAid Architect 25.3 Cu. Ft....
Water dispenser leak all the time how can i fix it?
May 10, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Our Kenmore side by side model number 10653382300 is having a problem with the water/ice dispenser. The water dispenser continues to drip and I can not get it to stop. How can I fix this problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jan 08, 2010 | Refrigerators
The ice and water dispenser on my Amana Refrigerator slowly leaks water. Are there repair parts to correct this? And how is the plastic frame containing the dispenser removed from the door?
The problem is most likely not in the door. When the dispense button is pressed it actuates an electric solenoid valve in the rear of the refrigerator that opens and allows the water to flow. Over time the valve seals get worn and the water seeps by. This is what usually causes a drip at the water dispenser. If there is a drip at the ice side then the door is jammed and is not closing fully. This allows the ice at the opening to melt and drip. Hope this helps. Please accept and rate. Good luck.
Dec 08, 2009 | Amana ARSE664BS Side by Side Refrigerator
The door water dispenser leaks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Dec 03, 2009 | Frigidaire FRS26H5AS Side by Side...
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water dispenser leaking at the door all the time.
Jul 09, 2009 | GE GSS25JFM Side by Side Refrigerator
lot of water coming from under the refrijerator
Jan 11, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water Dispenser Drips
Had the same problem after replacing over seven water valves and installing a water regulator in the water line to the refrigerator with no help. Had to reduce the water pressure to about 27 pounds the reduce most of the drips. It drips an amount about the size of a quarter and when the water gets the coldest it stops the drip, but there is always a droplet at the end of the water disperser tube.
The problem is with water stored in the refrigerator side of the box. Water come in and does not leak. After the water gets colder it expands and oozes drips from the water dispenser. It is worse with the roll of tubing behind the crisper drawer on the bottom, because there is no room for expansion in the tubing. We replaced the tubing with and older style tank and it helped some, but not completely. The solution is 1. Try to buy a refrigerator with a tank instead of the roll of tubing in the bottom of the refrigerator side. 2. Don't use the water dispenser. 3. Reroute the tubing directly to the water dispenser and bypass going into the refrigerator, the water will not be as cold. 4. Avoid those built by Whirlpool.
Oct 04, 2007 | Hotpoint HSS25GFP Side by Side...
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
636 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
