Remote control not working for split system
It is hot here and the remote has stopped working. We are only renting and have no manual for the air conditioner. on back of remote says R11HG/E-XLM but I cannot see anywhere that batteries are
  • angelln Apr 23, 2009
  • Anonymous May 04, 2009
    its stupid destroy the control to change the batterys i think so D:
Slide the slider down until it stops, then lift/prize the middle of the slider lid upward (or outward,, however you concieve it) and continue sliding the final 2cm. Voila! batteries are revealed. 2x AAA.
Don't understand? (Don't worry, my wife can't do it even after watching me do it TWICE !!)
Okay... the slider stops about 2cm from the bottom of the remote (when slid down as far as it will go). The reason for this is a small catch in the middle of the remote, just below the lidof the slider-bit. You need to LIFT the lid of the slider over that catch. The reason I use the word 'prize' beacuse you'll need to dig your fingers downwards, just below the TIME ADJUST button, and at the same time work the lid upwards against this pressure. LIFT / PRIZE the lid up in the middle, and away it comes!!
Still don't get it? YOU ARE USELESS and must go and pay one of the clever people to do it for you, *******!!!!!
Ha Ha aaaahhhh!
Posted on May 13, 2009
  • Tony Jun 21, 2012
    Instructions were excellent. And here I was trying to pry the back off the controller before finding your tips. thanks stingraymk1
  • Robert Gronbeck
    Robert Gronbeck Nov 14, 2013
    absolute legend, 6 months of no hope, decided to search and VOILA!!!
  • 958 Answers
What kind of airconditioning do you got?..is it a split unit or a window type? what is the model number? the batteries could be at the front if the remote is a sliding type. you have to slide the cover and remove it carefully , the battery would be exposed.
Posted on Feb 17, 2008
I just had the same problem with my remote. The slide does slide off and you can change the batteries.
Posted on Nov 13, 2008
Hey,
I just had the same problem, if the remote slides down, the batteries are at the end of the remote. You need to carefully remove the slider part and the batteries are under there. I found I needed 2 x AAA batteries and I am now able to turn off the air conditioner!
Thanks heaps for the help above - it helped immensely!!
Posted on Sep 29, 2008
It's a carrier split air system. Can't seem to slide it down?!?
Posted on Sep 12, 2008
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
I am in a rented unit, the power went off the other day and now I can't get my aircon split system (no manuals provided) to work again
Normally in your situation I would call the owner and ask for instructions. You could request the owner to send a technician and get it up as a tenant you cannot be denied use of the aircon if that is part of your lease benefit.
We cannot help you much at fixya.com without knowing the make and model number of the aircon unit. Usually with split systems I could suggest you turn the mains power off at the circuit breaker, wait a few seconds and then turn back on. Then go to the internal unit and with remote control start the unit. See if everything comes back to normal.
Sep 02, 2014 | Heating & Cooling
The remote control won't work even though I have
bad remote control may something got spilled on it they do not like to get wet. Tom try google manufacture to get new is their power to the unit tripped breaker.Tom
Jun 20, 2009 | LG LSC121PMA Split System Air Conditioner
Split system not starting up for about 10 mins after turning on
Hi Wendy,
The manual for the unit is at this link. This should answer all your questions. http://panasonic.com.au/products/details.cfm?objectID=4601 then go to the bottom of the page and click on CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me
Thankyou
Mat
Jun 10, 2009 | Panasonic MCM INVERTER
Cant get air con to work it is a teco air conditioner
Ours did the same. My husband checked the manual and found that the filters were FILTHY! The filter is at the front of the inside unit. If you still have the manual it will show you where. This fixed ours as it was NOT working at all!!
Mar 01, 2009 | Heating & Cooling
Remote won't work
The remote stopped working. So I changed the batteries Then remote signal's are OK But Indor Unit is not controlled by remote.
Feb 01, 2009 | LG LSC121PMA Split System Air Conditioner
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Centrex split system air conditioner
I have a centrex split system which the inside unit is working but the outside one the motor is not working does anyone know why and where can i get parts from sice centrex no longer exists..
Nov 18, 2007 | Heating & Cooling
Heating & Cooling Logo
5,902 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
