Question about JVC AV-27790 27" TV
Time display Hi, I just bought a used JVC AV-27790. I set the time and now it displays in the bottom right corner at all times! Do you know how I can turn it off. I've looked but can't figure it out. Or where I can view a manual? Thanks, Carrie
    Problem Solver:
  • 15 Answers
Go to JVC's website to download user manual.
The link is:
http://books.jvcservice.com/
Posted on Feb 16, 2008
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
Time display problem
mostly there is a button with an i on the remote,push it a few times
Apr 08, 2010 | JVC AV-36D303 36" TV
I need instructions for using my N1506 timer.
SETTING NOMA N1506 TIMER
Plug in timer – The letter C will Flash
TO SET CURRENT TIME:
Press Time Button – It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button – Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again – the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button – Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
Dec 04, 2009 | Woods Hardware & Accessories
JVC AV-K21T: TV goes off by itself
U know how to solder right?Take the backcover off take back of the handle screw driver taps where the part said it flickker or video back on, resolder that.
Sep 27, 2009 | JVC AV-20D303 20" TV
I can not get the time off of the front display
Hi There,
Try unplugging the TV for 2 minutes then plug it back in. Let me know what happens.
Mar 14, 2009 | JVC AV-32D305 32" TV
'03' is displaying on my screen
First try, using the remote, pushing the display button until the display is turned off (three to four depressions on the remote display botton. Second try, unplugging the tv for at least 2 minutes then plug the tv back in. This should reset the tv if you have lost the original remote with the display bottton.
Dec 30, 2008 | JVC AV-36260 TV
The digital clock on my 30"JVC is showing in the bottom of screen
The menu screen does not function the display. Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes or more and plug the tv back in. This should reset the tv display. If the universal remote has a display button, depress the display button until you get the desired display results. Reference the user guide below for the display button.
neww.gif JVC AV-36D503 36" TV - User Guide (page #43)
Dec 20, 2008 | JVC AV-36P902 36" TV
JVC TV with time displayed and will not turn off.
use your front control button to try to enter yoyr menu settings and if possible turn off display function.
Oct 22, 2008 | JVC AV-27D302 27" TV
Time set
How to change the time on a Pioneer DEH 1500 car stereo:
With the radio off, select the 'clock' (upper left button) to display the time.
Press and hold the 'audio' (upper right button) until the time display blinks.
Use the 'select' buttons to select the hour or minutes and adjust time (right button selects minute digits, left button selects hour digit, up button increases the time, bottom button decreases time). Comment by dognut, posted on Dec 25, 2007 Just a further comment posted by dognut:
After setting the desired time, 'press any
Oct 25, 2007 | Pioneer DEH-1500 CD Player
JVC AV-27790 - single horizontal line
Since Intermitant always inspect the vert ckt for bad solder connections. If not replace the output IC they're cheap and most likely the problem If you still have lines on the top or bottom I would replace all of the electrolytic capacitors in the vert ckt also. Without much test equipment rebuilding the whole little ckt is the best way to go.
Apr 24, 2007 | JVC AV-27790 27" TV
Televison & Video Logo
67 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
