Question about Radio Communications
Does not respnd when I talk
I just bought this 2 way radio, Ive set it up as it said, but when I try to talk nothing happens...........no sound comes thru
  • calladium Feb 17, 2008
    I have a midland 16 channel..........I get response if I have one cahnnel on 6 and one on 7............but I dont hear myself talk in it......any help?
    Master:
  • 518 Answers
You're not providing enough details to be able to help you.
Geno
Posted on Feb 17, 2008
How do i get the radio back to factory settings
In order to Get the RADIO back to factory default settings,all you have to do is,If you have a NEW RADIO,read it,by using the software/programming cable,and write it in your old radio,
Thank you,
Jack
Jan 27, 2013 | Radio Communications
I just bought a cobra 18 wx st 40-channel base cb radio and when i talk in the mic it comes out all distorted on the other end ive tryed three different mics do you have any answeres
Well, someone could have over modulated it. Some trashy techs will cut resistors and do nothing more than make it sound icky and bleed all over. You can turn the mic gain a quarter way to the left from where you had it and see how that performs. A mic gain turned up all the way is OK for farther transitions but a mic gain turned up all the way to people much closer will sequel and sound what I call "mashed out" ( distorted. ) If this does not help then take it to a licensed tech to inspect as the fix will be from inside the radio. Also make sure your SWR is 1-1:5 and no higher than 2. You can loose distance from a high SWR and burn up your radio. Good luck.
Feb 04, 2011 | Cobra 18 WX ST 40-Channels Base CB Radio
The speakers no longer work. They were working 2
selectbanker, As a test only try this. Remove green plug from rear of pc. Find old am/fm stereo transistor radio or even a portable cd player and connect the green plug to your "new" audio source. Can you hear anything coming out of the monitor's speakers? Also try a set of stereo headphones in the green audio "out" jack to see if sound is coming out of the pc. Narrow down where loss of signal occurs first. 12fixlouie
Apr 07, 2010 | HP Compaq WF1907 Monitor
Cb radio doesn't give out any sound
You would be surprised how little people actually talk on CB radios these days. I went through similar struggles a few years ago. Unless you are in a major trucker area, the CB radio is basically silence.
Check out the weather channels (anything on the WX setting) to make sure that your radio is receiving frequencies correctly. If that doesn't work, then it is your box, but I bet that will work.
Oct 30, 2009 | Radio Communications
My radio on my82 honda goldwing dont have sound
(Better1969) is correct. I just bought a 1983 Aspencade and there was no sound to my speakers. The gentleman I bought the bike from supplied new speakers but I quickly ruled that out. There are 3 fuse links behind the left turn signal in the fairing. 1 was a 1 amp, 1 was a 2 amp and the blown fuse was a 5 amp. I didn't have a 5 amp so I put a 2 amp in its place. So far the sound is still working but my FM radio reception is very poor.
May 14, 2009 | 1986 Honda GL 1200 Aspencade Gold Wing
Unlock radio in 98 beetle
I've had this happen twice when the battery died. It goes into the SAFE 2 mode if you try entering it and don't do it right and then you have to leave the radio on for 1 1/2 hours to have it come on to 1000 and then set it with each number one at a time and then hold down right reset until he beeps on. So, if you are discouraged as I was, the answer is to leave it on with the SAFE showing for over an hour and it probably will come on with the 1000 for setting eventually.
Aug 02, 2008 | 1998 Volkswagen Beetle
Radio Communications Logo
65 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
