Computer will not boot
I have used the restore disk and it will not boot. At the bottom of the screen it says that the master hard disk S.M.A.R.T is bad, backup and replace.
If you're confident enough, power-up and enter the BIOS. You need to find the reference to S.M.A.R.T and deselect it - then see if the hard drive will boot.
If it does, backup any important media before using Windows to check the disk. In XP open 'My Computer', right click on the drive, scroll down down and open 'Properties' > 'Tools' >'Check now'
and select both options before hitting 'Start'.
It's difficult to say whether the problem was software initiated or simply that the drive is shot.
Posted on Feb 16, 2008
Mi notebook acer aspire 3000LCi the only do is a an upper and i dont have a recovery disk
When you restore your system back to the new factory settings, it will wipe your hard drive clean and do a fresh install of the operating system with the original factory setting.
To start this process, unplug all extra devices from your computer
(printers, external hard drives, etc.) as these can interfere with the system restore.
Starting with Windows XP, most systems with issued a system recovery disk in case of any problems with the factory installation.
Check the documentation and disks that came with your computer to determine if you have one of these system disks.
If you do have a copy of this disk, place it in your CD/DVD drive and restart your computer.
If you do NOT have a copy of this disc, skip to step 3 for further instructions.
Once you restart your computer, a screen will appear with the words.
Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings.
Follow the on-screen prompts to finish the installation.
Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again.
Restart your computer to complete the restore.
3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk.
Unplug all external devices and restart your computer.
When the loading screen comes on with the Windows logo, press Alt+F10 together five times.
This will bring up the system restore menu.
Follow the on-screen prompts to restore your computer back to the factory settings
hope this helps
Oct 17, 2012 | Acer Aspire 5610-4648 Notebook
I tried to restore my sister laptop..but i got a message saying restore failed..so when i tried to restart the computer...i just got a black screen with the message NTLDR IS MISSING...Press ctrl+alt+Del...
Hi there, I did a bit of research on this for you and this is what I found:
First off, there are numerous causes which could be giving you this message. Odds are it's because reformatting wasn't completed properly, which means something on your computer hasn't been set up properly.
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and/or NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32. New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS.
Jan 06, 2011 | Acer Pink 101 Aspire One AOD2602571...
I have a Maxidata msi 865GM3-LS (ms - 7037 Ver:1) Motherboard , have two hard drive as master and slave. Suddenly when opened the pc, I got a message disk boot failure and unable to ...
Not shown in BIOS!!!
How old is that hard disk?
Have you been receiving messages showing "SMART error" or something like that?
If yes, hard disk can be damaged.
Aug 11, 2010 | MSI 865GM3-LS (MS7043020) Motherboard
On turning on my computer I get the HP screen with three options at the bottom Boot menu Startup menu System recovery When choosing the boot menu or startup menu the computer fails to bring up these...
The hard disk inside the computer had failed and must be replaced.
Since your system had an recovery partition and not a separate recovery disk you must contact HP and order a separate recovery disk. If you have a friend with the exact model of c then you can use its disk, but only if its the EXACT same model.
 This is a very big problem - and at least a basic knowledge of hardware is required to replace the failed hard disk. And some software experience is also needed to reinstall.
Aug 10, 2010 | Computers & Internet
I just installed a new hard drive into my gateway desk top and put recovery cd in and its says missing operating system
You will need to go into the BIOS screen and set the first boot device to CDrom. You can get to BIOS when the machine first boots, as soon as you see writing on a black screen press the bottom to get to setup. When you get to the setup screen look for an option to set boot devices or "boot priority". The first boot device needs to be CDrom and the second device can be Hard Drive. Now save the settings. This time on boot the computer will boot to the CDrom restore disk and you can follow its guides to restore your system.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 29, 2009 | Computers & Internet
Boot disk error insert system disk and and press enter.
it is a hard disk error. most likely your hard disk is defective since is it not registering well. please try to use 80-pin interface cable to correct the problem or change your Hard Disk
Sep 21, 2009 | ASUS P4S533-MX Motherboard
Boot problem
it sounds like the hard drive has died. to know for sure, push f12 at the boot screen and boot to the diagnostic partition. if it will load, the diagnostic tests will tell you exactly whats wrong, if it wont then the hard drive is definitely bad.
Aug 17, 2009 | Dell OptiPlex GX260 PC Desktop
Restore failed reason 0xa000000c.
this error is referring to a bad MBR (Master Boot Record)
which basically means that you will need to take steps to either recovery the master boot record or restore your computer using the the recovery disk.
Apparently acer has a partition specifically for recovery.
did you repartition your hard drive?
Try Booting and pressing ALT F10 and that may take you to a recovery console.
May 24, 2009 | Acer Computers & Internet
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
Computer doen't recognize Maxtor n256 have to boot by CD
  1. Log on as administrator or as a member of the Administrators group.
  2. Click Start, click Run, type compmgmt.msc, and then click OK.
  3. In the console tree, click Disk Management. The Disk Management window appears.
  4. you should see the maxor disk (unallowcated)
  5. right click & format it
Apr 04, 2009 | Maxtor Hard Drive
Computers & Internet Logo
89 people viewed this question
Alun Cox
David Payne
David Payne
